Which would you pick? N52 (silver engine cover) or N52k (black engine cover)
- shuey
Hey all, I will soon be buying a z4 coupe, sport.
Without going into a big debate about which is better or which is more reliable, if you could pick z4 coupe with either of the engines, which engine would you go for? Thanks peeps
M2 OG / Manual / Grey
Previous
Z4C Si Sport / Manual / Alpine White
350Z VQ35DE / Manual / Silver
Seat Leon Cupra MKII / Manual / Silver
Ford Puma 1.7
Rover 214 Si (I know!)
Previous
Ford Puma 1.7
Which would you pick? M54 or N52
you can only get a n52(or an S54) in a coupe so its kinda irrelavant really
knowing how fragile the N52 is now after owning a couple, i'd go M54 all day! The cooling system is sh1te but the actual block is a lot more reliable than the n52 in my experience.
18 Z4s owned to date.
Current: 2.5i Titan silver
- srhutch
- Moderator
I created a poll, then read it was for coupe, so as above can only get N52.
- si-forks
I think a bit of research is needed
- enzed4
Shortest poll ever
N52 it is then
N52 it is then
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
- kis
I disagree. I see it as a hypothetical question.
But agree the question should be worded better to indicate whether hypothetical or whether it’s just knowledge gap.
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- MACK
[/quote]kis wrote: ↑Wed May 02, 2018 7:29 am I disagree. I see it as a hypothetical question.
[quote=shuey post_id=<a href="tel:1538452">1538452</a> time=<a href="tel:1525222309">1525222309</a> user_id=27920]
Assuming the above and treating it as a hypothetical question then id go M54 simply for the better reliability. It's also much cheaper for parts when things do go wrong. Just compare water pump prices for example. Don't get me wrong I quite like the N52 and it's got more power and a better torque curve than the equivalent M54. It's just that when things go wrong it's much pricier to put right and they tend to go wrong more frequently. That said I would definitely still buy a 2.5/3.0 N52 engined car, as the issues it has are no where near as prevalent/plentiful as they are on it's smaller 2.0 N42/6 sibling
Silver 05 3.0i SE
White E89 20i M Sport
M54...because superchargers fit on them so nicely.
Don't just worry about the engine though. Can't speak for the facelifts but these early ones are made of cheese. Literally everything bar the engine is unbelievably weak and fragile.
MR-2 Turbo Rev2
Yep no Z yet. On the hunt.
- R60BBA
This is purely hypothetical but if I were ever to swap, these are the (BMW) engines I would install:
S50B32 (BMW’s benchmark M engine and has the best exhaust note with a proper exhaust imo)
S65 (a bit heavy and would probably upset the car’s weight distribution but is N/A and sounds epic)
S70B56 or S70/2 (V12 engine uprated and used by McLaren for their F1 cars during the 90s)
N54 (cheap and can be mapped to solid power)
N55B0T0 (Z4 with an M2 engine - dream)
Current: 2002 E46 M3
Current: 2005 997 Carrera S
Gone: 2004 R53 Cooper S
Gone: 1998 E31 840Ci Sport
Gone: 2007 Z4 E86 3.0Si Sport
Gone: 2015 F21 116d M Sport
- Marlon
N52 (facelift) is a great engine with more power and better torque than the M54
DISA – issues mainly on M54 engines.
VANOS – problems relatively rare on facelift, doesn’t suffer the same seal issues.
Gone: 3.0si 2008 E85
911 997 Carrera S
- ph001
Well lets look at the most common engine failure points (excluding things that are common to both like coil packs, o2 sensors, AFM etc)...
M54:
DISA valves - can break up and get sucked into intake = bad day at the office.
VANOS gets gunked up / leaks with resultant loss of midrange torque. Fairly easy to service to put right though.
Air leaks from splits on rubber elbow on inlet.
CCV system gets gunked up.
N52:
Electric Water pump (£200 to replace, easy enough to change DIY)
CCV on silver top engine can get gunked up (later revised black top engines have integrated CCV which is more difficult to change but doesn't seem to got wrong as often)
Valvetronic can be a bit ticky due to airlocks / sludge build up with lots of small stop - start journeys but not detrimental to engine.
N54:
High pressure fuel pump
Piezo injectors
Electric Water pump
Rattling wastegate actuators
Coked-up inlet valves (what a party they must be having).
The N54 is the most expensive to sort by a big margin. The M54 / N52 is more finely balanced but given the N52 runs a much more modern ECU and has the better engine characteristic and economy it probably wins. Unless you are a big engine modder perhaps.
M54:
N52:
N54:
Piezo injectors
Electric Water pump
- Steve84N
N52 every time, better sound, economy and power plus it's lighter.
Reliability is 50/50 as different things go wrong but neither has very expensive problems that require full engine rebuilds.
C63 AMG Estate 6208cc
Onlinehopz121
The S65 is lighter than most of the Straight 6's believe it or not.
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
- Steve84N
S65 is more than M54 or N52 but less than S54.
- srhutch
- Moderator
HVA issue isn't just down to short journeys and sludge. My old 2.5si did it from almost new and resulted in a revised head being installed. Car also did not do short distances Covered a 50 mile round trip every working day. I would also argue it is detrimental to engine as it's metal on metal contact with impact.ph001 wrote: ↑Wed May 02, 2018 10:46 am
N52:
I'd probably go with M54 given the choice, easier/cheaper to fix and more options for tinkering.
