SmartTop alternative
- Nanu
Keyless start was not available I think when I bought mine in 2014, hence it has comfort access which is all part of the comfort package but does not include the keyless entry.
G29 M30i M Sport San Francisco Red
Previous
E89 35is Valencia Orange
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
- Stevo1987
Try reading the info from the link I posted.
2014 Z4 e89 35is in mineral grey.
2012 Audi TTS in Ibis white.
- Stevo1987
Comfort pack and comfort access are two different things.
- Nanu
Looks like I am mixing up comfort pack with comfort access. Either way, wouldn't want it.
Previous
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
- Ole gits rule
Smart Top now fitted, wing mirrors now closing on the key, which is really good
One touch roof operation functioning off the internal buttons
The key fob function is not working so will be hooking up the laptop tomorrow to check that out - quick question, if the battery is struggling will this stop the roof woking off the key?
OGR
OGR
M4 Vert in Yas Marina Blue
- Chippie
That could well be the problem as it won’t work off the key if the battery is discharged without the smart topOle gits rule wrote: ↑Sat Jan 16, 2021 6:59 pm The key fob function is not working so will be hooking up the laptop tomorrow to check that out - quick question, if the battery is struggling will this stop the roof woking off the key?
- mr.tourette
Possibly..although it could be disabled in the software
- Ole gits rule
Cheers Chippie,
The car starts and runs fine, however, as the car is not used regularly the old car on ramp symbol appears every now and then especially on dark cold morning, today when I went out at 11 the symbol was not showing.
May put the batt charger on it tomorrow if it is fine (no garage) and see if I can boost the battery
- Argyll Andy
Me neither, I use one of these outdoor boxes for Xmas decorations, of course depends where the car is in proximity to the house, not going to work if you live three floors upOle gits rule wrote: ↑Sat Jan 16, 2021 7:14 pm May put the batt charger on it tomorrow if it is fine (no garage) and see if I can boost the battery
- 0FFC4529-0F42-48EA-A1F8-A662DBFA3E95.jpeg (229.39 KiB) Viewed 462 times
G29 M40i Thundernight with Ivory interior, all option packs (here for a while, hopefully )
E89 23i sDrive, Silver (Gone)
- Ole gits rule
I think I can get one of them, can get very close to the sun room / study and run a cable out, do you use a trickle charger on the car and leave it running all the time?
- Argyll Andy
Yes, it’s on a CTEK when I’m not using it as it’s not my daily.Ole gits rule wrote: ↑Sat Jan 16, 2021 9:13 pm I think I can get one of them, can get very close to the sun room / study and run a cable out, do you use a trickle charger on the car and leave it running all the time?
I got a mate to pop an outdoor waterproof socket outside so I don’t need to have a window open. He just ran a spur through the wall off of the existing sockets.
I use an outside extension cable into the box, plug the charger into the box it and it sits under the bonnet. You can just see the charger cable at 10 o’clock on the tyre. The charger sits in the void behind the headlight so the car is all locked up, alarmed and secure
- Ole gits rule
[/quote]
Cheers Andy, will run a similar set up as mine is not used daily, maybe once or twice a week at most and then only short runs at the moment.
[/quote]
- ronk
My smart charger goes on a maintenance charge at the end of October until April and sits at 13.6volts
The mains cable goes under the bonnet in the headlight area and the charger and LoVo cables connect away from the wet without a problem.
- Ole gits rule
Going to get this sorted, my boy can rig the electrics and get most of the bits from work
- Argyll Andy
Definitely cheaper than a battery replacement, especially with the added bonus of no electrician fees for parts or labourOle gits rule wrote: ↑Sat Jan 16, 2021 9:33 pmGoing to get this sorted, my boy can rig the electrics and get most of the bits from work
