Sounds like BS to me... that's not going to make them 5x the cash for the same amount of work, is it?
Coding a secondhand Airbag ECU, can anyone help please?
- Worcester_spoon
I had the same issue last year. 4 months of research and this ended up being my only option. Hard to swallow, but is what it is I guess.
03 Z4R 3.0i/Silver/custom quad/330d brake upgrade/LSD/G-Power supercharger/FIC 365cc injectors/Severn Tuning map
- R60BBA
Get a second hand module and code it mate.
Also would be grateful for a response to my previous question...
Current: 2002 E46 M3
Current: 2005 997 Carrera S
Gone: 2004 R53 Cooper S
Gone: 1998 E31 840Ci Sport
Gone: 2007 Z4 E86 3.0Si Sport
Gone: 2015 F21 116d M Sport
Ecu died because the top was left down in heavy rain. Bought a second hand ecu for £50 but couldn't find anywhere that could code it. Tried crash data, tried two independents one of which was a BMW specialist and then finally the dealership. None were able to overwrite the coding.
Is the ecu the one that is in the centre console? The control module?
Z4 3.0i Auto Black Sapphire - Dream Red Oregon - Wind Deflector/Isofix/Seat Heating/Xenon/TV/BT/Prof Carver/Elec Fold Ext Mirrors/Grad Tint WindScreen/Auto Dim Int & Ext/ Storage Comp Pack/PDC/CC/Nav Sys Prof/6 CD Changer/DDC/Chrome Line Int etc etc
Reopening this thread.mac27040 wrote: ↑Fri Feb 22, 2019 11:52 am found this on the internet:
Step by Step to edit VIN, Flash, Code to Default, Clear Errors and Start System Time of the Airbag Gateway Module.
INPA: UIF (User Information Field) Report
1-Open INPA>select your car model (E60)>Functional Jobs>F3 UIF
2-You'll see a list of all control units with their ZUSB number and VIN
3-Print to PDF the report.
4-Identify the ZUSB numbers without your VIN and copy from the PDF and close INPA
I too need to code the VIN in a secondhand SBSR satellite pillar module.
My car is a 2004 2.5i e85.
I'm stuck on step 1 above. I have INPA 5.0.6 and when I select car model E85, Functional Jobs is not an option like it is for some of the other models, e.g., E60, E65, etc. So I choose IDENT / read-clear error/info memory e85 instead. But then <F3> UIF is not an option, again like it is for some other models.
How can I determine the ZUSB (or Assembly Number) for my SBSR85 module?
2004 Z4 2.5i
2006 Z4 M Roadster
2017 X1 xDrive28i
2006 Z4 M Roadster
2017 X1 xDrive28i
- TomR
I did this on my car a while ago and updated the guide to make it a bit more suitable for the e85:
viewtopic.php?f=3&t=115539
Hopefully that will help
- Sidewaze Samm
Don't know about 'safety' ecu, but my understanding is dealers can't overwrite anything with INPA anyway - much more profit in selling a new unit. To overwrite modules I think you need a specialist with INPA+. But I may be wrong...
2008 E85 3.0si
Space Grey, Dream Red New England heated Msports.
Xenons, MFSW, cruise, PDC, wind deflector.
ZHP, stubby, gloss black grilles, DLV box, gaptech, no CDV.
- kis
I had problems as well.
I've added my experience to this one: viewtopic.php?f=3&t=37521
So possibly read the last post, then if you feel brave, follow this thread:
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- Ewazix
Sounds like a dealer
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
Well I finally got the airbag light sorted last night. Thanks to all for the replies. I agree with a previous post that it's 'weird' not seeing the airbag light on.
The write up and google doc resources provided by TomR were a HUGE help. By looking thought the .HIS files, I finally figured out that the ECU family that I needed to use was SBR264, not SBSR85 which is what shows up in INPA and ISTA. Also, it was good to confirm that the ZUSB number is actually just the part number. There are varying opinions about that, which I've read, and since the e85 doesn't have the UIF <F3> feature in INPA to provide the nice table like you see for other models, it was very confusing until reading TomR's write-up.
I want to note that in WinKFP, when performing the update, I chose 'unverbalt' (unspoiled) versus the dash ' - ' Those were my only two options. I was not sure this was the right thing to do since I replaced my original part with a used SBSR module, but it worked. So may want to clarify that part of the write-up.
Now the car is ready for safety inspection!
Regards, Tom
Regards, Tom
2004 Z4 2.5i
2006 Z4 M Roadster
2017 X1 xDrive28i
2006 Z4 M Roadster
2017 X1 xDrive28i
- TomR
Good job, gld you got it working
I'm going through the same issue right now with my 2004 2.5 with the right door module 6939763. The original module was timing out and throwing an error. Replaced with a second hand module with the same number but now receive incorrect chassis number fault. I can't find 6939763 in any of the .HIS files but the main module 6939810 is in the SIM85.his file. I'm not sure how to update other than trying to find older daten files, any help would be greatly appreciated.
- kis
If you’re using the same part number it will work... you just need to access the correct module and change the Vin. Can’t speak for the process as I didn’t do it personally, although it was done on my car. What programs are you using (and maybe someone else can help). Best of luck!
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
The plan was to use WinKFP but when I select comfort mode\enter ZUSB and enter the part number I get error 704, assembly identification number not found.... I do also have INPA, NCS Expert/NCS Dummy, BMW Coding Tool and Tool32. Which is the easiest to use?
Thanks for responding.
Wayne
Wayne
