SmartTop alternative
- ronk
Sorry, that’s what I meant to say - using remote with engine running! I was Just about to post the message!
- Ole gits rule
Yeah I understood Ron, will give it a try later but I did have the warning on the screen excessive battery usage or something along those lines.
M4 Vert in Yas Marina Blue
- ronk
I seem to remember way back when someone had problems with the unit when the plugs were not fully and properly seated - the engine running will eliminate this and steer you towards a low / poor battery.
- Ole gits rule
Ok - will take a look later this evening - think it could be the battery, hope so or it is take everything apart again
- Argyll Andy
Depending on what charger you bought could be worth doing a recondition and charge first time roundOle gits rule wrote: ↑Fri Jan 22, 2021 3:58 pm Yeah I understood Ron, will give it a try later but I did have the warning on the screen excessive battery usage or something along those lines.
G29 M40i Thundernight with Ivory interior, all option packs (here for a while, hopefully )
E89 23i sDrive, Silver (Gone)
- Ole gits rule
Bought a smart charger so should be able to do that - sounds a sensible thing to do as well Andy
- Ole gits rule
On charge - well in repair mode anyway
- Argyll Andy
Excellent, hopefully do the job
- Ole gits rule
Hope so, the charger said it was fully charged but I have the excessive battery discharge warning when trying to open the top with the remote
- ronk
Did you fire it up and try it ?
- Ole gits rule
Not yet - its still 0 down here so not moving the roof unless it is slightly warmer - had the charger on here for 4 hours so hopefully its going to work.
- ronk
- Ole gits rule
Looks like we got a shed load of snow due as well so may have to wait until next week - may take it into work and put it into the unit and try it there
- ronk
A good run won’t do the battery any harm either
- Ole gits rule
Did 100 miles yesterday, had to do my days penance in the office - trouble is dark on the way in and way home
