19” New alloys issue, help!
Hello all,
I need help. Just taken off my MV2s with spacers and longer wheel bolts and replaced with 19” new wheels and tyres.
Firstly, fitted new wheels which have the following spec:
Front 19x8.5 offset 35. 235/35/19 tyres.
Rear 19x9.5 offset 42. 265/30/19 tyres.
re-used the long bolts
ABS light on, move car forward and back approximately 2 feet and grinding noises.
Maybe it’s the long bolts I think as some dark rust like deposit fillings have fallen on to alloy inner bottom.
Fit standard length bolts... now a clack clack noise like you got on your push bike when you put a card on it.
I don’t have a jack so ordered one but does anyone have any clues what’s up? I thought this size of wheel was supposed to fit directly on.
Cheers, Sam
Cheers, Sam
They look lovely... lol
- 9B66A25F-28D3-410A-ADC7-F85C814F63CC.jpeg (361.83 KiB) Viewed 1067 times
- 6C349D4C-4901-440C-9368-36E916845BCA.jpeg (405.92 KiB) Viewed 1067 times
- Ghostrider.1127
no 37 offset in front ?
- mr wilks
Veemann FS37s ?
I have a set in garage , yet to try on my Si coupe but fully expect them to rub
Standard bolts are fine , no need for longer ones
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo + ecu enhanced Golf R estate
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
The front offset is 35.
Why do you expect them to rub? From the research I did lots of people have fitted 19 inch wheels.mr wilks wrote: Wed Jan 09, 2019 5:59 pm Veemann FS37s ?
I have a set in garage , yet to try on my Si coupe but fully expect them to rub![]()
- mr wilks
Mine were et 35 front + rear ( no other options when i bought them ) & primarily they were / are intended for a E89 sometime in the next coming months .SamP84 wrote: Wed Jan 09, 2019 6:08 pmWhy do you expect them to rub? From the research I did lots of people have fitted 19 inch wheels.mr wilks wrote: Wed Jan 09, 2019 5:59 pm Veemann FS37s ?
My Si is lowered & front tyres are 235 35 19 Pilot sports so quite a wide fitting tyre , for Si i would have gone 225 35 fronts , rears i don't expect any issues with the 255 35 19 i have fitted
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
I bet its the long bolts rubbing on the handbrake mech...
Interesting, I will loosen off the bolts a tiny bit roll it back and forth... thanks for the heads up.
I've had exactly this before; as others have said, it'll be the long wheel bolts. No need for them anymore as you've removed the spacers right?
2007 E86 Z4MC | Sepang Bronze | 18" 260M
(Gone) 2007 E85 Z4 3.0Si Sport | Black Sapphire | 18" Style 32
(Gone) 2007 E85 2.5i SE | Sterling Grey | 17" Style 200
I’ve taken the long bolts off and put bolts with a 26mm thread on which seems a pretty standard bolt. Do I need to go down to 19mm thread, doesn’t seem a lot thread.gregl342 wrote: Wed Jan 09, 2019 11:35 pm I've had exactly this before; as others have said, it'll be the long wheel bolts. No need for them anymore as you've removed the spacers right?
- MACK
The standard bolt has a 26mm threaded section and is circa 45mm overall length including the head. If this is what you've but on stick with that.SamP84 wrote: Thu Jan 10, 2019 12:11 amI’ve taken the long bolts off and put bolts with a 26mm thread on which seems a pretty standard bolt. Do I need to go down to 19mm thread, doesn’t seem a lot thread.gregl342 wrote: Wed Jan 09, 2019 11:35 pm I've had exactly this before; as others have said, it'll be the long wheel bolts. No need for them anymore as you've removed the spacers right?
Silver 05 3.0i SE
White E89 20i M Sport
Hi Mack,MACK wrote: Thu Jan 10, 2019 11:41 amThe standard bolt has a 26mm threaded section and is circa 45mm overall length including the head. If this is what you've but on stick with that.SamP84 wrote: Thu Jan 10, 2019 12:11 amI’ve taken the long bolts off and put bolts with a 26mm thread on which seems a pretty standard bolt. Do I need to go down to 19mm thread, doesn’t seem a lot thread.gregl342 wrote: Wed Jan 09, 2019 11:35 pm I've had exactly this before; as others have said, it'll be the long wheel bolts. No need for them anymore as you've removed the spacers right?
The long bolts were replaced with the Ones below. I just don’t understand how these could be too long. Am I missing something?
- 1C9D86D8-8E19-4D27-9B31-6064D82972BB.jpeg (89.95 KiB) Viewed 901 times
Are you sure you didn't break or move something when you fitted the long ones? The noise you hear now might just be from what you did when you put the long ones in.
No idea, I didn’t put the bolts on. I will take wheels off and inspect... as soon as the jack I ordered turns up.Trav wrote: Thu Jan 10, 2019 11:55 am Are you sure you didn't break or move something when you fitted the long ones? The noise you hear now might just be from what you did when you put the long ones in.
