Z4M GT4
Z4M GT4
Engine rebuilt and should be fitted in the next couple of weeks. Polished and ported, Balanced bottom end. Je Pistons, Cat Cams 1301805, Emerald K6 ECU, Vanos removed. New clutch has arrived. Geoff steel airbox ordered. Tilton pedal box ordered.
- Vanne
Z4M GT4
Which pressure plate is that? did that come from turners? in the kit? if its from the kit, using stock flywheel? then no issues, if you've got the JB SM flywheel.. for the Z4m, get ready for a return.. I've never heard of CAT cams? are they custom? and gotta say Emerald k6 eco doesn't ring a bell either..
Very interested to see this all come together. hope you keep a nice picture log.
congrats on the parts and great to see another build
Just had a quick sniff around Emerald site, looks good mate and cheap too.
Powered by Severn Tuning
Z4M GT4
Cat Cams are fairly well known in the UK, perhaps not so much for BMW stuff. I think they're based in Holland. It's one of their profiles not custom. You can find the spec here.
http://www.catcams.com/products/camshaf ... UP_id=1533
- MrPT
Z4M GT4
Are you going to need to raise the max rpm to get the power you want?
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- TomK
Z4M GT4
You can get more power relatively easily, I'm up to around 380 with a fairly standard engine and bolt on stuff. To get to 400 requires removal of the vanos and some very aggressive cams as a minimum which will make it a pig to drive at low revs (remember the vanos is there to give the car more torque at low revs not more power at high revs). In either of these scenarios to get (much) more torque is not really on the cards. You need a charger of some type.Felix79 wrote: ↑Thu Feb 07, 2019 9:36 pm Is it possible to break 400bhp with an N/A build S54? I was under the impression that it's very expensive and difficult to get much more out of the unit, unless you go with forced induction?
I'm currently building up a list of things I want to do with my E85 M and while I think 343bhp is enough for me power wise, I really wish I could have about 315-325lbt from it, as I find it's current torque to be a tad lacking next to what I my Impreza P1 was pumping out with the engine turned down for reliability.
drive a (tuned) E89 35is if torque is your thing, you might like it...
- GuidoK
Z4M GT4
Belgium afaik
They have lots of interesting bmw goodies
Are you going to use that clutchplate too with a solid flywheel? I think I use the same clutchplate but I think that too is only suitable for dual mass as it has no springs (maybe thats different for full track cars but wouldnt you rather want a sintered plate?)
- BMWZ4MC
Z4M GT4
Beedub gets over 500bhp from his ///MR with (AFAIK) stock intervals. However, he has extensively upgraded the suspension, brakes etc to handle the performance available.Felix79 wrote: ↑Fri Feb 08, 2019 12:18 am Thanks for the replies Tom.
The tolerances must be insane if the engine needs a rebuild every 100 hours, but then I would guess 100 hours would be about a season's worth of racing on the engine?
I've come across some videos/threads with a supercharged S54 E85/86 M. What I can't remember is what changes were required to the engines internals? From what little I understand, BMW made sure the S54 was built using "high quality" parts for the engines internals, which means if you're using pretty low boost or aiming to just go past 400bhp and keep it less than 450bhp, you won't need to alter too much?
One big problem I faced with my Impreza P1, like so many classic shape Impreza's is the fact the 5 speed gearbox was very prone to blowing up if you took things past 350lbt. The only solution was to go with a 6 speed box, but you then had to swap a lot of the drivetrain/LSD's , which for the P1 was something you didn't want to do, as Prodrive totally changed all of this when developing the P1. They went from electronic to mechanical LSD's etc (not that it is, all that interesting for people on here to find out about). With all this in mind, how much power can the standard drive train take on the E85 M's?
My final annoying question for now is regarding the breaks. I was always told that the first thing you should upgrade on a car, before adding power, is the breaking. With my P1, I was able to get myself 6 pot Alcon calipers , that went over a 330mm 2 parts disc/hub setup from Godspeed Brakes. I then was advised to use EBC Blue'Stuff pads, which required a bit of heat in them before they would work at their full potential. They were totally amazing, as no matter how hard or much braking I was doing, they never once faded on me and I think I even managed to boil the brake fluid when me and a member from my local car club shared my car on a track day.
Cheers,
Felix
S2000 GT - gone
- BMWZ4MC
Z4M GT4
Google ESS Stage II supercharger Z4M. It comes with a software to remap the ecu. It’s on my wish list but my wife keeps finding other things (she’d say better things) on which to spend the £10k
The ///M track mode is easily programmed and well worth it. There’s a thread about it in the M section. Essentially, it disengages the traction control but keeps the stability programme running. It’s perfect for fast road use, although I prefer both TC and DSC off on the track.
Whilst you’re programming the ECU, I’d recommend switching off the dynamic brake assist too. That disengages the hugely over servoed brake response that occurs when braking immediately after lifting off the throttle.
S2000 GT - gone
