topping up oil
- rjhl64
topping up oil
Just checked the oil level on the dashboard display and am trying to work out the amount of oil I need to add. I haven't figured out the scale on the dashboard, anybody able to offer an idea as to roughly how much I need based on the pic?
- IMG_20210613_161604.jpg (119.37 KiB) Viewed 471 times
BMW Z4 SI SPORT Automatic / E86 coupe
topping up oil
Usually on most of these systems from empty to full is one litre
So if you are in doubt add half a litre and see what it then says..
They are not perfect even on an E89 most of the time it says it is full but occasionally I get a 3/4 full reading!
- enuff_zed
topping up oil
Oh, I thought that was showing 1/4 empty?
Not the clearest symbology.
topping up oil
It may be..I’m not a 5th Dan on E85s..but I think the 1 litre from empty to full is correct
- rjhl64
topping up oil
Hi, thanks for the updates, will add quarter of a litre and see it registers, don't really want to overfill
- enuff_zed
topping up oil
topping up oil
I'm pretty sure its 1 litre. Like Pbondar says I just tend to add 1/4 or 1/2L at a time in my E85 to be sure and keep topping up until its happy
2006 Sapphire Black E86 3.0si | 108's, ZHP, Stubby, Eibach Springs
2007 Carbon Black E85 2.5i | 19" NAD alloys, Pilot Sport 4S, strut brace, Stubby, ZHP, Brembo 4 pots, Greenstuff pads, Alcantara retrim, roof motor in boot
2022 BMW G80 320D Touring
Onlinefredej
topping up oil
I don't think you need to add oil at that read out.
This is what it says in the manual. I would only add oil when it is actually telling you to do so. To reduce the risk of overfilling it.
- enuff_zed
topping up oil
You're right.
That is showing you may be down 1/4 litre-ish. But it still says OK and it doesn't show a '+' underneath.
BMW seem to let it get down 1 litre then top it right up.
But whilst it may be 'OK' I think I'd be sticking about a 1/4l in and seeing what it does. Better to be full surely?
topping up oil
What fredej says. There is a lot of oil in these cars (>6 litres), so being down 1/4 litre won’t do it any harm, however overfilling it may do.
You need to fill up with petrol instead, that’s looking dangerously low
2003 Maldives Blue 3.0i auto
- rjhl64
topping up oil
Roundtrip of 150 miles and the petrol light came on 2 miles from home , Next outing via petrol station, once I've dripped some oil into the engine
topping up oil
It says: Oil OK - leave it alone!
topping up oil
I would not add any oil at this point, too likely to overfill and cause an issue within the engine. There is no way of telling if this is a linear scale or not, so why risk it when the engine is still happy with more than enough oil? (just my opinion)
Montego blue 2006 BMW Z4 coupe 3.0si with black interior, ZHP, Whippy, 12mm front/16mm rear spacers on BBS 108's wrapped in Michelin PS4's. :driving:Brand new Pierburg water pump fitted at 101k after failure (should have done it at 100k)
- Dark Diggler
topping up oil
It bleeps and the yellow oil light comes on while you are driving as well as it showing add 1 ltr on the display, it does it again when you switch off. I would wait till then to add what it suggests. The manual says add 1 ltr within 125 miles so it’s a fairly early warning.
- Rucky
topping up oil
I recently added 0.6l when the indicator was 3 bars down 3 X 200ml. The indicator did not respond straightaway at idle but a check with the car at speed it was back to "full" ok.
First top up since oil change last July. I topped it off as it is very hot. Getting changed again next month. I actually prefer a dipstick, my X5 still has one as well as electronic. I think the electronic version is for people who probably don't care anyway and couldn't find a dipstick if it poked them in the eye!
04 2.5i Titan silver - 1st Z4 now sold on
07 3.0si Silver Grey M Sport pak.
X5 and assorted motorbikes
