Good point Andybutters & enuff_zed
The MOT inspection manual (link here) says exactly what enuff_zed posted.
I guess all E85 & E86 will be first used before 1st September 2009 so their headlamp washers won't be tested, irrespective of whether they have Xenons or not.
headlight washer jets
I read on loads of forums that this is the case regarding the MOT, headlamp washers and pre 2009 cars.
One of my headlamp washers leaked (a lot), where the tank would be emptied within 24 hours. So I removed the fuse, discounted the pipe work from the headlamp washer pump and then cable tied it to the FEM, and put a rubber cap with a jubilee clip on the output of the headlamp washer pump to ensure it doesn't leak.
We've got a leaker on the wife's MC.
I'm assuming it is bumper off to replace them?
Paul
Paul
2006 Imola Z4MC (wife's shopping trolley)
1990 Toyota Carina (Started as a free family heirloom, now apparently a Classic)
2016 Toyota Avensis 1.6D (yup, the *really* slow one).
2011 TDM900
1997 VFR750 project. 95% complete. Only 30% left to do.
2011 TDM900
- Mr Tidy
Hi Paul, in theory you might be able to do it by removing the cover from the headlamp access in the wheel-arch liner, but Ross at RBM had to remove the front part of the arch liner when he sorted mine.
Easier than removing the bumper though!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Thanks - I'll have a play. At least I assume why the washer tank empties and an accusing puddle appears next to the offside front wheel.
I was NOT looking forwards to taking the bumper off.
2011 TDM900
2011 TDM900
- inkey$
Bumper off is super easy and by far the most convenient way to fix the washers or fog-lights. Lots of how-to’s on YouTube to help you out too. Just make sure you get the shut-line parallel with the bonnet before you tighten up the top bolts fully.
Previously: Z3R 2.8 • E46 330i • Z4R 3.0 • Z4///MC • E90 335i • Z4///MR • Z3///MC 'Breadvan' • Z3R 2.8 • E30 325i R • Z4C • Z4R 3.0
