Which would you pick? N52 (silver engine cover) or N52k (black engine cover)
- ph001
Which would you pick? M54 or N52
Just as a final aside...it turns out the CCV in the black cam cover is serviceable after all:
https://vanos-bmw.com/product/111275522 ... -n52n-n52k
What I'm not clear on is how this connects back to the sump - does anybody know?
- ph001
Bit of research over on Bimmerfest suggest the later black cam cover N52 is known as the N52K and has the following changes:
The engine underwent minor modifications in September 2006 and is now designated
N52K. With the introduction of the N52K, modifications were made in following areas:
• Cylinder head cover
• Lighter Camshafts (hydroformed)
• Revised stronger conrods
• Stem diameter of exhaust valves increased to 6 mm instead of 5 mm
• Torsional vibration damper revisions
• Crankcase ventilation valve now integrated into cam-cover
• New digital hot-film air mass meter (HFM)
• New Throttle valve (EGAS8)
• Faster DME (tri-core MSV80)
• New, 2nd gen electric water pump (still fail though!)
Quite a comprehensive list of changes if it's to be believed!
http://www.bimmerfest.com/forums/showth ... p?t=806805
- Smartbear
I wonder if the power drop on the e89 using this engine is down to the larger diameter valve stems?
e85 3.0si sold
- Mr Tidy
Thanks for that!ph001 wrote: ↑Thu May 03, 2018 5:04 pm Bit of research over on Bimmerfest suggest the later black cam cover N52 is known as the N52K and has the following changes:
• Camshafts
• Crankshaft
• Hot-film air mass meter (HFM)
• Throttle valve
• Digital motor electronics
Ties in nicely with what I found with my 2 Coupes - current one built in August 2006 and has the silver top, previous one was built in October 2006 and had the black cover.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- Marlon
Interesting, I certainly wasn't aware of these minor modifications
Gone: 3.0si 2008 E85
911 997 Carrera S
- shuey
Thanks Ph001 - was wondering why there would be two different covers. Quite a comprehensive list of tweaks too.ph001 wrote: ↑Thu May 03, 2018 5:04 pm Bit of research over on Bimmerfest suggest the later black cam cover N52 is known as the N52K and has the following changes:
• Camshafts
• Crankshaft
• Throttle valve
Anyway just tested my first z4c - flipping awesome! Coming from a 350z, can’t believe how much better z4 feels. Anyway two more to test before I pick... even tempted to go all the way and go for a z4m!
M2 OG / Manual / Grey
Previous
Z4C Si Sport / Manual / Alpine White
350Z VQ35DE / Manual / Silver
Seat Leon Cupra MKII / Manual / Silver
Ford Puma 1.7
Rover 214 Si (I know!)
Previous
Ford Puma 1.7
- Mr Tidy
That makes me feel better - I wondered if I should have tried a 350Z before getting a Z4C, but it doesn't sound like I missed anything!
And I agree, the Z4C is really special. An M was out of my budget, but if it's within yours then why not?
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- shuey
If I'm perfectly honest the z4 M is way out of my budget - but there's two for sale for 15k on autotrader. and I'm not sure if they would ever drop any lower, so my thinking is I could probably always sell it back at 15k. trying to work last time I did something silly as double my car budget!
Previous
Ford Puma 1.7
Previous
Ford Puma 1.7
- earthdweller
Thanks Guys, interesting read
I now know I have an N52K
I’ll sleep well tonight
07 3.0si Sport Roadster Titanium Silver/Syrah Blue Individual Leather, CSL reps ZHP
- shuey
And here’s some official documentation that took me a week of hunting on the tinterweb to find. Sorry pages in wrong order
- BBF800EA-AFAC-4488-ACAF-699E44AC07AE.png (74.06 KiB) Viewed 2823 times
- BC83ECF6-0C50-47AC-8656-6B36F2E0E129.png (657.66 KiB) Viewed 2823 times
- 6B7501D4-9782-4191-9C29-51C1D1B84602.png (532.13 KiB) Viewed 2823 times
Previous
Ford Puma 1.7
Previous
Ford Puma 1.7
- ph001
Good find! The waterpump thing is very interesting indeed. Looks like there maybe was an improved version after all. I can feel a poll coming on!
- enzed4
Perhaps a good reason to buy the last model in any run. Hopefully it will incorporate every positive improvement or enhancement found necessary over the model's life. Makes me feel a bit better about my 2008 Z4. However, I'm now foolishly considering a 2009 E89, so I imagine I'd be experiencing all the pain of any 'new' model release....
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
- Smartbear
Hi, if it’s the 3.0 sdrive it should have the later incarnation of the n52 engine at leastenzed4 wrote: ↑Mon Jun 25, 2018 2:38 am Perhaps a good reason to buy the last model in any run. Hopefully it will incorporate every positive improvement or enhancement found necessary over the model's life. Makes me feel a bit better about my 2008 Z4. However, I'm now foolishly considering a 2009 E89, so I imagine I'd be experiencing all the pain of any 'new' model release....
e85 3.0si sold
- enzed4
Yes, I thought about that after posting - the engine will be more or less the same (but higher output) as what I currently haveSmartbear wrote: ↑Mon Jun 25, 2018 8:05 amHi, if it’s the 3.0 sdrive it should have the later incarnation of the n52 engine at leastenzed4 wrote: ↑Mon Jun 25, 2018 2:38 am Perhaps a good reason to buy the last model in any run. Hopefully it will incorporate every positive improvement or enhancement found necessary over the model's life. Makes me feel a bit better about my 2008 Z4. However, I'm now foolishly considering a 2009 E89, so I imagine I'd be experiencing all the pain of any 'new' model release....
Gone: 2010 35i DCT
Picking up this old topic. My Z4 roadster does have the black cover N52 with the plastic valve cover. The car is from December 2006. Recently I have been troubleshooting for a problem and the DME also came across.
According to the information here I should have the MSV80. I found out I have the MSV70 DME mounted. Can anyone give me more information on this? Did they use a combination of parts for the first months for the N52 with black cover?
