Aftermarket Paddles
stijohnny
Aftermarket Paddles
Post by stijohnny » Thu Jul 01, 2021 8:24 pm
mcbutler wrote: Thu Jul 01, 2021 6:04 pm
stijohnny wrote: Wed Jun 30, 2021 9:18 pm Try these Marc...30th Junhttps://www.mmrperformance.co.uk/products/mmr-p ... paddle-set
Do you know for sure that they fit the E89? Does not state that in the ad!
ML performance in the UK have these on offer at the moment and say they will fit the e89, I have emailed the company to confirm, i'll let you know what they say...
[/quote]They are £200 on ML UK, thats not an offer in my language!
I have messaged them with my VIN for compatibility, they list under E89 but the product description does nt mention E89 at all.
[/quote]
Marc - ML Performance emailed me to say they were 179.99 on offer, unfortunately that ended 30th Jun. I have a search on their website for e89 and they came up. You're right its not 100% they will fit and e89 so thats why I emailed the manufacturer to clarify, I'll let everyone know what they say.
mcbutler
Aftermarket Paddles
Post by mcbutler » Thu Jul 01, 2021 8:39 pm
Also just noticed they have a plus on the right side and minus on the left and the E89 does not conform to this either as we all know...
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Online
Marcoose
Aftermarket Paddles
Post by Marcoose » Thu Jul 01, 2021 9:02 pm
Thanks, John. Yes, keep us in the loop.
Mark, on my 2016 35is ‘facelift’ –see pic in the OP–, right side is +, left side is –.
2016 35is, monoballs, camber plates, KWV3, PS4S, xHP, MHD, LFB pedal, flat bottom wheel, red indicators, black headlamps
Roddy
Aftermarket Paddles
Post by Roddy » Fri Jul 02, 2021 7:07 am
mcbutler wrote: Thu Jul 01, 2021 8:39 pm Also just noticed they have a plus on the right side and minus on the left and the E89 does not conform to this either as we all know...
Are you sure about that? Look at OP's post, and look at mine. I'm collecting info about many BMW models to see if there is any compatibility. They are ALL +PLUS on the right, -MINUS on the left.
LHD, RHD, no difference.
mcbutler
Aftermarket Paddles
Post by mcbutler » Mon Jul 05, 2021 9:09 pm
Roddy wrote: Fri Jul 02, 2021 7:07 am
I emailed them about compatibility and they asked for a pic of my wheel so as soon as I get it doen I will post it here for you
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Roddy
Aftermarket Paddles
Post by Roddy » Tue Jul 06, 2021 1:48 am
mcbutler wrote: Mon Jul 05, 2021 9:09 pm
I found one that does mention Z4 amongst others, in the title at least:
https://www.aliexpress.com/item/4000120 ... 0089ee80-0
I've looked at quite a few BMW wheels with paddles, it *seems* that the paddle maybe common between models, the switch maybe not, hence the different assy part numbers on RealOEM. For some reason the steering wheel is unique to E89.
This is listed as F10 F11 F30 F32 F15 F25 G30 G11 G01, looks very much like E89 paddle.......
https://www.aliexpress.com/item/4000499 ... 089ee80-42
Online
Marcoose
Aftermarket Paddles
Post by Marcoose » Tue Jul 06, 2021 6:00 am
Whilst my 35is’ wheel is at Control Customs for reshaping, I put an used mule wheel, which isn’t a facelift. The paddles don’t match the 7-gear DCT. Don’t know why.
There’s a shop here in Silicon Valley, EuroBoutique, that fabricates gorgeous carbon fibre paddles, among other things. I went there. It’s all legit. But they’ve priced between US$400-US$650. Blimey. That’s mental.
I want longer paddles on the lower side for turn exit, something that isn’t ugly, and that I won’t need to explain myself to my wife.
Roddy
Aftermarket Paddles
Post by Roddy » Tue Jul 06, 2021 7:36 am
Marcoose wrote: Tue Jul 06, 2021 6:00 am that I won’t need to explain myself to my wife.
Haha, not sure mine would notice. :D
RealOEM says this below, all E89 use, or can use the same switches. Do you think you can separate the switch from the plastic part and take a pic? Assuming they are off the car of course. The paddle/switch assembly is different to other cars, just hoping the paddle can be changed.
Aliexpress vendor says they only support G29 Z4
Part 32306799619 was found on the following E89 vehicles:
Z4 E89, Z4 18i, Roadster, N20, EUR, (LL11) : Sports steering wheel airbag w/paddles
Z4 E89, Z4 18i, Roadster, N20, EUR, (LL11) : M Sp. st. wh. airbag multif./paddles
Z4 E89, Z4 18i, Roadster, N20, EUR, (LL12) : Sports steering wheel airbag w/paddles
Z4 E89, Z4 18i, Roadster, N20, EUR, (LL12) : M Sp. st. wh. airbag multif./paddles
Z4 E89, Z4 20i, Roadster, N20, EUR, (LL31) : Sports steering wheel airbag w/paddles
Z4 E89, Z4 20i, Roadster, N20, EUR, (LL31) : M Sp. st. wh. airbag multif./paddles
Z4 E89, Z4 20i, Roadster, N20, EUR, (LL32) : Sports steering wheel airbag w/paddles
Z4 E89, Z4 20i, Roadster, N20, EUR, (LL32) : M Sp. st. wh. airbag multif./paddles
Z4 E89, Z4 28i, Roadster, N20, EUR, (LL51) : Sports steering wheel airbag w/paddles
Z4 E89, Z4 28i, Roadster, N20, EUR, (LL51) : M Sp. st. wh. airbag multif./paddles
Z4 E89, Z4 28i, Roadster, N20, EUR, (LL52) : Sports steering wheel airbag w/paddles
Z4 E89, Z4 28i, Roadster, N20, EUR, (LL52) : M Sp. st. wh. airbag multif./paddles
Z4 E89, Z4 28i, Roadster, N20, USA, (LL53) : Sports steering wheel airbag w/paddles
Z4 E89, Z4 28i, Roadster, N20, USA, (LL53) : M Sp. st. wh. airbag multif./paddles
Z4 E89, Z4 35i, Roadster, N54, EUR, (LM71) : Sports steering wheel airbag w/paddles
Z4 E89, Z4 35i, Roadster, N54, EUR, (LM71) : M Sp. st. wh. airbag multif./paddles
Z4 E89, Z4 35i, Roadster, N54, EUR, (LM72) : Sports steering wheel airbag w/paddles
Z4 E89, Z4 35i, Roadster, N54, EUR, (LM72) : M Sp. st. wh. airbag multif./paddles
Z4 E89, Z4 35i, Roadster, N54, USA, (LM73) : Sports steering wheel airbag w/paddles
Z4 E89, Z4 35i, Roadster, N54, USA, (LM73) : M Sp. st. wh. airbag multif./paddles
Z4 E89, Z4 35is, Roadster, N54T, EUR, (LM11) : M Sp. st. wh. airbag multif./paddles
Z4 E89, Z4 35is, Roadster, N54T, EUR, (LM12) : M Sp. st. wh. airbag multif./paddles
Z4 E89, Z4 35is, Roadster, N54T, USA, (LM13) : M Sp. st. wh. airbag multif./paddles
Online
Marcoose
Aftermarket Paddles
Post by Marcoose » Tue Jul 06, 2021 1:38 pm
Mrs Marcoose has a keen eye for the credit card statement. :lol:
The mule wheel is already on the car.
I’d rather find a vendor that can confirm they have sold paddles for the facelift 35is. I reckon the incompatibility is how the old paddles were push and pull, and the facelift 35is is pull only, right side up, left side down.
R.E92
Aftermarket Paddles
Post by R.E92 » Tue Jul 06, 2021 4:30 pm
The difference in paddles is due to the LCI changes.
Pre-LCI cars have the silver paddles that are push for downshift and pull for upshift on each side. The LCI cars have the black/silver paddles that are pull only and downshift on left and upshift on right.
They are interchangeable between models and cost about £150 from BMW if you wanted to switch.
Personally I prefer the pre-LCI methodology so kept them, the LCI paddles do look nice though.
stijohnny
Aftermarket Paddles
Post by stijohnny » Tue Jul 06, 2021 9:12 pm
I got an email back from MMR they said that if I buy a set of paddles to go for the F series and try them. Any problems whatsoever and they will refund me. I have asked them can I have mine without the + and - signs as they dont correspond with the up and down either side change of the 7 speed DCT in my 35i.
I doubt they can do this but I'll let you know, here is their link...
https://www.mmrperformance.co.uk/produc ... paddle-set
Online
Marcoose
Aftermarket Paddles
Post by Marcoose » Tue Jul 06, 2021 9:28 pm
That’s an easy fix, John. Just buy a 35is.
:D
Roddy
Aftermarket Paddles
Post by Roddy » Wed Jul 07, 2021 3:08 am
stijohnny wrote: Tue Jul 06, 2021 9:12 pm I got an email back from MMR they said that if I buy a set of paddles to go for the F series and try them. Any problems whatsoever and they will refund me. I have asked them can I have mine without the + and - signs as they dont correspond with the up and down either side change of the 7 speed DCT in my 35i.
That's what I'm trying to find out, if the 166 quid paddles from an F series fit, then a $50 Chinese set for an F series should too. Some comments I've found though, go for aluminium paddles and not plastic, as plastic flexes if you use the top of the paddles
stijohnny
Aftermarket Paddles
Post by stijohnny » Wed Jul 07, 2021 7:13 pm
Thanks Roddy, all
I got an email back from MMR saying they will make me a set of paddles without the + and - signs on them so they will be better for the 7 speed dct. I'll order them tomorrow as soon as I get back from FOS. I'll let you know if they fit!
Online
Marcoose
Aftermarket Paddles
Post by Marcoose » Fri Jul 23, 2021 5:28 pm
Has anybody used these?
https://modeautoconcepts.com/products/m ... e0QAvD_BwE
I've emailed them Wednesday. No reply yet.
