It isn't that hard to do but you do need a little skill with soldering. My soldering skills aren't the best, I managed to get it done but I wouldn't feel comfortable doing this for someone else. As you say if you are not comfortable with soldering best to pay a little and farm the job out. The end result though is 100% worth it.Timmyboybunter wrote: ↑Fri Apr 17, 2020 9:35 am Wow, that looks fantastic. It's one of the few things that bugs me about both the Zeds I've owned was the orange lit dashboard, just makes it look dated in my opinion.
How hard was this to do? I'm not sure my sausage fingers are to be trusted with soldering etc (but it may be something AnubisZed adds to his mod service menu perhaps?)
Edit: I've just found the guide, there's zero chance of me even thinking about doing this mod myself. May have to tempt someone with beer money.
Some More Little Mods - Racechip XLR Pedal Tuning Box
I know what you mean, I did the same had a list of things even before I got the car and now more things have been added to the list!Big Bad Boris wrote: ↑Fri Apr 17, 2020 10:03 am O lord, I’ve not even bought the car yet.... and I’m already making a list if things to do when it finally arrives!
I had a 2006 MR2, it had a orange dash lighting system, which just looked sooo dated.
The orange dash lighting isn't half as bad as the red lighting in my dad's Mazda, that really is appalling.
- Timmyboybunter
Agreed, it looks great.
I'm just about comfortable enough to solder a wire together, as long as the wire is quite thick and it's then covered by heat wrap so you can't see it so wouldn't have a go at these LED lights.
I'll perhaps give Mr Tanner a shout - he's clearly a soldering expert and likes to tinker.
2012 VW Passat 1.4 Tsi Estate
2005 Mercedes CLK 55 AMG
2015 E89 BMW Z4 sDrive35iS (sold)
2010 E89 BMW Z4 sDrive30i (sold)
2003 E85 BMW Z4 3.0 (sold)
I think I might have have found a way around the issue with the OBD port flap which is left open. Maybe something like this will work:Silverstar wrote: ↑Mon Apr 13, 2020 7:10 pm This arrived today:
It's quite a neat little gadget, you can adjust it to show various parameters such as revs, oil temp, coolant temp, voltage, turbo boost (for turbo cars) etc. plus you can get performance, braking data and error codes. It is just 3" diagonal so sits neatly in the corner of the dash and plugs into the OBD port. I managed to hide the cable behind the dash and the A pillar and then just lifted the door seal and hid it behind and tucked it behind the kick panel. Only issue is I can't close the flap for the OBD port now, so I am going to have to think about what to do there.
It looks like the bit that sticks out from the OBD port is much slimmer on that extension cable so hopefully meaning I can close the port flap and just connect the HUD unit further up the line.
This turned up the other day:
Finally managed to fit it today and wow what a difference it makes. Makes the throttle pedal so much more responsive! My first actual performance mod!
I have been looking on eBay for one these to come up for a very long time, I don't think they are worth the retail price being charged (even after fitting it, I am still off that opinion) but for £70 it's well worth it. It was a very hard job trying to buy one though, the first one I bid on the vendor deleted the sale before auction end, the second one I won for £50 the buyer failed to send it and this one third time around I finally received it! This one has the bluetooth phone app so I don't need to mount the controller making for a very clean and stealth mod!
One other thing if someone is looking for one of these boxes it doesn't have to be specifically for a Z4, any XLR box for BMW models from 2002 will fit since they all use the same connectors at the throttle pedal. This one was advertised for F20 and F30 models.
Serious question: how is that different to pressing the "sport" button, which also changes the throttle parameters?
2012 Z4 2.0 M-Sport Atacama Yellow
2000 Z3 3.0
2016 Vauxhall GTC Sunny Melon Yellow
2000 Jaguar X308 Sovereign 4.0
1969 Jensen Interceptor 6.3 litre
2000 Z3 3.0
I have seen comments saying it's no different to pressing the Sport button before but that isn't entirely true. When you press sport button sure the throttle becomes more responsive but it also changes (at least in an automatic) the shift points in the gearbox which sometimes I feel it changes at far too late and it also makes the steering artificially heavier / weightier.SV8Predator wrote: ↑Fri Nov 06, 2020 10:30 pm Serious question: how is that different to pressing the "sport" button, which also changes the throttle parameters?
With this XLR, it does not change the gearbox shift points or the weightiness of the steering. It allows you to leave the car in comfort mode but have a responsive throttle. You can adjust the responsiveness off the throttle via the rotary controller or via the app on a smartphone. Also when you are in Sport mode with XLR the throttle becomes even more responsive.
So no not the same as pressing the sport button or just pressing the accelerator harder!
- Deepseaskateboard
What is this part of the wheel called, and how much was it to spray?
I don’t know why BMW don’t do this as standard. I have seen lots of new cars with this bit looking rusted. Mine included.
Looks much better like this!
- 916AF906-8BFF-42C0-8A81-7D7379F54286.jpeg (77.08 KiB) Viewed 548 times
- Smartbear
That’s not part of the wheel - it’s the disc centre/bell or carrier depending on what type of discs you have. It’s cheaper for bmw not to spray itDeepseaskateboard wrote: ↑Sat Nov 07, 2020 12:24 amWhat is this part of the wheel called, and how much was it to spray?
e85 3.0si sold
It cost me 100€ to have that part of the discs and the brake callipers painted on all four corners.Deepseaskateboard wrote: ↑Sat Nov 07, 2020 12:24 amWhat is this part of the wheel called, and how much was it to spray?
- Deepseaskateboard
Great, it looks like a really good finish they put on it.Silverstar wrote: ↑Sat Nov 07, 2020 2:09 amIt cost me 100€ to have that part of the discs and the brake callipers painted on all four corners.Deepseaskateboard wrote: ↑Sat Nov 07, 2020 12:24 amWhat is this part of the wheel called, and how much was it to spray?
I will add it to the list!
So three years after I retrofitted the center wind deflector I finally managed to get hold of some deflectors that fit in the roll hoops. These are stupid money new and even second hand some breakers / sellers ask a fortune for them. I finally managed to pick up one side for £15 and the other for £17 off eBay, just goes to show patience pays off!
- Smartbear
After waiting all that time did they make a noticeable difference to the turbulence?
e85 3.0si sold
I haven't yet tried them with the central deflector, it is still too hot here to need it. I am not expecting them to make any difference to be honest, I just got them to complete the look rather than for functionality.
