SmartTop alternative
- ronk
The alternator churns out 100 Amps so there will have been more going in than out - even with headlights etc
- Ole gits rule
Well time I got home was late / wet so I left it but will most certainly get the charger back on there tomorrow if the weather permits.
Need to sort the program as well as I am not happy with the door settings
M4 Vert in Yas Marina Blue
- ronk
Mine is set to Unlock at ign Off - I’ve found this saves the two pull to open situation.
- Ole gits rule
Yes that is how I have set it but on opening only the drivers door unlocks initially, where as I want them both to unlock on the key
- Ole gits rule
After charging and reconditioning the Battery on Sat, the snow has finally gone so tested the roof operation using the fob and now it works fine for both open and close - happy days
- Argyll Andy
ResultOle gits rule wrote: ↑Tue Jan 26, 2021 11:16 pm After charging and reconditioning the Battery on Sat, the snow has finally gone so tested the roof operation using the fob and now it works fine for both open and close - happy days
G29 M40i Thundernight with Ivory interior, all option packs (here for a while, hopefully )
E89 23i sDrive, Silver (Gone)
- Ole gits rule
Yep - £22 for a smart charger and about four hours on charge and all sorted, not getting the old car on lamp warning now either
Got that thing now for the other 5 cars on the drive
- ronk
A good simple result!
- Ole gits rule
Certainly was cheap and better than a new battery
a newbie question - is this a smarttop function too? even the locking above certain speed or do I have to have that coded in? and have you sorted out the unlocking of both doors? thank you!Ole gits rule wrote: ↑Sun Jan 24, 2021 10:29 am Yes that is how I have set it but on opening only the drivers door unlocks initially, where as I want them both to unlock on the key
2009 E89 SDrive35i
Yup its all configurable. The Smarttop manual can be found here: http://www.mods4cars.com/sms/db/smartto ... 2.2/en.php
strange, I can't attach a PDF on this forum. I wonder why?
- Ole gits rule
Clarker is correct, both mine open on the keySnowii wrote: ↑Wed Jul 20, 2022 11:21 ama newbie question - is this a smarttop function too? even the locking above certain speed or do I have to have that coded in? and have you sorted out the unlocking of both doors? thank you!Ole gits rule wrote: ↑Sun Jan 24, 2021 10:29 am Yes that is how I have set it but on opening only the drivers door unlocks initially, where as I want them both to unlock on the key
great, thanks guys... seems like there is no point to search or even consider anything else instead the SmartTop, is there? (as attempted to discuss in this thread somewhere)
2009 E89 SDrive35i
- ronk
The Smarttop is expensive but if works!
When / if you sell your car, you will easily sell the device and recoup a huge chunk of your outlay
Buy a used unit and you’ll get all of your cash back!
Roadster Bags are a similar buy and resale commodity
