New Owner
- Mr Tidy
New Owner
I think you may well have pressed the button without realising.
The OBC screen on my E90 has 4 displays, average MPH, average MPG, fuel range and a blank one! But then time and outside temperature are pemanently displayed above that screen.
My E86 doesn't have a blank screen in the OBC, but you need to scroll through the options to get the time or outside temperature.
E89s being newer than E85/86s may well have more in common with my E90, but hopefully someone with an E89 can confirm. Failing that go out and try it tomorrow!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- mr.tourette
New Owner
Yep, ive changed the obc display a few times while using the Indicator, kinda inevitable it will happen from time to time with the position
- Ole gits rule
New Owner
Mr Tidy has given the correct info - three sets of info average speed / average MPG and instant mpg plus a blank one for some unknown reason
Time and temp above.
M4 Vert in Yas Marina Blue
New Owner
Cheers guys,
That’s reassuring to know
- Ole gits rule
New Owner
I think press and hold for 3 secs and it resets.
New Owner
So it’s definitely a case of fat finger syndrome & being over sensitive with indicating in the new car!
Another question … sorry!
I live under a couple of trees & assume that the roof needs to be completely clear of leaves to retract properly?
What do people recommend?
I assume a brush (as in dustpan and) with really soft bristles?
Thanks for your help so far guys
- tiglon
New Owner
The display will also flash up with miles remaining when you get low on fuel, I think at 60 and 30 miles remaining, so it could have just been that.
Worth mentioning that my manual warns against letting fuel regularly go below 30 miles remaining as it may cause damage (can't remember the exact wording). But, that may be engine specific because the 35i/35iS with the N54 engine are well known for fuel pump failures.
I would be very careful using a brush on the bodywork, I'd want something as soft as a paint brush. To be honest I would probably just use my hands.
2014 E89 35is Valencia Orange 788M wheels (M2 Competition), E90 M3 control arms, Eibach Pro Kit Springs, MHD Stage 1
- Smartbear
New Owner
Hi, scrolling through the obc functions brings a blank screen - just press again
The missing screw covers are normally found under the seat, i put a splodge of silicone on mine to stop the cycle
e85 3.0si sold
New Owner
I think the paintbrush is an excellent suggestion
There is just no way of avoiding leafs on our drive & the last thing I want is to bugger up the roof mechanism
Good job I own a Karcher as well as I need if for the other cars on the drive
