AVINUSA 10.25 multimedia nav system
- mac27040
Well had to cut dash and trim base plate as it’s not designed for Z4 but an X3
Not finish fitting it in just wanted to see if wiring is ok
- 63A3D504-B060-4EAC-B914-B7F19291CFAD.jpeg (104.67 KiB) Viewed 1681 times
- E6FF7DCD-7AC4-43F8-9E4E-C7601A07AF0D.jpeg (104.87 KiB) Viewed 1681 times
- 4A09CAC2-AAE4-4A01-ABD1-6529C552E2A2.jpeg (115 KiB) Viewed 1681 times
3.0i SMG Supercharged,19" CSL, AvinUSA android 10.25” screen,DSP,M6 gearknob,Coilovers,Aero F-bumper,M r-bumper,Aero skirts,Facelift front & rear lights,M sports seats,Carbon Steering wheel,Intravee,Rervese cam,Hydrographics
Onlinemarkplant
Looks a nice piece of kit
- mac27040
- mac27040
Installed now to setup
- E9A544D7-0EA3-4BE7-BAC5-ECDB0595E0A7.jpeg (107.7 KiB) Viewed 1661 times
- 3F600291-D807-43CA-B9D3-EA77DC99E62C.jpeg (102.65 KiB) Viewed 1661 times
- 7C162E55-C04A-4B2D-9FF5-C3D0DB0494EE.jpeg (99.75 KiB) Viewed 1661 times
- FC4119EE-80D1-4F85-88FA-7BA71D334BF2.jpeg (109.81 KiB) Viewed 1661 times
- CA16ADA0-0A31-4399-9C33-94FC0AA1524D.jpeg (124.56 KiB) Viewed 1661 times
- Darren Slone
Top job there I have all on changing windscreen wipers
Current Porsche Cayman S 987.1
Now sold - Imola Z4MC
Now sold - Silver Grey Z4MC
OEM CSL’s, Supersprint, Gruppe M, Eibachs, Carbon Roof, carbon rear spoiler,,
Now sold - My other Z
‘71 Datsun 240Z imported from West Coast USA
Onlinemarkplant
How much timing was involved in the end, looks a well done job
- mac27040
Took about 6 hours on Saturday, Monday about 5 hours, today about 3 hours. Still have a few small issues.
Totals about 14 hours but most was spent thinking about it and cleaning!! Could probably do it in 4-5 hours
Onlinemarkplant
Sorry Neil it should have said trimming
- mac27040
Oh about a couple of hours, doing very small alterations and keep trying it
- mac27040
Photos of trimmer areas on dash and base plate.
1. Drilled hole in leg to use as fixing point.
2. Cut cross plug back as it is not required
3. Drilled hole in leg to use as fixing point.
4. Sanded edge down as Z4 dash has slightly different contours
5. Cut front lip off
6. Not shown on pictures but remove the three metal screw plates at back edge of original hole in dash which the flip screen screws used.
7. Trimmed dash as underside of new base where screen sits is wider.
8 & 9. Cut dash for the back legs to fit. 40mm off centre, so 80mm apart. 15mm wide and approx 10-15mm deep.
10. Trimmed dash as underside of new base where screen sits is wider.
- 1DCD6F0E-19F1-47A8-BFF2-32159A1A8513.jpeg (175.14 KiB) Viewed 1595 times
- AF25D434-D7A7-40C4-BD19-467ACEFA9916.jpeg (83.81 KiB) Viewed 1595 times
- 7EAFDB6D-87C7-4AA0-889D-23CEF0789C2A.jpeg (153.38 KiB) Viewed 1595 times
- Darkangelv2
Well done Neil
Now that you’ve proven it fits, I’d be really interested as to how impressed you are by the unit itself and how well it functions?
My one concern has always been the lack of I-drive style controller - touchscreen doesn’t seem the best idea whilst driving!
BMW Z4 2006 2.5SI - 437M Wheels - Strut Brace - H&R ARBs
3.0si Brake Conversion - Custom Nappa Sport Interior - Z4M Bumper+Bonnet -
BC Racing BR Coilovers - AFE Stage 2
- mac27040
We let you know once i have it all fully up and running, I have a small issue with bluetooth setup at the moment which means i cannot connect the iphone, carplay and OBD adapter. Have emailed AVINUSA and have suggested changing settings which ill have a look at later.Darkangelv2 wrote: ↑Wed May 20, 2020 9:31 am Well done Neil
Thus once up and running steering wheel controls should work and i will be able to voice control it to a degree. The screen is massive and does sit a little high, if your short you will have visual problems seeing over it !!
- mac27040
Sorted Bluetooth just need to change factory setting.
Sorted AUX connection, replaced cheap eBay cable with one with resistors in, now have sound.
Wired up wireless charge phone holder using spare USB port from screen.
Added music to SD card
Installed Sygic offline maps app.
Just waiting on CarPlay dongle from AvinUSA
- yyz_bobby
Might have asked this already Neil but are you getting any car info to that screen? MPG, range left?
I know using the BT OBD you can get some info via Torque pro but my next step, now that i got the wire out, is to see if I can get the cambus feed into my 'Joying' Unit.
- mac27040
No not yet anyway, the Z4 headunit i think doesn't has canbus as it doesn't have idrive. I have the torque app but my cheap bluetooth dongle wont connect !! working on it.yyz_bobby wrote: ↑Sat May 23, 2020 10:09 am Might have asked this already Neil but are you getting any car info to that screen? MPG, range left?
