ihadablackdog
With the cars sat on the drive doing nothing except 1 food shop a week, the batteries are going to go low I think.
Havent started my Z4 for well over a week, if not two.
Started Debs 1'er yesterday to go for weekly shop and it took a few seconds to catch.
So, do I need a trickle charger or something?
I read a lot about ctek but as is usual when you dont know fcuk all about it, lots of different versions!
Both cars have start stop, hers a 2014 116d and mine a 2011 e89 20i. I think they are AGM batteries?
So, CT5 Start/Stop? Circa £80?
https://www.ctek.com/products/vehicle/ct5-start-stop
Do I need that, or is there a cheaper version just to keep them ticking over....I'm assuming I can connect to one of the cars for a few days then swap?
Deb was told her battery needed replacing by the stealer previously and when she pushed back over the price they said it was just begining to show signs of needing replacing, whatever that meant! Its been fine since. Mine normally starts ok, but the start/stop function has never worked in the 2yrs I've had the car. Do a 26mile round trip to work each day (obviously not at the moment), so dont know if that would be enough to keep it topped up.
Both might need replacing, but not going to do that at the moment, hence looking for an alternative solution, and even with a new battery i'd still need to keep it topped up.
Yes that does smack of laziness...............on my part Rob
