i changed to standard and all ok. I got Sachs for all 4 of them + 4 new springs all for 1400 ( in UK)GDeth wrote: ↑Tue Oct 01, 2019 7:33 pm Any update on this?
I just found out today that my front struts are bad (leaking) and checking out the bmw adaptive m struts - about $720 each. As far as I can see, there are no non-bmw struts available. I am seriously considering going the standard strut route (although when I contacted Bilstein, they said they do not recommend it as they have not tested it and it is not supported).
adaptive suspension busted
What did you do about the alarm light?
guy did recording so that error dos not show, now no warning light that adaptive suspension is not working. All good except that with new suspension i have front of the car sitting higher than what it should, so investigating this...
Have you fitted standard springs as the M Sport which are fitted with the adaptive suspension are 10mm lower?
If you have fitted M Sport springs then it could be settlement and bedding in, otherwise have they been fitted correctly?
keving1 wrote: ↑Thu Oct 31, 2019 9:06 amHave you fitted standard springs as the M Sport which are fitted with the adaptive suspension are 10mm lower?
Its a long story, but they fitted M sprig rear and standard at front... so took few weeks to realize that garage did mistake, so i got M springs ( and yes u r correct they r 10mm lower) and had them installed yesterday in another garage, to my horror car sit again to high, it needs to be 621mm and driver side front is 631 and passenger side 635. I have no clue have they been fitted correct, garage did the work...i read somewhere that lower arms should not be tightened while car in in air...
I also had bit of problem with the rear, M spring installed, driver side sit at 600mm - and it needs to be at 609 and passenger side rear sit at 610 - i am happy with 610 as i know this 1mm dos not chnage anything... so yesterday garage inserted 10mm spring pad rear driver side ( it had 5mm pad) so this should put the car at 605mm, will measure latter on today, i am so focused at front being to high at the moment.
I have a 2011 z4 30i with adaptive M chassis... seems as though some are saying that you can get away with regular shocks (but that you have to purge the code)... is that correct and if so what is the trade off if I have adaptive in the back (they're good) but replacing the front with regular (regulars are going for $298, adaptive $677)
OnlineB21
If you are going to replace them you need to do the full set..better of with Bilstein B8s all round!Orlandovjc1 wrote: ↑Mon May 22, 2023 11:58 pm I have a 2011 z4 30i with adaptive M chassis... seems as though some are saying that you can get away with regular shocks (but that you have to purge the code)... is that correct and if so what is the trade off if I have adaptive in the back (they're good) but replacing the front with regular (regulars are going for $298, adaptive $677)
I looked at bilstein b8s but they (bilstein site) says they aren't compatible with my z4 because it was before 9/10 not after 9/10). Thanks... gonna just go with adaptive and pay the extra. Thanks.
OnlineB21
That’s cause it’s not like for like replacement
You are replacing adaptive with non adaptive and need to remove / code out the adaptive ECU system
So, broken adaptive suspension + 19" wheels + run flats = too hard.marioz4 wrote: ↑Sat Sep 14, 2019 10:38 pm ***UPDATE: Changed all springs + shocks with standard Sachs suspension, now car sit 10mm higher than with my M suspension, ride is much better even if i have 19" and run flat. M active suspension + 19' + run flat is simply to hard ride, now happy with my "new car" standard suspension
And unbroken adaptive suspension + 19" wheels + run flats + 10mm = OK.
Quite where does the improvement lie, I wonder?
Vidi, vici, veni
