BMW centre badges that work with Zito 935 wheels.
- MACK
Hi,
I fitted some Gloss Black Zito 935 wheels last week which are great but I'm having a bit of trouble getting some BMW wheel centre stickers to work with them. I can't use the proper 68mm wheel centre caps, even though I think the Zito ones are actually the same size. The issue is the wheel has a lip behind where the cap goes so the proper BMW ones don't fit.
65mm BMW wheel stickers do seem to fit perfectly size wise on the Zito wheel caps but the ones I got off Ebay were less convex in shape than the actual Zito wheel cap meaning they don't stick too well, except in the middle and protrude around the outer edge. As a result they don't look great and its only a matter of time before they peel off. I've seen others on Ebay that state they're curved or domed but I think they're talking about the front face of the sticker rather than the whole thing. Before I try one of these I know they're quite a few on here with Zito 935's and I'm wondering has anyone come up with a solution to this or any ideas what might work etc. I really dont want to use the standard "Zito" centre stickers that came with the wheels but leaving then off the wheels look a bit plain without something on the cap in the middle. It all else fails I've considered trying some 50mm wheel stickers I've seen on Ebay to see how well they work but ideally Id like to stick with the standard size 65mm stuff.
Mark
Mark
Silver 05 3.0i SE
Mods- Zito 935 Gloss Black F/L Xenons 4 Spot Clear Rear Lights Clear 3rd Brake Light M Sport E/H Seats & MFSW ZHP Carbon Dash Trims Eibachs & B4s M Spec tyre sizes 3.64 DIFF Parrot MKi9100 in ashtray Cruise MM Tips
- mr wilks
If its the same problem as I had on Veemann centres then buy a, set of eBay centres (£7/£8) & unfold the outer cap from the rear plastic that fits into wheel hub. Then sit into hub with a little clear silicone.
Obviously you wouldn't want to push hard on the centres once in but I never had any issues once fitted
Previous Zs
E86
E85
///MR
Si E85
E89 23i
Si E85
E86
3.0Si E85
///MR
35i Msport 6spd
E86
///MR
E86
35is
911 997 Carrera4
https://www.instagram.com/andy911wheels/
E86
E85
///MR
Si E85
E89 23i
Si E85
E86
3.0Si E85
///MR
35i Msport 6spd
E86
///MR
E86
35is
911 997 Carrera4
- MACK
Thanks I'll have another look at it and give that a go at the weekend, I've got a few old sets of centres here to play with.mr wilks wrote: ↑Wed Aug 14, 2019 1:04 pmIf its the same problem as I had on Veemann centres then buy a, set of eBay centres (£7/£8) & unfold the outer cap from the rear plastic that fits into wheel hub. Then sit into hub with a little clear silicone.
Obviously you wouldn't want to push hard on the centres once in but I never had any issues once fitted![]()
Silver 05 3.0i SE
- Pbondar
Hello I have the same wheels so interested how it goes..don't want anything too tacky!!MACK wrote: ↑Wed Aug 14, 2019 1:22 pmThanks I'll have another look at it and give that a go at the weekend, I've got a few old sets of centres here to play with.mr wilks wrote: ↑Wed Aug 14, 2019 1:04 pmIf its the same problem as I had on Veemann centres then buy a, set of eBay centres (£7/£8) & unfold the outer cap from the rear plastic that fits into wheel hub. Then sit into hub with a little clear silicone.
- Nictrix
I tried to put BMW centres in the Zitos but as you found they dont fit exactly and to get them all the way in broke the tabs off the centres.
I opted for domed stickers. So far they have lasted about 2 years and still look the same as when fitted.
E89 2010 23i M Sport Black with Black leather
- Pbondar
Hi where did you get the dome badges from ?
i managed to get the fake ebay £3.99 caps in my Zito 935's Mark, guess its luck of the draw how out of tolerance they are
2008 carbon Black z4 2.5i sport
2005 arkis silver E91 320d
- Nictrix
I got them from Ebay but just had a look and dont see any in 68mm size.
- MACK
I'm going to take another look at it this weekend I think (didn't get a chance last). to be honest the current ones are holding up fine, which considering they're only attached in the middle and not at the outer edges does surprise me. I keep getting told they look fine and you cant really tell they're not sitting perfectly flush with the wheel cap but my OCD on this is getting the better of me. Im going to try modding some old centres Ive got like Andy suggested and see if I can make them work, failing that its ordering some domed stickers off ebay and hoping they're a bit more concave than the current ones
Silver 05 3.0i SE
maybe use a heat gun to make them more domed? Presuming they are resin not metal?MACK wrote: ↑Thu Aug 22, 2019 8:53 pmI'm going to take another look at it this weekend I think (didn't get a chance last). to be honest the current ones are holding up fine, which considering they're only attached in the middle and not at the outer edges does surprise me. I keep getting told they look fine and you cant really tell they're not sitting perfectly flush with the wheel cap but my OCD on this is getting the better of me. Im going to try modding some old centres Ive got like Andy suggested and see if I can make them work, failing that its ordering some domed stickers off ebay and hoping they're a bit more concave than the current ones
- MACK
Unfortunately the ones I went for are thesejamie_z4 wrote: ↑Thu Aug 22, 2019 9:23 pmmaybe use a heat gun to make them more domed? Presuming they are resin not metal?MACK wrote: ↑Thu Aug 22, 2019 8:53 pmI'm going to take another look at it this weekend I think (didn't get a chance last). to be honest the current ones are holding up fine, which considering they're only attached in the middle and not at the outer edges does surprise me. I keep getting told they look fine and you cant really tell they're not sitting perfectly flush with the wheel cap but my OCD on this is getting the better of me. Im going to try modding some old centres Ive got like Andy suggested and see if I can make them work, failing that its ordering some domed stickers off ebay and hoping they're a bit more concave than the current ones
https://www.ebay.co.uk/itm/4-x-65mm-Car ... 2749.l2649
says there 3D aluminum steel sticker so I think I'm knackered there!
Silver 05 3.0i SE
