If they fit like that with no spacer then I suspect the rears are going to be 8.5J - look forward to finding out of curiosity!
BMW E85 and E86 Wheels and Tyres Thread
- Mr Tidy
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- mr wilks
Looking at the concave spoke design I think they could be 8j et20 off a 5 series so looking forward to seeing the numbers once removed , the fronts look different style to rears so may be a mixed set ?Mr Tidy wrote: ↑Wed Mar 11, 2020 10:42 pmIf they fit like that with no spacer then I suspect the rears are going to be 8.5J - look forward to finding out of curiosity!
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- Mr Tidy
That would make sense - they certainly seem to sit further out than I'd expect for an ET50 8.5J wheel.
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- enuff_zed
- yyz_bobby
Hi all
Need some advice
Owned my z4 E85 for 3 weeks
Currently has OEM 17" alloys and run flats. same one in my avatar pic.
Current tyre setup is:
Front: 225/45/17 and Rear: 255/40/17
First Question - why would my front tyre have lower profile than my rear? Barely noticeable when looking but curious.
I have seen a nice set of alloys for sale 18" and I think once I have these and some non RFs that my ride will be massively improved however I am concerned about whether they will fit without me having to touch spacers (not sure what these are to be fair) and/or if I need to take into consideration anything else? Eg brakes, cambers, strut? Could any of these be negatively effected?
The 18" alloys take tyres of the following measurements:
Front: 235/40/18 Rear: 255/35/18
Q1 - here the front is wider
Q1 - the tyres have a lower profile which I expect but that combined with the increase in alloy size would that still look better than what i have now?
Sorry for hijacking this thread.
Bobby
Need some advice
Bobby
- Mr Tidy
Bobby,
17" wheels are generally "square" so same rim widths front and rear, and usually same tyres sizes. But if someone fitted wider rear tyres they need to have a lower profile to maintain the rolling radius so that the speedo is accurate.
That's also why 18s run even lower profiles, although standard 18" rims are usually "staggered" so fronts are usually 8J x 18 and rears are 8.5J x 18. But the standard size for front tyres on those is 225/40 x 18.
But what you need to check is the rim sizes for both sets of wheels, including the offset, or "ET". BMW call it "IS" and it should be stamped on the wheels, usually on the rear face. The offset will determine how far out the wheels sit in the wheel-arches - spacers just sit them further out and many prefer that look.
Standard staggered 18s like MV2s and 108s are ET47 on the front and ET50 on the rear, but some other options from 3 series models and E89s will fit.
If you find all the wheel size and offset details you can see how they will fit by putting details on here:- https://www.willtheyfit.com/index.php?w ... offset2=20
Hope that is of some help.
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- yyz_bobby
Mr Tidy wrote: ↑Sun May 03, 2020 11:34 pm Bobby,
Thanks Mr T
I am currently watching youtube videos explaining Offset and ET but its nearly 12am and brain is already switched off since 6pm.
If you get the time this is the thread to the tyres I am considering:
viewtopic.php?f=7&t=121580&p=1739528#p1739528
About half way up the seller "number 5" has tried to explain the fitting. But he is the seller and wants to sell.
So if you have the time if you can read his explanation using willtheyfit.com, can you confirm or give me your advice if these will fit okay without any potential future screw up. I plan to put on some decent P Zeros non run flats on the alloys if i buy.
bobby
tyre profile relates to a percentage measurement of the tyre width not a millimetre measurement. so in your case your front tyres are a 45% profile of the 225mm width and rears are a 40% profile of 255mm width. all comes down to overall rolling diameter. What you will find is if you punch those figures into https://tiresize.com/tyre-size-calculator/ the rolling diameter front and back will be identical (this is important when looking for new wheels/tyres with +/- 3% to ensure your speedometer isn't thrown out of calibration)yyz_bobby wrote: ↑Sun May 03, 2020 11:16 pm Hi all
Need some advice
Bobby
RE the new 18s
do a quick search on http://www.bmwstylewheels.com/Z/Z4-E85+ and look up the specs (offset + width etc) of your current wheels and compare to the new wheels.
e.g. if the new wheels are the same width as your current 17s but with a lower offset then these wheels will sit that much closer to the outside of your guards.
e.g. if stock is 17x8 +40 and the new wheel is 18x8 +30 then your new wheel will protrude 10mm further outwards.
I use this online calculator to make an educated guess if wheels will fit.
https://www.1010tires.com/Tools/Wheel-Offset-Calculator
answering your question:
225/45R17 vs 235/40R18 : new tyre will be 1.72% bigger than the old so will be no issue and within tolerance
255/40R17 vs 255/35R18 : new tyre will be 0.02% smaller than the old so this setup shouldn't throw our your speedo
hope this helps!
Current:
05 Clio 182 Trophy
Gone:
02 IBP Integra Type R - Lightly Modified
06 BSM 130i - OEM+
06 PW Cooper S - OEM+
07 BSM 335i - Lightly Modified
99 Altezza RS200 Z Edition - Extensively Modified
02 WRX STI
- enuff_zed
The diagram in the other thread you refer to is pretty accurate.
Your existing set up is the orange and the new set up is the green.
From that you can see there is hardly any difference in overall diameter and the tyre will project outwards a tiny amount more.
Overall, unless you are racing, worried about perfect suspension set up etc, then these will fit and look much better.
- yyz_bobby
enuff_zed wrote: ↑Mon May 04, 2020 1:27 pm The diagram in the other thread you refer to is pretty accurate.
Great stuff.
No not racing for sure. Past that stage.
Looks like a good buy then
- yyz_bobby
Great explanation mate, took me a few reads but I kind of get it.where.is.lee wrote: ↑Mon May 04, 2020 12:38 pmtyre profile relates to a percentage measurement of the tyre width not a millimetre measurement. so in your case your front tyres are a 45% profile of the 225mm width and rears are a 40% profile of 255mm width. all comes down to overall rolling diameter. What you will find is if you punch those figures into https://tiresize.com/tyre-size-calculator/ the rolling diameter front and back will be identical (this is important when looking for new wheels/tyres with +/- 3% to ensure your speedometer isn't thrown out of calibration)yyz_bobby wrote: ↑Sun May 03, 2020 11:16 pm Hi all
Need some advice
Bobby
RE the new 18s
hope this helps!
Think I will get these now.
- AER
I wanted a rim that was more stream-line and understated than the stock 18" 3.0 sport rims so I painted everything but the face of my new rims satin black. The 225/40/18 tire on the 8" 35ET front rims brought it out 18mm from the stock 47ET looks and fits nice. The 255/35/18 tire on the 9" 30ET rear rims has brought the rim out 26mm or 1.023 inches from the stock 50ET and is cutting it VERY tight. No way a 255/40/18 would fit in the fender well. I have yet to adjust the camber and I'm concerned it will rub after I do.
- 97060380_3325286634182120_6748908869298159616_o.jpg (213.16 KiB) Viewed 4671 times
- 97376076_3325335434177240_4514835364896047104_n.jpg (56.26 KiB) Viewed 4671 times
- 97157218_3325335504177233_6150953364751384576_n.jpg (112.97 KiB) Viewed 4671 times
Past Rides:
78 320i, 79 730 5spd, 80 630csi, 83 633csi, 84 Euro M6,
87 325i convertible, 88 325i convertible, 89 635csi
Currant Rides:
88 325i convertible, 96 328is convertible, 03 Z4 3.0 M// Sport package 44k orig. miles
Currant Rides:
- yyz_bobby
Looks good!AER wrote: ↑Thu May 14, 2020 8:17 am I wanted something a little bit more understated so I painted everything but the face satin black. The 8" front rims with a 35ET from the stock 47ET looks and fits nice. The 9" rear rims with a 30ET from the stock 50ET is cutting it a little to tight. No way a 255/40/18 would fit in the fender well and I have yet to correct the camber. I'm worried I will rub after the camber adjustment.
- CHIMV8
A great post with lots of useful info. Thank you for putting in the effort to produce it.
