Can't open boot, panic!
Hi all, morning of nightmares! BMW Z4, E89, 2010, RHD.
Charged the battery this morning after a period of flatness. The windows have the "auto drop by an inch" feature turned on.
I "stupidly" after forgetting which buttons were which pressed the hardtop drop button, which is now flashing red, although the hardtop appears fully closed. Passenger window stuck fully open and driver window stuck fully shut (cannot drop it the quarter inch to shut and lock car properly) and the boot won't open for me to pull down the grey protector so I can see if I can drop and lift the hardtop.
No boot release button in the car, that I can see and no ski hole. Car seems to be charging and will start, but I can't lock, secure, drive etc due to the issues above.
Drama. Thoughts please?
- Zed Baron
Hi longshot here, with the car started press the central locking button (next to the hazard lights, cant remember if its one or two presses) and see if that opens the boot
Hi Zed, tried that..no dice unfortunately!
- enuff_zed
Welcome to the forum.
Sorry it's with an issue though.
Stupid question time, have you tried selecting the roof closed again, using the button in the car?
- enuff_zed
For all things E89 roof related, by far the best bet is to speak to Robbi_Z4, who is based in Germany but is an absolute guru for these roof issues.
Do a search for him through the 'Members' tab and have a look at some of his threads.
Once you have 3 posts you can send him a PM. (Note, this will stay in your Outbox until he's read it)
yes I'd try this with the engine running to ensure you have enough juice... and you still may not have enough if your battery is duff.
Do you have a code reader? Where are you based... you need to know what codes are raised, and there are some options to open the boot with the right code reader e.g. Foxwell.
- Chippie
If the engine starts try leaving it running for half an hour then try putting your windows up and down, if this works do it several times as with a flat battery it may have to re learn when they are fully open and closed, once they are working with the windows closed try pressing the roof close button and see if the light stops flashing red, then try opening the boot,
My wife unlocked the car recently and and held the fob too long which started the roof opening sequence but didn’t unlatch the roof, same situation boot wouldn’t unlock, once l had pressed the roof close button and then light went out the boot opened again
By the way welcome to the forum, please post a photo of your car when you get it sorted
Thanks sincerely all for your replies, I ended up giving up and taking it to the dealer. Work was crazy busy and I was worried about the fact I couldn't secure it
The roof mechanism had stuck and that had locked all the windows and boot, so I couldn't see a way around it in the time I had to look.
As soon as sorted and home (and I'm a few k lighter, I suspect) I'll post a photo
- enuff_zed
Well I hope it gets sorted without a mortgage!noo6py wrote: ↑Tue Aug 31, 2021 6:33 pm Thanks sincerely all for your replies, I ended up giving up and taking it to the dealer. Work was crazy busy and I was worried about the fact I couldn't secure it
On the plus side, you're in now and there's no escape.
Look forward to seeing some photos of your chariot, roof down of course.
Strange, if protector isn't down roof should not do anything but bong, to tell you roof protector is not in position.
I had a window problem, got them all stuck down, was loose connector or pin in connector on the right door window switch.
Taken apart, cleaned and no problem since.
Bad earth pin, because the illumination in switch was out.
I had the windows doing odd things when I had a microswitch issue. I put it down to the 'order' of how things should happen was all to cok. If a problem occurs out of sequence, the computer seems to have a 'brain f*ck' and doesn't know what day of the week it is. Until the sequence is restored, then it seems to get a grip.flybobbie wrote: ↑Tue Aug 31, 2021 7:18 pm Strange, if protector isn't down roof should not do anything but bong, to tell you roof protector is not in position.
I had a window problem, got them all stuck down, was lose connector or pin in connector on the right door window switch.
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
Hi all, sorry for the long time away.
I’ve had some drama with the garage, trying to force a new battery on me at just under £300 without testing via a charge first. The one on the car was only a couple of years old!! They fitted a new battery despite my saying not to.
That’s finally been resolved and they have charged my for 3 hours of inspection so far at £150.
Diagnosed micro switches and controller issue, coming in at around £800 (attached). I’ll be honest though, I’ve lost all trust in them, so thinking of taking to another dealer. Alternatively, could any garage sort these issues?
Thanks for thoughts, hopefully won’t be long before I’ll be posting that pic!
- 6501D99A-B804-4B1F-84EA-7FEBB1ABF1A3.png (487.11 KiB) Viewed 713 times
- enuff_zed
That sounds like they'll just change everything and hope for the best!
Whereabouts are you? Easier to recommend someone if we know.
Also, search for Robbi_Z4 and PM him. He's in Germany but very clued up and helpful on these roof issues.
If he can't fix it, no-one can.
Thanks enuff_zed.
Yep, that’s my concern. They first stated that they replaced the battery as that “might have been it” then immediately went into another two hour round of inspection.
It’s not filled me with confidence from the start of I’m honest.
We’re located in South Wales, Newport, NP20.
Will drop a DM Robbi_Z4 a DM too, thanks again!
- enuff_zed
Hopefully Robbi can at least point you in the right direction.noo6py wrote: ↑Wed Sep 15, 2021 9:09 am Thanks enuff_zed.
I was going to recommend Ross at RBM, but Hook is a fair old trip for you.
