Good feedback ..still planning to get some form of lift myself but the garage does have limited roof height so not sure how much higher than 1m I could go anyway…stevespg wrote: ↑Sat Oct 16, 2021 12:02 pm I have a low height scissor jack which is great for most jobs. It lifts about 1m which means you can’t stand under, but I had limited roof height
Positives
Park over it without any issues
No posts to hit doors on
No posts creating obstructions in the garage
Negatives
Access under is more limited than 2 post, but I can still get to everything I need
If space around the car is no issue, and you don’t park between the posts all the time. Then a 2 post is great. But as a lift for what is irregular use, where it’s in a tighter space, then for me the access around the car prompted a scissor lift.
Scissor lifts or 2 pole lifts for use in a home garage
- B21
It was from a place called garage equip group I think.
Was under £1k new, had it a few years though now, used regularly for all sorts.
I’ve had a few tvr which are very low and this just works for them in terms of driving over.
Lifts 3000 kg which works for bigger stuff too
If I had loads of room… a 2 post would be in there, but this works for me.
- 97A9AADA-A03A-4008-BF10-3F00631E33EE.jpeg (99.31 KiB) Viewed 459 times
- 909FD0AD-D880-4C12-BF1C-83DC5855262E.jpeg (125.81 KiB) Viewed 459 times
Z4 3.0si - gone
Z4MR - gone
E89 35i - gone
Z4MR - gone
E89 35i - gone
- RedUn
That looks ideal! I've got the same height restriction to I'll be going for a metre too! I can't seem to find one for much less than 2k at the minute though which is slightly annoying!
IMOLA Z4///MR
- B21
- RedUn
I looked at them but came to the conclusion it's not that much cheaper than the scissor lift so might as well go the whole hog! Man maths for you
IMOLA Z4///MR
These have bars that cross under the car, making access harder. I used one once. Was impossible to work on exhaust, gearbox etc.
Z4 3.0si - gone
Z4MR - gone
E89 35i - gone
Z4MR - gone
E89 35i - gone
- B21
Good point!stevespg wrote: ↑Fri Oct 22, 2021 10:13 amThese have bars that cross under the car, making access harder. I used one once. Was impossible to work on exhaust, gearbox etc.
This is the kind of thing I have, it has compressed air safety locks which mine doesn’t, which would be ideal but I didn’t have a compressor at the time I bought mine.
(I always put a set of axle stands under the scissor section of the lift which would prevent it lowering in the event of a catastrophic fail).
https://www.ebay.co.uk/itm/AB-MR3000-3- ... 635-2958-0
There are a few suppliers, mostly of Chinese origin (what isn’t these days!!), but Automec and others sell alternates.
Z4 3.0si - gone
Z4MR - gone
E89 35i - gone
Z4MR - gone
E89 35i - gone
- B21
Looks good, is the length of the 'treads' short enough to clear the E89 wheels and arches? I assume so..?stevespg wrote: ↑Fri Oct 22, 2021 11:35 am This is the kind of thing I have, it has compressed air safety locks which mine doesn’t, which would be ideal but I didn’t have a compressor at the time I bought mine.
On mine, the treads ends (last12 inches or so), flop down, so you can easily access wheels and other stuff readily.
They work with the tvr tamora which has a short wheelbase of 93 inches
You can also lock them horizontally and lift the car with them if you have a longer car, I’ve used that for the trucks I’ve had. Most useful!
- FF5045D1-8846-4623-8CBA-1EB5C576537C.jpeg (123.93 KiB) Viewed 299 times
Z4 3.0si - gone
Z4MR - gone
E89 35i - gone
Z4MR - gone
E89 35i - gone
And hockey pucks make great jack pads on these. Small, almost solid and take up little height.
The tam has chassis bolts that protrude, and I just lift on those on the hockey pads. Looks like it’s sat on the body, but it’s on the chassis
- B4B0110B-3E7B-4D8C-9EA9-F8A6F1368694.jpeg (94.51 KiB) Viewed 298 times
Z4 3.0si - gone
Z4MR - gone
E89 35i - gone
Z4MR - gone
E89 35i - gone
- B21
Looks good have you lifted the 35i on it yet?
Yep. Fits easy.
The tam is pretty low and fits over .. close but ok.
The 40mm thick blocks of wood I leave under the ramp slopes just so I can slip the hockey pucks under the chassis easily, (without the blocks I have to lift the front arches 5 mm shove them under a bit blind), and because I don’t really like slipping the clutch when the car’s stone cold on the tam every time I use it just to reverse over the ramps to exit the garage. The clutch is a bit of a “switch” when cold and you’re holding revs to keep the engine on idle for the first minute or two.
The z is less fussy and no issues.
Z4 3.0si - gone
Z4MR - gone
E89 35i - gone
Z4MR - gone
E89 35i - gone
- B21
I'll put in on my christmas shopping list..just need the garage to be finished first!stevespg wrote: ↑Fri Oct 22, 2021 3:30 pm Yep. Fits easy.
