Could it perhaps be that you just needed new injectors, coil packs and plugs because you'd done 60k miles and nothing to do with the fuel?
E10 mpg?
- tiglon
E10 mpg?
2014 E89 35is Valencia Orange 788M wheels (M2 Competition), E90 M3 control arms, Eibach Pro Kit Springs, MHD Stage 1
E10 mpg?
In the world of debate about V-Power, nah. Far too logical. Mind you, it did happen when I tried it.
Vidi, vici, veni
- pvr
E10 mpg?
Or you could say that the cheap fuel had knackered the whole system in that time which otherwise would not have happened
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
E10 mpg?
Ethanol has a lower calorific value than gasoline so your gallon is now in effect less effective so its impossible to achieve more mpg on a lower calorific fuel. Ethanol is however 'greener' so it lowers your emissions per gallon which is the governments aim.
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
E10 mpg?
So we should all be reporting a decline in mpg.mcbutler wrote: ↑Wed Nov 17, 2021 10:38 pm Ethanol has a lower calorific value than gasoline so your gallon is now in effect less effective so its impossible to achieve more mpg on a lower calorific fuel. Ethanol is however 'greener' so it lowers your emissions per gallon which is the governments aim.
Vidi, vici, veni
E10 mpg?
You would expect so budBusterboo wrote: ↑Thu Nov 18, 2021 10:53 amSo we should all be reporting a decline in mpg.mcbutler wrote: ↑Wed Nov 17, 2021 10:38 pm Ethanol has a lower calorific value than gasoline so your gallon is now in effect less effective so its impossible to achieve more mpg on a lower calorific fuel. Ethanol is however 'greener' so it lowers your emissions per gallon which is the governments aim.
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
- pvr
E10 mpg?
That is what is reported as an expected side effect of using E10mcbutler wrote: ↑Thu Nov 18, 2021 10:58 amYou would expect so budBusterboo wrote: ↑Thu Nov 18, 2021 10:53 amSo we should all be reporting a decline in mpg.mcbutler wrote: ↑Wed Nov 17, 2021 10:38 pm Ethanol has a lower calorific value than gasoline so your gallon is now in effect less effective so its impossible to achieve more mpg on a lower calorific fuel. Ethanol is however 'greener' so it lowers your emissions per gallon which is the governments aim.
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- pvr
E10 mpg?
Example: https://www.topgear.com/car-news/top-ge ... t-it-means
Topgear wrote:
In an engine, burning a less energy-dense fuel means that you need to burn more of it to get the same amount of power. This doesn’t mean that you’ll lose power if you use E10; rather that your fuel economy will drop as your car’s engine computer fiddles with fuel-air ratios to get the best stoichiometry (a fancy-pants term for the ideal mixture). So while the carbon count goes down with ethanol-blended petrol, fuel consumption goes up.
Or RAC: https://www.rac.co.uk/drive/advice/emis ... ffect-you/
RAC wrote: “And those with E10 compatible cars will unfortunately find they are getting fewer miles to the gallon as the fuel is less efficient than E5 fuel, due to it containing 5% more ethanol.
Or Autocar: https://www.autocar.co.uk/car-news/new- ... my-10-cent
autocar wrote: New E10 fuel could reduce a car's economy by 10 per cent
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- Smartbear
E10 mpg?
Wow, that’s shocking! I’d heard of a 3% drop in economy before but not as high as 10%, that’s an even better reason to run on super-unleaded
pvr wrote: ↑Thu Nov 18, 2021 3:15 pmExample: https://www.topgear.com/car-news/top-ge ... t-it-means
e85 3.0si sold
E10 mpg?
This thread was asking the question does E10 fuel give you less MPG. From my experience the answer is no. I just wonder if part of the reason for the price rise is the extra Ethanol which is being masked by the general rise in oil prices worldwide.
G29 M30i M Sport San Francisco Red
Previous
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
- pvr
E10 mpg?
Or even "dangerous" / "Criminal" reduction in fuel efficiency
https://www.msn.com/en-gb/cars/news/its ... li=AAnZ9Ug
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
