Vanne's lightweight/ interior modification thread
"M" Specific discussion
RedUn
Post by RedUn » Wed Dec 15, 2021 12:29 pm
Probably needs a new thread title now Vanne, you've kinda gone past the point of interior modification :rofl:
It should be Vannes race car build! 8)
IMOLA Z4///MR
Vanne
Post by Vanne » Wed Dec 15, 2021 3:51 pm
Liam, yup, well as plug and play as this whole car is.. lolol. had to fab the new mount, but aside from that, yeah, its a pretty easy install..
Red, lol, yeah i guess we crossed that line a while back.. ;)
:thumbsup:
Powered by Severn Tuning
Vanne
Post by Vanne » Tue Dec 21, 2021 11:36 pm
Finalizing some stuff today. Met with the painter, talked over a few things and requirements. No sure yet if I'll go with this guy, he's good, but bloody expensive..
Put the bottom alu crash plate on, it's part of the rigidity of the car. And then tried to fit on the nose ..
Yay guess what, another f**k up.. nose doesn't fit any more as the heat exchange unit (intercooler in hoon terminology) piping comes down about a inch and a half lower than the sway bar, so spent today moving that f***er up an inch so the nose can fit on .
I'll show you what I mean..
And then after I sorted that I had some luck with the nose..
Didn't snap a pic, but she's on properly now. Wheel is perfectly centered, so that's lucky. I do however have to cut some more of the splash guard as that still rubs on full lock.
(Not pictured is me swearing like a sailor when I found out I had to cut part of the sway bar mount, and also not pictured is me swearing like a Sydney sider trying to force the nose mount into place as the bolt is about 4mm to long for the offset of the nose. Fits, but f**k it's gonna be hard to get that off.. I'll cut the 4mm off it when I pull the nose off next time.
(No idea why this pic is last, it's supposed to be first to show you that the intercooler piping is an inch and a half to low.)
Ilogik
Post by Ilogik » Wed Dec 22, 2021 7:57 am
Nuts! This is insane
Beedub
Post by Beedub » Wed Dec 22, 2021 7:02 pm
yeah i had new intercooler pipework made up so i could run the stock undertray. expensive and PITA.
Vanne
Post by Vanne » Sat Jan 08, 2022 6:21 am
Made some headway with gauges.. added the rear diff temp gauge, wired that up finally, had the sensor installed when I replaced the crap Oem lsd with race spec diff from racingdifs.com (complete other story in itself) :evil:
Boost gauge sorted, though currently disconnected for the paint shop. And gotta clean up the dme box wiring a bit. :poke:
(Those of you with eagle eyes can probably spot the oil px wire I stripped for testing… lol amongst other modifications.. :rofl:
The race dash will run the low oil px idiot light, as the 7v Oem dash one doesn’t cut it, comes on way to late.
:thumbsup:
Random pic of boost gauge uninstalled due to dash not being installed due to car going to paintshop. :tumbleweed:
-Tom-
Post by -Tom- » Sat Jan 08, 2022 12:03 pm
This on your roads is going to look insane. A great read as always!
-Z4 M Coupe, Silver Grey, Imola Red Nappa, carbon leather, CSLs, SuperSprint Race, Track Mode Enabled
-Tesla M3 LR
Previous - 3.0 si sport roadster, Silver Grey with Oregon Pearl Grey leather, Piano black, EIbach Pro, Stubby
Vanne
Post by Vanne » Wed Jan 12, 2022 11:58 am
Thanks Tom, means a lot. :thumbsup:
Took today to sub in some steering stops, the penalty for going so low and 295 on the front is that the wheel catches the rear metal part of the inner wheel well.
So I furbished some 38mm bumpers.
:lol:
Pics attached as your probably wondering what I am on about.. lol
And then started to tidy up the electrics a bit... Lololol..
And then shot a pic to capture how low this car actually is..
1536Z4
Post by 1536Z4 » Wed Jan 12, 2022 5:49 pm
Looking forward to seeing and hearing again the finished item :evil: :thumbsup:
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
Vanne
Post by Vanne » Thu Jan 13, 2022 1:52 pm
Did a helluva lot today... Nose is finally on and it's solid.. solid as a rock..
Boost gauge isn't working properly, but will sort it.
As she sits now, very proud of all the work that has gone into it so far.. just in case your wondering.. it's a lot..
And then went and did a few burn outs.. hahaha
1536Z4
Post by 1536Z4 » Thu Jan 13, 2022 7:26 pm
Vanne wrote: Thu Jan 13, 2022 1:52 pm And then went and did a few burn outs
Looking good and appreciate how much work it has taken but you are such a tease ...........longer video please :poke: :thumbsup:
Vanne
Post by Vanne » Tue Feb 01, 2022 11:37 am
Fixing the brake ratio atm. :thumbsup:
Heading to the shed tomorrow to sort the brake pedal ratio. Boosted brakes run about 4, unboosted should be around 6. will see when i pull it out and re-drill the arm. guestimating the new hole needs to go up by about 13mm. gotta make sure the master cylinder pushrod angle does not exceed 5 degrees while setting up the ratio. divide A by B to get the ratio.
diagram below:
:thumbsup:
Vanne
Post by Vanne » Wed Feb 02, 2022 1:26 pm
Stock brake boosted z4m has a really low brake ratio.. didn't see that coming..
3.55.. normally around 4.2
We ended up at 5.2 brake ratio. Pretty choofed... Feels a s**t load better already , but have t driven it yet..
The original hole was at 90mm and I redrilled/welded the hole at 62mm
Vanne
Post by Vanne » Sun Feb 06, 2022 11:33 am
bit of a mixed report this one. spent the whole day at the shop, cleaning up some of the electrics wires and zip tied the gauges to the frame... then tidied up the rear wing a bit. then tried to start the car, batt completely dead.. had to start it as i needed to test the brakes...
used a jump starter battery to start the car.. and then fried the boost gauge... f**k!!! thats not good, not sure if it shorted out somehow due to the spike jump starter, or just something shorted itself out.. eitherway, that burned capacitor smell hung around for a bit... just ordered a new one. :( bloody expensive AEM gauges.. :(
then took the car for a drive... absolutely love it, was only a quick hoon up and down the steet in front of the shop, as cops are everywhere, and dont want to get my car impounded..
brakes work much much better.. its now possible to lock them up.. still a bit of spongy-ness in there, so ill bleed them tomorrow with the abs valves open...
car getting exhaust fitted atm... fingers crossed that goes ok :thumbsup:
RedUn
Post by RedUn » Sun Feb 06, 2022 12:45 pm
Keep it coming Vanne, proper labour of love this but the final result is going to be unbelievable :driving: 8)
IMOLA Z4///MR
