I always understood it to be for modulation...it does look like there's some design elements for heat on them calipers though!Pbondar wrote: ↑Fri Jun 25, 2021 9:01 amApparently to apply different pad pressures along a long thin pad ..some say for gas pressures..others say heat spread..Nictrix wrote: ↑Thu Jun 24, 2021 6:42 pmI wonder what the reason is for the different designed pistons in the caliperSimon 3.2M wrote: ↑Thu Jun 24, 2021 2:51 pm I put these on mine with matching rears, made for a nice improvement with better pedal feel.
Brake upgrade suggestions
- RedUn
IMOLA Z4///MR
Be good to hear a review on the VagBrem kit if you go for it.
I've got a spare set on V8 Vantage calipers sat in the garage and have been thinking about fitting them to the Z...
- barryb97
pbbrakes.com has some cost effective alternatives also.
CDV del, clutch stp, LeatherZ console, strut bar, PB brakes, TC Kline coilovers, M3 reps, Stromung, Intravee II, paintd reflect, Hdlt wash disable, AS SSK, RTAB lmtrs, Vibra tech, BMW pedals, Skyer frnt. r lip, r defuser, coil cover, rad cover.
- RvsBmw
Do the pagid make noise or just like oem quiet?
BMW Z4M Coupe '08 | Sapphire Black | Bicolour Silverstone Anthrazit | OEM CSL's | Aero's
