Got my first Z4 earlier couple months back. It had been in storage for a 2yrs, so I accepted I may have a few things to fix.
Anyway, I’ve changed the coil pack which fixed misfiring, but since then it idles at 500-600. Is this too low?
She runs okay, but on pull away needs a little more gas than I’d expect. Anyone else experienced something similar? Should I be concerned?
Idle too low?
OnlineChippie
Idle too low?
It may help if you let us know which z4 and engine you have
Idle too low?
Yeah,sure… e89, 2011 s23i manual. N52. 60k on the clock.
Online
Idle too low?
Mine idles 500-600 rpm. Can need bit of welly when cold in normal, i always drive in sport mode.
Normal mode seems pointless, wish it would stay in mode last selected.
- Ole gits rule
Idle too low?
Mines around 500 to 600 as well and yes needs a bit of pressure n the loud pedal to get it moving
M4 Vert in Yas Marina Blue
Idle too low?
Cool, sounds the norm then. I’ll stop worrying about it!
Cheers fellas
Cheers fellas
