Yes those green pads are very low dust, a good choice.
Epic brake upgrade fail
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
You learn by doing so persevere and get it done yourself.
YouTube is your friend.
Current : 640D M Sport & F30 320D
Previous: e39 3.0i, e86 3.0i, e85 3.0i, e46 m3, mk1 Audi TT, e92 2.0D
Hmmm not sure about the dangerously wrong part.....I knew a guy that stripped his brakes, went inside for Sunday lunch, forgot to put any pads in both front sides, promptly put his car through someone’s garden wall down the road....I kid you not, he was trying his own repairs as the OP. Easily done tbh if you’ve not done brakes before and wander off halfway through.ph001 wrote: ↑Sat Apr 11, 2020 8:51 am I’m all for people having a crack at diy and it’s pretty hard to get the brakes ‘dangerously wrong’ as long as they are bled properly. I think all you needed was probably upgraded pads though as said above. Anyway, I would almost certainly say you are going to need a pressure bleeder as sometimes you just can’t get the pedal to pump the fluid through.
As for the brake hose - you just undo the flexi from the other coupling (where it joins the solid pipe) first. Then it’s dead easy and you dont need to spin the caliper around. You can buy rubber caps that fit over the exposed brake union for pence on Ebay.
It really is quite important that you don’t let the fluid drop too low in the master cylinder otherwise it’s a whole heap of hassle.
Well done for having a go but double and triple check everything Beemerguy....seriously.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- BeemerGuy
Thanks have ordered 2 litres of bmw 4 dot, and the easibleed pressure kit. The level is OK, so far so I will be especially careful of that thanks.ph001 wrote: ↑Sat Apr 11, 2020 8:51 am I’m all for people having a crack at diy and it’s pretty hard to get the brakes ‘dangerously wrong’ as long as they are bled properly. I think all you needed was probably upgraded pads though as said above. Anyway, I would almost certainly say you are going to need a pressure bleeder as sometimes you just can’t get the pedal to pump the fluid through.
I feel committed to plough on with this job, and will take my time, find a solution for the bolt, get the right carriers, and maybe change the pipes too as well as getting the rubber caps.
I like to try things, and am typically a completer finisher....so I'm sure ill get there...and safely. If I really have big doubts I wouldn't hesitate on calling someone in...
Thanks for all the constructive, sobering and also positive advice
S20i Auto Mineral Grey
Racechip GTS + App
330 front brakes, Hel SS hoses
326M Michelin PS4S
Xenon AEs
Smart Top
Black Leather Heated
Comfort Pack, Pro Media
Racechip GTS + App
326M Michelin PS4S
Xenon AEs
Smart Top
- BeemerGuy
The carrier bracket is part 34116769097. They don't look easy to source sadly.....Mr Tidy wrote: ↑Fri Apr 10, 2020 8:23 pm I'm sure I read that on the E85/86 models you need a different carrier for the calliper to get it to fit.
I think it was the same part that was fitted to E46 330 models.
So I think you will need new carriers - probably worth a look on "realoem" to check whether it is a different part to what your car has.
- SmartSelect_20200411-124208_eBay_resized.jpg (72.53 KiB) Viewed 1089 times
Racechip GTS + App
326M Michelin PS4S
Xenon AEs
Smart Top
Racechip GTS + App
326M Michelin PS4S
Xenon AEs
Smart Top
- BeemerGuy
In fact if anyone has a 2nd hand set per chance I'd be very interested, thanks.BeemerGuy wrote: ↑Sat Apr 11, 2020 12:45 pmThe carrier bracket is part 34116769097. They don't look easy to source sadly.....Mr Tidy wrote: ↑Fri Apr 10, 2020 8:23 pm I'm sure I read that on the E85/86 models you need a different carrier for the calliper to get it to fit.
Racechip GTS + App
326M Michelin PS4S
Xenon AEs
Smart Top
Racechip GTS + App
326M Michelin PS4S
Xenon AEs
Smart Top
- BeemerGuy
Ordered new ones now so please ignore last post, thanks.
Racechip GTS + App
326M Michelin PS4S
Xenon AEs
Smart Top
Racechip GTS + App
326M Michelin PS4S
Xenon AEs
Smart Top
if its a rubber brake hose...you can get a brake hose clamp tool to stop the fluid. means you only have to bleed a little air out of each one...
- BeemerGuy
Thanks...it's the metal braided type so I don't think that will work.Maybach_man wrote: ↑Wed Apr 15, 2020 9:26 am if its a rubber brake hose...you can get a brake hose clamp tool to stop the fluid. means you only have to bleed a little air out of each one...
Racechip GTS + App
326M Michelin PS4S
Xenon AEs
Smart Top
Racechip GTS + App
326M Michelin PS4S
Xenon AEs
Smart Top
- BeemerGuy
Time for an update...bit of a mechanical tale
So the saga continued until last weekend when I finally got the brakes working, tested and fully operational. MOT tomorrow!
There were a few more mishaps along the way, and it wasn't quick or cheap - I didn't really expect it would be, but I'm pleased I did it and would be much more confident in the future - many a lesson learned.
Finally new carriers arrived and I set about fully replacing the front 300mm to the 330mm disk / calliper setup. I also decided to order some new disk guard bolts (as one wasn't catching properly), new guide bolts, and new brake pad retaining clips. I also realised from more research that my issues with the brake hoses were down to me trying to loosen the calliper side and not the connection into the brake pipe first (consequently somewhat mashing the calliper side tightening male connector nut....so I ended up ordering a set of Hel braided hoses to resolve any chewed nut issues and further improve braking...
Having been struggling on with a single set of axle stands, I also decided to buy another set, to make bleeding less of a faff...various other tools were bought like torque wrench, bleed spanner, and elongated T30 torx.
I decided to spray paint the break pad retaining clips red for a bit of bling....I later decided to scrub up the OEN ones and spray pain them satin black, as the red calliper paint seemed a bit flakey….or maybe t was the quality of the clips (or not prepping them properly)..
So got the front done with not too much trouble this time, and moved on to the rears....more trouble with the parking brake...
..I tried the wind back technique from the youtube techno tutorial, winding back with a screwdriver, but there was no way that was going to work - it wasn't for budging (perhaps because the had been locked in position, even while off the car). Additionally it was very difficult to get the bracket off the electric motor/calliper...and I ended up chewing the torx bolt and having to drill it out and stamp in a bigger bit to get a catch and remove it. In the process of hammering the torx after clamping the calliper, I managed to hammer out the parking brake piston from its seal and couldn't get it back inside it's gaitor - after more research I realised it was assembled from the read not from the front and that (at that point) looked well beyond me so decided to throw more money at it, and replace the rear callipers under a core exchange...also ordered some more torx bolts.
Anyway when they arrived some weeks later, it proved a fairly straightforward task to replace both sides, and to bleed all round via an Eazibleed kit.
Overall it came together I hope, and there haven't been any leaks as far as I can tell...garage I hope will confirm all is well...as I still have a couple of doubts over how the new narrower brake hoses seat in the connection with the brake pipes...the retaining clips I think might need bulked up with an extra washer or so, but I think would only be a slight wear risk over many thousands of miles) on a non critical part of the hose (says the novice) - one to keep an eye on!
I guess there's more I could have done...maybe cleaned up the rear carriers etc. In the end I was glad just to get it done, even although it didn't really need to be
- 20200516_184842.jpg (192.82 KiB) Viewed 903 times
- 20200516_184837.jpg (222.21 KiB) Viewed 903 times
- 20200515_184446.jpg (264.76 KiB) Viewed 903 times
- 20200515_170759.jpg (148.45 KiB) Viewed 903 times
- 20200515_152744.jpg (193.36 KiB) Viewed 903 times
- 20200425_183102.jpg (164.54 KiB) Viewed 903 times
- 20200425_182016.jpg (278.43 KiB) Viewed 903 times
- 20200425_152958.jpg (203.34 KiB) Viewed 903 times
- 20200425_134257.jpg (268.56 KiB) Viewed 903 times
- 20200515_170756.jpg (193.13 KiB) Viewed 903 times
Racechip GTS + App
326M Michelin PS4S
Xenon AEs
Smart Top
Racechip GTS + App
326M Michelin PS4S
Xenon AEs
Smart Top
- Chippie
Well done you, hope all goes well with the MOT tomorrow
- Mr Tidy
OP, it's great to see that you persevered and got there in the end.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- BeemerGuy
Thanks - passed, and they said all was fine on the test and that all looked good....asked when I could start
Racechip GTS + App
326M Michelin PS4S
Xenon AEs
Smart Top
Racechip GTS + App
326M Michelin PS4S
Xenon AEs
Smart Top
- BeemerGuy
The forum was a great source of help and motivation, so thank you!
Racechip GTS + App
326M Michelin PS4S
Xenon AEs
Smart Top
Racechip GTS + App
326M Michelin PS4S
Xenon AEs
Smart Top
Hey, great job with the brakes. Currently trying to upgrade mine for the track. Where did u buy the carriers from? Cheers
