Start up problems
- [email protected]
Start up problems
Dear Z4 users.
Recently I have got problems starting my Z4 35is 2012 with MHD stage 1. The egine cranks sometimes up to 10 sec before it starts. And I can hear the egine make small missfires during idle.
When running normally I cant notice anything. Runs smooth and no missfire as can be noticed. Somtimes during heavy acceleration there seems to be a lag before the power kicks in. I now there are som common issues like the high pressure gas pump and the coils.
Have any of you other users have similar problems, if so what was your solution?
If not, what to start with?
New start plugs are ordered. Hopfully this is what I need.
Sorry for bad language, all answeras are appriciated.
BMW Z4 35is 2012 white style M313
MHD stage 1+
PiperCross airfilter
WT intercooler
Simons exhaust axelback
Else OEM
If in doubt, just flat out!!!
free direct file hosting
MHD stage 1+
WT intercooler
Else OEM
- ph001
Start up problems
Unfortunately I don’t think new spark plugs will cure your problem, but new injectors will.
- kinger
Start up problems
#2.... for injector problems
Mike
Mike
Current - E89 35is Saphire Black
Previous- E89 35i Space Grey
- Chippie
Start up problems
Isn’t long cranking a symptom of a failing high pressure fuel pump
- Smartbear
Start up problems
Get the car scanned for codes or it’s guesswork
e85 3.0si sold
- R.E92
Start up problems
Probably the high pressure fuel pump. A car will fire up with dodgy injectors and run rough but they don't usually cause long cranks.
Are there any codes if you scan with MHD?
Have any components already been changed by previous owners?
- ph001
Start up problems
....not when it runs normally once warmed up.
It causes long cranks because the cylinder bores get washed by the unburned fuel which results in low compression when you first crank it.
- Player 1
Start up problems
Long crank was the first warning I had of the fuel pump failing. Error codes would be handy but long cranking didn't throw any for me, it wasn't until developing a misfire past 60-70% throttle that any fuel pump related code appeared.
- Chippie
Start up problems
Misfire from cold is a sign of leaking fuel injectors, fuel dripping onto the spark plug directly below the injector wetting the electrode and causing the misfire
- [email protected]
Start up problems
Thanks for all answers.
Reading all answers and between the lines I assume that it is the injectors that are my problem. I will give it a go with replacing them.
So next question. What type of injectors will do its work. If the original injectors last for 25000 km I think and upgrade of those is at least some thing to think about. Are there any injectors of better quality than the OEM on the market? What are you guys using?
Next question about analyzing the problem with MHD monitor app. What should I be looking for? Is it the timing the different cylinders or what? I will for sure change all injectors, but it would be nice to know witch one is bad.
Once again, thanks and drive tastfully.
MHD stage 1+
WT intercooler
Else OEM
MHD stage 1+
WT intercooler
Else OEM
- tintoverano
Start up problems
this could get you closer
there my be different INPA function keys you have to use, but same captions
mSport 23i
Coding Help, Stubby, Remap, K&N filter, Cruise Ctrl, Reverse cam, Instrument Cluster Color, UR front brace, CDV delete, Android on CIC, Roof Module, LSD
- tintoverano
Start up problems
also https://bimmerprofs.com/diagnostics-inpa-part-4/tintoverano wrote: ↑Wed Jun 17, 2020 3:12 pm this could get you closer
mSport 23i
- ph001
Start up problems
1353 8648937-12 is the latest index 12 injector and seem reliable. They were £102 ech from a main dealer as of Jan 2018, but typically these were only used for warranty work and BMW will want to retail part number 1353 8616079-12 which is exactly the same but with a £240 price tag.
- Chippie
Start up problems
25000km doesn't seem a lot for injector/s to fail, although I have seen posts where fuel pumps have failed early, most of the problems tend to start at around 500000 miles plus[email protected] wrote: ↑Wed Jun 17, 2020 3:00 pm Thanks for all answers.
Start up problems
How many miles / km has the car done..seems implausible that a 10 year old car has done 25k Km..Chippie wrote: ↑Wed Jun 17, 2020 7:44 pm25000km doesn't seem a lot for injector/s to fail, although I have seen posts where fuel pumps have failed early, most of the problems tend to start at around 500000 miles plus[email protected] wrote: ↑Wed Jun 17, 2020 3:00 pm Thanks for all answers.
