Beam deflectors- RHD/LHD? Whats correct?
bigwinn
Post by bigwinn » Sat Oct 17, 2020 7:11 pm
I'm sure someone will point to a manual somewhere- when I disassembled my headlights today I noticed a lever on the projector lens rear- is this a way of moving the beam pattern when driving on the left from right side of the road (or vice-versa)?
Never seen it before
Arrowed in picture
More importantly- which way should they be for us driving on the left<<<???
Because one of mine was up, one down! Assume they should both be the same?
E30 325i Touring
E85 2.2i SE
F31 330d
kis
Post by kis » Sun Oct 18, 2020 12:17 am
I’m sure the tab should be down on both sides.
Having it in the up position blocks some light on the left hand side of the light output, this would be when you’re on the opposite side of the road as to not dazzle standard LHD drivers.
That’s from memory! So let’s wait for a second opinion! :D
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
bigwinn
Post by bigwinn » Sun Oct 18, 2020 9:06 am
Resurrecting an old thread here- still not 100% conclusive but I’ll have a look in the manual
viewtopic.php?f=2&t=6150&start=45
E30 325i Touring
E85 2.2i SE
F31 330d
Chris_D
Post by Chris_D » Sun Oct 18, 2020 11:12 am
Lever UP position for normal UK driving.
lever DOWN when driving on the continent.
Note that my RHD car has been imported into NL and my headlights are permanently converted for driving in EU / rght side of the road with LHD lenses. The baffles are therefore on the left side of the lens looking forward. UK lens baffles are on the right side looking forward.
Lever UP lowers the beam baffle
Lever DOWN raises the baffle.
bigwinn
Post by bigwinn » Sun Oct 18, 2020 1:34 pm
Cheers Chris
Had a play this am and I agree- only slight changes to beam pattern but it’s there!
Thank you
E30 325i Touring
E85 2.2i SE
F31 330d
kis
Post by kis » Sun Oct 18, 2020 6:25 pm
I'll amend my post slightly, are you sure your lenses are in correctly?
They look like (transparent at the top) they will light up the horizontal line, then up into the sky? i.e. you will have no light output on the road? :?
Irrespective of which way you toggle of the beam pattern (not sure if its UP or DOWN)... for RHD vehicles, you want the "light line" to look like this:
_______
aaaaaaa\_______
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
