E85 Front suspension/shock absorbers- How To
bigwinn
Post by bigwinn » Sat Dec 18, 2021 5:11 pm
No worries gents
Wouter I’ve yet to do front suspension and find that the upper and lower rubbers are past it- but of course if you want peace of mind go for it!!!
Z4’s: I’ve lost count and let’s not talk about how many are on the drive as I get constant reminders from ‘er indoors
EWS Delete PM me
Coding- airbags etc PM me
WouterZZZZ
Post by WouterZZZZ » Sat Dec 18, 2021 10:38 pm
Thanks, I will replace them after nearly 17 years of perfect service. You have inspired me a lot. Have nice Christmas holidays. Off course I will let you know once I’ve replaced it all. Frgr Wouter
True-Blue
Post by True-Blue » Sat Dec 18, 2021 10:41 pm
WouterZZZZ wrote: Sat Dec 18, 2021 10:38 pm Thanks, I will replace them after nearly 17 years of perfect service. You have inspired me a lot. Have nice Christmas holidays. Off course I will let you know once I’ve replaced it all. Frgr Wouter
I had no choice as my car was running on coilovers when I bought it, and the original struts were not included. I have to say though, the spring pads are cheap as chips really, so worth replacing IMHO :thumbsup:
Previous Z4’s :E89 30i, E89 20i, E85 3.0Si (X4) E85 3.0i, E86 3.0 Si, E85 2.5si, E85 2.5i
Zulu4
Post by Zulu4 » Tue Jul 12, 2022 6:40 pm
Thanks Stuart for the great write-up.
I just changed my front shocks for Bilstein B4's and I noticed a couple of things which others may find useful.
Firstly, the B4's have a longer shaft than the OEM shocks that were on my 3.0Si Sport. I had read that someone was concerned that this would be the case and that the B4's would now be in a permanently compressed state when fitted. I understand why now, so time will tell how they do.
Secondly, when I refitted the spring, I initially thought this was the correct place for the bottom end to go, as it seemed to fit nicely against the lip of the rubber.:
But looking at Bigwin's and my other side which I hadn't dismantled, it seems the end of the spring needs to be in this position:
2007 3.0si Auto Sport Roadster. Whippy.
Previous:
2003 3.0i SE Roadster. Whippy.
bigwinn
Post by bigwinn » Tue Jul 12, 2022 7:02 pm
That had me foxed for a while Rob as it looked like it should sit into that groove flush- but it doesn't!
Well done
And thanks again for the loan of VCDS
EWS Delete PM me
thespannerman
Post by thespannerman » Sun Jul 24, 2022 3:53 pm
Just ordered and now awaiting delivery of all the bits to do mine, but intriguing bit about the lower spring position as I would have also thought it would have gone up against that step in the rubber.
Al
BMW newbie, 2003 E85 2.5 SE - but after 10 Discoveries this ought to be a walk in the park :P
enuff_zed
Post by enuff_zed » Sun Jul 24, 2022 3:55 pm
thespannerman wrote: Sun Jul 24, 2022 3:53 pm Just ordered and now awaiting delivery of all the bits to do mine, but intriguing bit about the lower spring position as I would have also thought it would have gone up against that step in the rubber.
Nope, mine have always been the same, don't quite line up as you'd think.
Headquarters of 'Norfolk Zed Rescue'.
Vanos seals, Disa mods, EPS motors & column changes, roof motor relocations, suspension refreshes, airbag module coding, transport mode resets, anything else you need help with please PM me.
Zedebee
Post by Zedebee » Sun Sep 17, 2023 11:01 pm
Hi Bigwinn, how did you torque up the top nut to 64Nm without the piston spinning? NewTIS says to use a special tool. I can’t for the life of me remember how I did it last time.
2003 Maldives Blue 3.0 auto w/ paddle shift, 3.0Si brake upgrade, colour coded interior, other projects ongoing
Previously: Maldives Blue 2.5i manual, and another, and a Monaco Blue 3.0Si coupe
bigwinn
Post by bigwinn » Mon Sep 18, 2023 6:41 am
If I recall I did it as tight as I could off the car with mole grips on the shaft then installed on the car and re torqued with the weight on the wheels
EWS Delete PM me
