Audeze LCD2 Fazor Planar Magnetic headphones + balanced cable + Pelicase
One for the audiophiles here maybe.
2015 Fazor model in Bamboo, supplied in the original protective dustproof/waterproof Pelicase.
Supplied with :
Certificate of authenticity (see photo). Serial number has been protected.
SE cable
3.5mm - 1/2inch SE cable adapter
Extra Audeze 2m balanced cable
Soft headband protector
Beautiful condition with no cracks or scratches to the lovely Bamboo surround. These high-end headphones sound fantastic especially when paired with a decent source/DAC.
Minus point:
Some of the plastic laminate has started to peel from the edge of the earcushions on the thin strip between the cushion and surround but this does not affect sound quality in any way. See photos.
This is common with the original Audeze earcushions of this age.
Replacement and upgrade earcushions can be sourced easily.
Offers in the region of €1050 please.
Selling due to ridiculously uneccessary purchase of LCD4’s
Type: Over ear, open
Driver type: orthodynamic
Pads: Lambskin leather
Foldable: No
Headphone connector: 4-pin mini XLR
Cable entry: dual
Driver size: 80mm diameter, active area 65mm x 50mm
Nom. power rating: 5W (15W peak power)
Nom. voltage: 18 Vrms (32V peak power)
Nom. current: 250 mA (0.45A peak power)
Max. S.P.L. 130 dB (at 18V)
Impedance: 70 Ω
Efficiency: 93 dB/1mW (105 dB/1V)
Weight: 550 g.
Clamping force: Medium
Accessories: 3.5mm TRS to 6.3mm TRS converter, ruggedized travel case
FOR SALE Audeze LCD2 Fazor Planar Magnetic headphones + balanced cable + Pelicase
- Chris_D
- Chris_D
- B3D5E98F-E864-4C6F-A7D4-97E6BEDD4D4A.jpeg (394.53 KiB) Viewed 580 times
