AVINUSA 10.25 multimedia nav system
- markplant
I wonder if that's why they have their own odb adapter to make you pay for a specific unit
- yyz_bobby
Same hve the torque app and a bt obd but its not feeding through all data at once, sometimes works great sometimes not.mac27040 wrote: ↑Sat May 23, 2020 12:06 pmNo not yet anyway, the Z4 headunit i think doesn't has canbus as it doesn't have idrive. I have the torque app but my cheap bluetooth dongle wont connect !! working on it.yyz_bobby wrote: ↑Sat May 23, 2020 10:09 am Might have asked this already Neil but are you getting any car info to that screen? MPG, range left?
I know using the BT OBD you can get some info via Torque pro but my next step, now that i got the wire out, is to see if I can get the cambus feed into my 'Joying' Unit.
- mac27040
Added Wi-fi adapter from AvinUSA today so I could get torque app working
- DFFC4161-636A-473F-A779-783D953A437E.jpeg (125.13 KiB) Viewed 1592 times
3.0i SMG Supercharged,19" CSL, AvinUSA android 10.25” screen,DSP,M6 gearknob,Coilovers,Aero F-bumper,M r-bumper,Aero skirts,Facelift front & rear lights,M sports seats,Carbon Steering wheel,Intravee,Rervese cam,Hydrographics
- mac27040
Yes its this one https://avinusa.com/torque-compatible-wifi-obd2.htmlCrazyBaptie wrote: ↑Tue Jun 02, 2020 3:09 amEnjoy reading this it looks great! Is that the wifi adaptor that plugs into the OBD port??
- mac27040
Downloaded the torque themes app which gives you 60 themes. You can also custom the colours. Here a quick updated version
- B15E98F1-FC3F-4CCD-A133-0084C360B56E.jpeg (107.26 KiB) Viewed 1543 times
- mac27040
Updated software to the new ID& theme from AvinUSA
[youtube]https://www.youtube.com/watch?v=nz7ou9dxP5s[/youtube]
- kis
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Hi bro,mac27040 wrote: ↑Tue Jun 02, 2020 9:19 am Yes its this one https://avinusa.com/torque-compatible-wifi-obd2.html
Just installing my Android Screen to my E85, could you please tell me where you pass/send the cable of the rear camera to the front?, what pieces exactly you took off please.
- mac27040
Hi,mariocaz wrote: ↑Sat Oct 10, 2020 8:19 pmHi bro,mac27040 wrote: ↑Tue Jun 02, 2020 9:19 am Yes its this one https://avinusa.com/torque-compatible-wifi-obd2.html
i already had a rear camera connected up to the old factory flip screen via the TV module in the boot, My camera is part of a numberplate surround so to install that the rear bumper had to come off so i could feed cables through one of the rubber grommets on the corner of the car. I then ran the cables through the centre below the DVD / CD changer, this requires the centre rear console to be removed, then run the cables through past the handbrake and gear selector and come up under the heater controls so i can connect into head unit. you might have to remove seats too to get the centre tunnel out.
Should it work with this version of platinumIPTV?mac27040 wrote: ↑Wed Apr 22, 2020 1:05 pm Proposed setup:
Retain: Aftermarket reversing camera in numberplate surround, Intravee & Alpine 420 unit, I need the intravee to control the triple blink & flash to pass on my car.
Install 10.25" multimedia unit, carplay and android software to talk with ODB port. install platinumIPTV apk or mirror iphone to run TV
- BumpyZ4
How big of a gap is there at the front edge?
- InkedB15E98F1-FC3F-4CCD-A133-0084C360B56E_LI.jpg (56.02 KiB) Viewed 1005 times
2003 E85 3.0i Sterling Gray
KLR 650
Diva Roadster (Kit Car)
KLR 650
- mac27040
Close up of unit on dash, no gap at front and i have cut lip off x3 base plate
- 4D4E3704-A8BB-42D4-A682-7C9E44F6898E.png (1004.77 KiB) Viewed 959 times
Looks good, which Android version did you get 9, 10 or 11?
- mac27040
mine is a PX6 android 9 but would recommend you go for snapdragon and newer android
