Update. Unit fitted and plugged into the aux connection.
Sound quality is good from both DAB and USB (in glovebox).
Adding DAB and USB
Adding DAB and USB
- IMG_20200326_090430784~2.jpg (152.87 KiB) Viewed 2036 times
E86 Si Auto Coupe in Ruby Black.
- KevBrowne
Adding DAB and USB
Hi, am I reading this correct, the 300i has a socket to play music via usb? Thanks.Sidewaze Samm wrote: ↑Sat Aug 31, 2019 5:18 pm I have recently fitted a Pure Highway Drive Digital/300Di. It's hard-wired in, not powered from the socket, and gives a choice of three ways to connect to the head unit; FM transmitter, aux socket or via antenna input. I chose the aux socket method, as the unit provides it's own aux input capability along with USB. So I have the original head unit (standard Business CD) but with DAB radio and both USB and aux input capabilities. The only thing I don't have is bluetooth, which doesn't bother me.
- Sidewaze Samm
Adding DAB and USB
You're reading correctly - I've got a 8Gb USB stick in mine which gives me loads of tunes.KevBrowne wrote: ↑Sat Jun 27, 2020 4:24 pmHi, am I reading this correct, the 300i has a socket to play music via usb? Thanks.Sidewaze Samm wrote: ↑Sat Aug 31, 2019 5:18 pm I have recently fitted a Pure Highway Drive Digital/300Di. It's hard-wired in, not powered from the socket, and gives a choice of three ways to connect to the head unit; FM transmitter, aux socket or via antenna input. I chose the aux socket method, as the unit provides it's own aux input capability along with USB. So I have the original head unit (standard Business CD) but with DAB radio and both USB and aux input capabilities. The only thing I don't have is bluetooth, which doesn't bother me.
But you refer to 300i - not sure if there might be a difference with my 300Di...
2008 E85 3.0si
Space Grey, Dream Red New England heated Msports.
Xenons, MFSW, cruise, PDC, wind deflector.
ZHP, stubby, gloss black grilles, DLV box, gaptech, no CDV.
- KevBrowne
Adding DAB and USB
Cheers Sidewaze, I've just ordered one, well, I've ordered the Alpine version - exactly the same apart from you can change colours & it's somehow cheaper??
https://www.mister-auto.co.uk/car-acces ... R0941.html
These can be found for about £45 delivered
