Temporary roof fix?
SV8Predator
Temporary roof fix?
Post by SV8Predator » Sat Sep 11, 2021 10:51 am
Smartbear wrote: Sat Sep 11, 2021 12:25 am As opposed to you, who only seems to come on here to criticise & find fault?
I'll certainly criticise when I read (as RobbiZ4 would say) these "crazy stories" from uninformed posters.
This is a highlty regarded forum and new or prospective owners come here for informed advice. They should not have to wade through messages and try and decide which is accurate and which is mystery and imagination. Don't you agree?
2012 Z4 2.0 M-Sport Atacama Yellow
2000 Z3 3.0
2016 Vauxhall GTC Sunny Melon Yellow
2000 Jaguar X308 Sovereign 4.0
1969 Jensen Interceptor 6.3 litre
Smartbear
Temporary roof fix?
Post by Smartbear » Sat Sep 11, 2021 11:04 am
SV8Predator wrote: Sat Sep 11, 2021 10:51 am
I’ll tell you what, if your roof motor merely melts & doesn’t actually burst into flame & you feel aggrieved by this (which you obviously would)
I’ll come round & torch your car for you.
Happy now? :P
e85 3.0si sold
therealmc
Temporary roof fix?
Post by therealmc » Sat Sep 11, 2021 1:35 pm
Next update.
Returned home to Sussex without any further issues. Since we weren't touching the roof, I'd decided to retract the shelf in the boot to give more room for luggage etc and coincidently or otherwise have not had even a whif of an alert for a day or so. Is it possible that the collection of sensors and microswitches regarding latching etc 'shutdown' because a fundamental one connected to the shelf position isn't going to let you try to lower the roof?
Next up is to find an independent BMW garage (don't want to pay dealer prices unless things get desperate) who can have a look at it all.
Pondrew
Temporary roof fix?
Post by Pondrew » Sat Sep 11, 2021 2:37 pm
therealmc wrote: Sat Sep 11, 2021 1:35 pm Next up is to find an independent BMW garage (don't want to pay dealer prices unless things get desperate) who can have a look at it all.
You may struggle finding an independent garage who know what to do unless it is very simple. Seems to be a dealer, or a roof specialist job from what I've seen.
If you have a decent code reader, are able to do any work yourself, then give RobbiZ4 a shout who will advise on what to do :thumbsup:
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
therealmc
Temporary roof fix?
Post by therealmc » Sat Sep 11, 2021 5:49 pm
Hot off the press - report from the code reader at my son's garage:
@RobbiZ4 any thoughts?
SV8Predator
Temporary roof fix?
Post by SV8Predator » Sat Sep 11, 2021 9:03 pm
Looks like the infamous microswitches that RobbiZ4 recommends being replaced as service items.
2000 Z3 3.0
Smartbear
Temporary roof fix?
Post by Smartbear » Sat Sep 11, 2021 9:41 pm
Told you I’d read it somewhere, posted by Robbiez4 no less https://www.spoolstreet.com/threads/urg ... lays.3815/
Couple of screenshots, one of which shows a burnt out e89 roof motor
e85 3.0si sold
flybobbie
Temporary roof fix?
Post by flybobbie » Sat Sep 11, 2021 10:11 pm
Seems the discussion also suggests fitting of buzzer to warn relay contacts haven't opened.
We have the same in aviation, on the instrument panel the CAA mandate a starter warning light.
Years ago an acquaintance told me he was flying mechanic on board a Dove aircraft.
The starter had stayed engaged and caught fire.
So warning light had to be fitted, but usually only on coil side of relay from what i have seen.
Really needs connecting to the contacts.
SV8Predator
Temporary roof fix?
Post by SV8Predator » Sat Sep 11, 2021 10:21 pm
Smartbear wrote: Sat Sep 11, 2021 9:41 pm Told you I’d read it somewhere, posted by Robbiez4 no less https://www.spoolstreet.com/threads/urg ... lays.3815/
Yes, as explained by RobbiZ4 on P1 of this thread:
RobbiZ4 wrote: Wed Sep 08, 2021 7:26 am I would not expect "flames". The motor simply continues turning around as intended. But it gets hotter and hotter until internal(!) plastic parts will get overheated and melt away. Then the rotating unit will stop, cool down and is destroyed.
2000 Z3 3.0
Smartbear
Temporary roof fix?
Post by Smartbear » Sat Sep 11, 2021 11:59 pm
SV8Predator wrote: Sat Sep 11, 2021 10:21 pm
Yep, in Robbie own words the pump has been burned. I knew I’d read it somewhere.
e85 3.0si sold
Ole gits rule
Temporary roof fix?
Post by Ole gits rule » Sun Sep 12, 2021 8:48 am
Looking at that, think it may be time to change the salmon relays :thumbsup:
M4 Vert in Yas Marina Blue
enuff_zed
Temporary roof fix?
Post by enuff_zed » Sun Sep 12, 2021 9:17 am
Smartbear wrote: Sat Sep 11, 2021 11:59 pm
It does look as though Robbi is suggesting the motor would get extremely hot and melt itself, rather than burst into flames, at which point perhaps the circuit would be destroyed and nothing further would occur? Not sure, I'm no expert on electrickery at all.
However, I do think Rob has a point too. Whilst the motor may not burn, the heat generated by it could conceivably be enough to set fire to insulation etc.
Regardless of whether it melts or burns, I would not want something reaching that temperature in the boot of my car.
Following Robbi's suggestion of disconnecting it would seem wise to me.
HQ of 'Norfolk Zed Rescue'.
Smartbear
Temporary roof fix?
Post by Smartbear » Sun Sep 12, 2021 5:47 pm
SV8Predator wrote: Fri Sep 10, 2021 10:59 pm
Smartbear wrote: Wed Sep 08, 2021 10:54 pm Because I’d read it elsewhere, is that ok with you?
No no real-world experience then?
I don't understand why people post their "wonderful advice" when they really don't know anything about the subject being discussed?
See Robbi's advice (above). He actually has the real-world experience.
Just to reply to your rude & ignorant comment about “not knowing anything about the subject being discussed”
I worked with DC motors & electro/hydraulic motors for the best part of 20years, my experience also includes fault finding on relay interlocking circuitry. Prior to that i installed & commissioned battery backup systems for the National telephone network.
I’m not sure what you bring to the table apart from a penchant for sarky comments? Maybe you could enlighten us as to your technical prowess?
e85 3.0si sold
flybobbie
Temporary roof fix?
Post by flybobbie » Sun Sep 12, 2021 5:56 pm
Anything electrical has potential for catching fire. I have used a fire extinguisher 4 times on electrical equipment to put fire out.
SV8Predator
Temporary roof fix?
Post by SV8Predator » Sun Sep 12, 2021 8:43 pm
Smartbear wrote: Sun Sep 12, 2021 5:47 pm Just to reply to your rude & ignorant comment about “not knowing anything about the subject being discussed”
The subject being discussed is the fact that (according to you), the pumps can burst into flames, if a fault lets them run continuously:
Smartbear wrote: Tue Sep 07, 2021 10:31 pm they can burst into flames!
This has been refuted by other posters, speaking from their experience. You attempted to justify your claim by spuriously quoting RobbiZ4 who actually said nothing of the sort. Overheating and melting of internal pump components is not "they can burst into flames!".
Rude and ignorant?
Smartbear wrote: Sat Sep 11, 2021 11:04 am I’ll come round & torch your car for you.
2000 Z3 3.0
