a strange thing
road warrior
a strange thing
Post by road warrior » Wed Aug 14, 2019 9:32 am
For many years i have put 5-30 oil in my fiat ducato motorhome , this year i was advised to put in 5-40 as it goes abroad, while checking the spec of the offered oil i noticed it was also ll04 so made a mental note of this and did the oil change.
Imagine my shock to find that my mpg dropped immediately by 5 mpg from a healthy 33 mpg to a maximum of 28 now.
the motorhome is taxed to 3850 kg so no lightweight like a zed, but it must affect it. Before you ask nothing has been changed in any way it also made no discernible difference whether the ac was on or off.
I cannot imagine that this oil was in any way different to another 5-40 to affect such a huge swing. This of course is immensely annoying to me and my wallet as in a couple of weeks it will be doing couple of thousand miles. I considered doing another oil change back to 5-30 but this would cost roughly the same as doing nothing and taking the fuel hit, and besides I'm curious to see if anything changes on the continent in warmer weather.
If you ever think I'm off my rocker.. Just put me back in it and walk away... It's the kindest thing
My wife says I never listen - or something like that.
Mean Steve - makes a sound like a bear with his nuts in a trap.
Keith96
a strange thing
Post by Keith96 » Wed Aug 14, 2019 10:45 am
I’m sure you know this already but the W in the oil description, in your case 5w30, means winter. This is all to do with the viscosity of the oil. So the idea is to reduce the viscosity of the oil in low temperatures and increase it in high temperatures. 5w30 is used in temperature from -25°C to 25°C and 5w40 from -25°C to 35°C.
With this in mind it may or may not explain your predicament. Did you get this mpg running the camper at optimal temperature?
Online
buzyg
a strange thing
Post by buzyg » Wed Aug 14, 2019 5:19 pm
33 down to 28 is a big difference. Are you sure there are not other factors at work here. :?
Chris_D
a strange thing
Post by Chris_D » Wed Aug 14, 2019 7:53 pm
Did you put on some weight?
Come on now, tell the truth :poke:
:lol:
road warrior
a strange thing
Post by road warrior » Wed Aug 14, 2019 9:26 pm
:lol:
wot - in a day ?? :rofl:
Mr Tidy
a strange thing
Post by Mr Tidy » Wed Aug 14, 2019 9:28 pm
Maybe you've got a stowaway or two on board? :lol:
Coupes because stunning!
Current - Silver Grey MC, Imola Red heated Nappa & carbon trim. H & R Coil-overs, CSL Reps, Strut brace, Nav, cup-holders, DSP Hi-Fi, pdc, cruise, MFSW. E90 330i daily
Gone - Montego Blue
Gone - Ruby Black
road warrior
a strange thing
Post by road warrior » Wed Aug 14, 2019 9:30 pm
yes im sure otherwise i would not have mentioned it
Keith96
a strange thing
Post by Keith96 » Wed Aug 14, 2019 9:44 pm
Was it running at top temperature???
firebobby
a strange thing
Post by firebobby » Wed Aug 14, 2019 10:18 pm
:worthless:
You know the rules by now :poke: :wink:
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
road warrior
a strange thing
Post by road warrior » Wed Aug 14, 2019 10:20 pm
based on your figures you cant run 5-30 in the uk - presumably you park up your car when the sun comes out :)
road warrior
a strange thing
Post by road warrior » Wed Aug 14, 2019 10:21 pm
:worthless:
what- you want a pic of my van ?
Keith96
a strange thing
Post by Keith96 » Wed Aug 14, 2019 10:41 pm
http://www.differencebetween.net/object ... -and-5w40/
Here is a bit of reading for you. Maybe when you are asking for advice it would be good manners not to jump all over the people willing to take the time to assist.
patriot66
a strange thing
Post by patriot66 » Wed Aug 14, 2019 11:15 pm
Did you leave the handbrake on ? :D
'03 Sterling Grey 2.5i SE / SMG / Matching Hardtop / Gloss Black MV3s / Bilstein B4s / DLV Backbox / Carbon-wrapped Interior Trim / Re-Covered Steering Wheel / De-tango'd !
NickDE
a strange thing
Post by NickDE » Wed Aug 14, 2019 11:17 pm
The key bit from the link is
"Both oils are 5 grade when cold, but 5w30 is 30 grade, and 5w40 40 grade at operating temperatures. 5w40 with higher temperatures in summer has a higher viscosity than 5w30, which contributes to uninterrupted functioning of the motor".
So when the engine is cold, on a cold winter morning, both oils are pretty much the same from a viscosity viewpoint. When your engine is hot (whatever the outside temperature, the cooling system is thermostatically controlled to hit and maintain an optimal temperature) the 30 oil is thinner than the 40. Good if you want to save fuel, bad if you want to protect an older engine.
Darkness gone, go Darknes2, go Frozen, go Tronic
road warrior
a strange thing
Post by road warrior » Thu Aug 15, 2019 12:34 am
Oh don't be so po faced, it was a lighthearted comment, moreover I'm not asking for advise. This post is more an observation shared. Try not to look for insults where none exist. Lighten up will ya? I mean thanks for posting but let's not get too serious here.
Last edited by road warrior on Thu Aug 15, 2019 12:40 am, edited 2 times in total.
