i'm still sure its a wire break in that loom from the front of roof to the loom disappearing into the motor area- purely as when I move the loom, the issue goes away (assume I am rejoining the break in the wire)Number5 wrote: ↑Sat May 29, 2021 5:38 pmAs a quick simple check and elimination, I'd first swap the ports and polarity over to see if the problem moves from going up to dropping downJas- USA wrote: ↑Sat May 29, 2021 5:22 pm Your hinge lifters are failing. The top will come down but, your system no longer has the need pressure to raise the weight of the top.
Note: Although unusual, your emergency by-pass system within the pump could also be stuck half open.
Both failing hinge lifters or a stuck half open emergency by-pass can cause a loss in pressure need to raise the top of a Z4.
This video has a long winded beginning. However, the guy in the video shows the hinge lifter issue which effected his Z4.
https://www.youtube.com/watch?v=ecfkS5NDa0U&t=37s
I've got Mark Plants INPA to run some tests to see what codes are thrown and if its an open circuit but I am fairly convinced
