Oil Catch Can on N20
sumotan
Post by sumotan » Sat Apr 03, 2021 4:45 pm
Hi Guys,
Has anoyone installed the above ? Was think it might help minimize carbon build up in a log run.
Pbondar
Post by Pbondar » Sat Apr 03, 2021 6:30 pm
The N20 had a much cleverer oil mist minimisation strategy then its predecessors and a better recovery system...I looked at in detail and even on opening up the intakes found at 50k miles little to note when compared to say the N54s..
sumotan
Post by sumotan » Sun Apr 04, 2021 4:36 pm
Aaaaah as always many thanks Pete.
mcbutler
Post by mcbutler » Tue Apr 06, 2021 5:31 pm
Not required unless the engine is direct injection
Mark
Plymouth
E89
35i
Carmine Red
Black leather
sumotan
Post by sumotan » Thu Apr 08, 2021 5:56 am
It is direct injection Mcbutler
fader
Post by fader » Wed Aug 18, 2021 7:00 pm
Hello, I used the BMS Turbo dual baffle N20 oil tank to install, but the bms bracket is not suitable for e89 z4 and requires a DIY bracket. The following is my installation location and pictures I hope to help you.
Z4 20i Msport | BMS JB4 Tuner | BMS Oil Catch | JB4 Universal Water Injection WMI Kit | Quaife ATB LSD | J-Fiber Dry Carbon Driveshaft | Michelin Pilot Sport 4 S |
GuidoK
Post by GuidoK » Wed Aug 18, 2021 7:35 pm
I have a chinese clone of that BMS catch can in my car.
Costs about £20 on alie.
https://www.aliexpress.com/item/1005003117163545.html
But there are also other not so big ones for sale that are quite nice.
I don't think that there's a plug&play fit option for the e89, you have to make some sort of bracket.
