Best OBDII Reader?
Best OBDII Reader?
I'm in the states and new to the bimmer world. Best reader that won't break the bank? I've only ever owned the cheap OBDII reader that I know won't work on this car.
- mr.tourette
- colb
Best OBDII Reader?
I can reccommend a Creator 310+ as a good code reader and reset tool, available on ebay and Amazon.Works fine on my Z4 and Z3 and is portable so easy to carry in the car. I also run BMW INPA and BMW Scanner 1.4 on a laptop, usually go to the Creator 310+ first when I want to scan the cars its easier than getting the laptop out.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1998 Honda Deauville 650
1999 1.8 Z3
2003 2.5 Z4
- DMike
Best OBDII Reader?
I’ve used a cheap obd-usb cable from ebay with INPA sw (older and runs on almost any Windows laptop) or recently ISTA-D, which requires quite a lot disc space. Some have had problems with either cable or sw installation, but I experienced no major issues. Both programs can do bmw specific tests, actuate controls and with some courage the cable can be used to program some of the cars settings. Cannot suggest any specific cable brand or ebayer as I bought mine ages ago.
2005 Z4 3.0i Sterling grey
Best OBDII Reader?
+1 for Creator 310+
2003 Maldives Blue 3.0i auto
Best OBDII Reader?
I’ve got an iCarsoft CR Pro which is a great multi-manufacturer scanner. It’s more expensive than the single brand ones thought. However, in the long term it’s a better buy. I’ve used it on various Audi, BMWs, Jags, Land Rovers and Porsche.
Best OBDII Reader?
Why would I want two different devices?colb wrote: ↑Wed Sep 01, 2021 7:10 pm I can reccommend a Creator 310+ as a good code reader and reset tool, available on ebay and Amazon.Works fine on my Z4 and Z3 and is portable so easy to carry in the car. I also run BMW INPA and BMW Scanner 1.4 on a laptop, usually go to the Creator 310+ first when I want to scan the cars its easier than getting the laptop out.
Best OBDII Reader?
Definitely want something that doesn't just work on a BMW, but dang, $400!!!!!
Best OBDII Reader?
Foxwell 510.....can buy on EBAY
- Optinium
Best OBDII Reader?
I just got an Autophix 7910 from Amazon for a little over £100, has code reading and erasing features as well as some more advanced ones like module recalibration, battery reset etc...
Got rid of my ABS warning light in a jiffy and had gave me some more codes to dig into.
Youtube: Car Beard Instagram: its_car_beard
Current: 2015 F-Type R RWD, 2022 Tucson N-Line S
Gone: 2021 GR Supra Pro 2007 E86 Z4MC 2016 F-TYPE R AWD Convertible, 2014 F-TYPE V6S, 2007 E86 Z4MC, 2010 E89 Z4 23iSdrive
Best OBDII Reader?
I have one from BAFX and it works fine on mine with the Torque Android app.
Best OBDII Reader?
Okay so it looks like all suggested are specific to BMW except iCarsoft CR Pro (BAFX is just a cheap obdii reader that can't do nearly what I need it to do). Any others out there that can work on other cars aside from BMW that isn't $400?
- GuidoK
Best OBDII Reader?
Depends on what you want.
Most cheap obd2 readers can diagnose the P codes (what description they give to those can vary but you can look them up on the internet), but if you want.....say read out your ABS rings (wheel speed sensors) to see which one is defective (this is just one of the hundreds of things you can do with obd2) you'll either need the real BMW software (INPA or ISTA, and a $10 obd cable), or you need a more elaborate system like AUTEL (or one of the numerous other ones).
These vary between $800 and $8000
The manufacturers need to pay the car brands for intergration of the functionality, so some have different price and can do more or less on more or less brands.
But there is no doubt: with the $10 obd cable and either ISTA D/P or the INPA/ncs expert/tool32/winkfp software pack you can do everything (for flashing you obviously need flashfiles). But this is of course BMW group only.
The software can be found (hacked) on the www so paying for this software is a very questionable situation.
Point is that these are professional softwaresuites, so the learning curve is steep and for some functionality very very steep. Usually if you need to ask, you're not going to get there.
Best OBDII Reader?
So are you saying the handheld ones that were suggested can't do what you are suggesting with the cable? I just want to be able to diagnose issues that arise which could be ABS, etc. as it's a used car and who knows what goes wrong with it
- enuff_zed
Best OBDII Reader?
Just to clarify a little.GuidoK wrote: ↑Thu Sep 02, 2021 7:42 pm
I have an Autophix 5900 and when I got the ABS, Traction and Tyre Pressure warnings on together it was able to tell me exactly which one of the ABS sensors was not working.
It also led me straight to the vanos solenoid valve that was sticking.
It tells me what is wrong in plain language which I like, being a simple soul.
I would imagine paying the extra for the 7910 will give you all this easy to use ability, plus more?
