N54 engine ownership guide
- scootr
This is a good collection of information by FCP that every N54 owner should read.
https://blog.fcpeuro.com/the-definitive ... i=82049447
E89 3.0L 6 MT gone
Michelin P4s
Bilstein struts & shocks
Luxon tower brace
Michelin P4s
Luxon tower brace
Good read.
I get codes for the HPFP and turbo actuator on the wifes 335i
Looks like an invoice coming.
Current - Z4 MC, M3 CSL, S54 Z3MR, Z1.
Thanks. Helpful guidance on what to keep an eye on.
There are some common issues with the N20 versions too..
Cam box and gasket
Water pump
Oil changes
Oil Cooler and gasket
Cam box and gasket
Water pump
Oil changes
- Smartbear
I’ve not read of anyone changing a water pump on an n20 yet, I’m presuming it’s equally as simple as the n52 is?
e85 3.0si sold
"BMW recommends walnut shell blasting the intake valves every 40,000 miles."
No, they don't.
Vidi, vici, veni
- Smartbear
What do bmw recommend to combat the carbon build up Buster?
e85 3.0si sold
I don't know, Rob. I do know, though, that they don't recommend walnut shell blasting or snake oil massage.
Vidi, vici, veni
In all seriousness, Rob, walnut blasting can cause significant damage if the debris left from the process is not completely removed.
Even a little walnut 'grit' left in the engine will do a damn sight more damage than any carbon it's used to remove.
Vidi, vici, veni
- Smartbear
That’s surprising, i would have thought the engine could ingest the walnut shell without harm?
e85 3.0si sold
Apparently not, which, considering its function as an abrasive, is perhaps not surprising.
Anyways, I ain't lettin' none o' those techie folks put any nutty bits in my car.
Vidi, vici, veni
- enzed4
Denial
Seriously, a quick search found many references to BMW dealers carrying out this service. I read that to mean it is BMW approved/recommended. So I'm not sure why Busterboo says it's not approved. Unless he just meant 40,000mi is not the BMW recommendation? Hard to tell. I found one reference that said BMW recommends 30,000mi but it wasn't on a BMW website so I wouldn't take it as gospel.
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
By "dealers" do you mean dealers who sell used BMWs? Or ADs - dealers authorised by BMW to import & sell new cars?
Vidi, vici, veni
- Smartbear
Walnut shell is only a harder medium than the carbon deposits though, it’s not as hard as the steel & alloy within the combustion chamber. After all when it’s blasted into the intake ports it doesn’t harm the valves or port in anyway does it?Busterboo wrote: ↑Wed Jan 22, 2020 1:14 amApparently not, which, considering its function as an abrasive, is perhaps not surprising.
e85 3.0si sold
