Or have it wrapped...? It's cheaper than a respray...
Hardtop on Alpina rs
- PerryGunn
Alpina Roadster S #320
* Quaife ATB LSD * StrongStrut Braces * Turner RTAB Limiters * Gap-Tech RCH+ *
* Intravee & KCA-420i * Mini 0806 * Cheetah C550 * Stubby *
How much would it cost to have it wrapped?and what is the finish like?
Oi, never mind hard tops and wraps, we need to see the car
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
Very nice, the best Z4 IMHO
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- buzyg
- Mr Tidy
+1 - I think that combo looks good.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- patriot66
IMHO the hardtop for your Alpina needs to be silver. The grey is ok but not quite right and if you had it wrapped in black I think it would jar a bit as you've no other black features/accents such as grilles or wheels to tie it all together.
The Alpina is a special car and yours looks a very original unmolested example that deserves a matching and complimenting hardtop
- kis
Hi OP mine is Titan and I’ve got a Stirling top. Check out my thread (signature) and go to the bottom of the first page. If you’re local then welcome to view? Doesn’t look quite right but still good. My Zed is a WIP. Always wanted to carbon wrap it! But we’ll see! Better than a completely random colour like blue!
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Just a word of advice to the OP. I would double check that your RS is indeed prepared for a hard top. I had a fellow RS owner come to buy my one a few years ago and just as we went to go fit it, we noticed the prep was not in place. This was a UK supplied car. I understand this was a “one off” but definitely worth checking I advance.
Thanks, I will check today, how do i know, is it fairly obvious once top down?
If I remember correctly when you drop the top there will be a locating hole behind each door shut which the hardtop pins drop into. They may be covered by a plastic cover which can be lifted off. It’s fairly obvious once the top is down.
- Marlon
Found these pics showing hardtop prep kit on bimmerfest:
Prep kit:
As Gee says, they are located under this plastic cover:
I also found what looks like a sterling grey hardtop on a Titanium silver Zed on the same thread!
Prep kit:
Gone: 3.0si 2008 E85
911 997 Carrera S
Thank you, it's a real help being on this forum.
Picked a hardtop up yesterday, sterling grey, immaculate condition with cover and fitting tool. Lining inside slightly bubbled so got it down to £400, had to travel 250miles each way to get it , but think it's a bit of a bargain!
Phil
Phil
Hardtop on, 2 mins to fit, was prepped so all good
