Felt the factory rear camber was a bit excessive for a road car, and less toe in up front makes it a bit more eager to turn in. Its the factory M specs, so figured they know how to set a car up!philbo909 wrote: ↑Fri Mar 09, 2018 8:26 amHowcome you went for this set up, less twitchy? Just had mine lowered and oem aligned, but the dreaded tram lining is back so looking for something more neutral.mjennings23 wrote: ↑Fri Feb 23, 2018 3:21 pm Gone a bit different to my roadster, for comparison
Wheel alignment results
- philbo909
I had the zed aligned last week to factory spec on eibachs and it's tramlining a bit, any experts on here able to advise what to tweak?
front toe +0.06' each side
camber -1.16'
caster 5.16'
rear toe +0.07' each side
camber -2.5'
back in on Friday to get tweaked and was thinking just bringing camber down on the rear, but not sure that'll actually change the tramlining?
camber -1.16'
caster 5.16'
camber -2.5'
Sapphire black z4 coupe 135,000miles young
- hopz121
Go for Z4M settings as a start and see how it feelsphilbo909 wrote: ↑Tue Mar 13, 2018 8:48 pm I had the zed aligned last week to factory spec on eibachs and it's tramlining a bit, any experts on here able to advise what to tweak?
camber -1.16'
caster 5.16'
camber -2.5'
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
I’ve replaced a lot of front suspension components and I am gonna have a total wheel alignment done. I’ve currently got 17x7.5 ET45s all round, with 225 rubber - these are my winter wheels. I’ve just received my new summer wheels, which are 18x8 ET40 with 225/40 on the front and 18x9 ET40 255/35 on the rear.
Does it make much difference which wheels I have the alignment done with?
- vester86
less camber on the rear (aim for as close to front as possible) and a little more rear toephilbo909 wrote: ↑Tue Mar 13, 2018 8:48 pm I had the zed aligned last week to factory spec on eibachs and it's tramlining a bit, any experts on here able to advise what to tweak?
camber -1.16'
caster 5.16'
camber -2.5'
- vester86
yeah let's change everything and see that it feels different indeed an Coupe VS an M have different specs FOR A REASON.hopz121 wrote: ↑Tue Mar 13, 2018 10:02 pmGo for Z4M settings as a start and see how it feelsphilbo909 wrote: ↑Tue Mar 13, 2018 8:48 pm I had the zed aligned last week to factory spec on eibachs and it's tramlining a bit, any experts on here able to advise what to tweak?
camber -1.16'
caster 5.16'
camber -2.5'
i'm not saying that factory specs are the best, but your advise is making no sense this way.
- vester86
not much, but BMW does spec different wheel sizes different. go for "summer tyre specs" would be my advise as you'll probably drive your car more on the limit in summer then in winter.ionofchios wrote: ↑Thu Mar 15, 2018 8:45 pm I’ve replaced a lot of front suspension components and I am gonna have a total wheel alignment done. I’ve currently got 17x7.5 ET45s all round, with 225 rubber - these are my winter tyres. I’ve just received my new summer tyres, which are 18x8 ET40 with 225/40 on the front and 18x9 ET40 255/35 on the rear.
when changing from winter to summer tyres it's always good excercise to check thread depth along the tyre to see where the tyre wears the most. (inside/middle/outside). with that info you might want to change some alignment
Ok, thanks Vester!vester86 wrote: ↑Thu Mar 15, 2018 11:01 pmnot much, but BMW does spec different wheel sizes different. go for "summer tyre specs" would be my advise as you'll probably drive your car more on the limit in summer then in winter.ionofchios wrote: ↑Thu Mar 15, 2018 8:45 pm I’ve replaced a lot of front suspension components and I am gonna have a total wheel alignment done. I’ve currently got 17x7.5 ET45s all round, with 225 rubber - these are my winter tyres. I’ve just received my new summer tyres, which are 18x8 ET40 with 225/40 on the front and 18x9 ET40 255/35 on the rear.
- hopz121
vester86 wrote: ↑Thu Mar 15, 2018 10:56 pmyeah let's change everything and see that it feels different indeed an Coupe VS an M have different specs FOR A REASON.hopz121 wrote: ↑Tue Mar 13, 2018 10:02 pmGo for Z4M settings as a start and see how it feelsphilbo909 wrote: ↑Tue Mar 13, 2018 8:48 pm I had the zed aligned last week to factory spec on eibachs and it's tramlining a bit, any experts on here able to advise what to tweak?
camber -1.16'
caster 5.16'
camber -2.5'
- philbo909
Ok so I had it tweaked today
0deg02' front toe
-1.2 front camber
0deg11' rear toe
-2.1 rear camber (as far as they could take it apparently, maybe to do with the Eibachs)
Drives great now, didn't take it out in anger, just the 15 mile b Road commute. But feels much more planted compared to normal!
0deg02' front toe
-1.2 front camber
0deg11' rear toe
Hi Phil,philbo909 wrote: ↑Fri Mar 16, 2018 4:12 pm Ok so I had it tweaked today
0deg02' front toe
-1.2 front camber
0deg11' rear toe
Bit of a favour, my recently acquired Z4 roadster tramlines as a result of the previous owner fitting the Eibach springs. He didn't have the cars alignment done and need to get mine done. could you post your tweaked full geo set up for me to follow? This is me assuming the roadster and coupe wont be dramatically different... do step in if I'm being a pleb anyone.
cheers!
- philbo909
Not at all, this is the complete set up though, they can only adjust toe and camber. Front camber can also only be adjusted if the pins are pulled I think (I'm no expert on this, but most places claim it can't be adjusted)SamP84 wrote: ↑Tue Jun 12, 2018 11:50 amHi Phil,philbo909 wrote: ↑Fri Mar 16, 2018 4:12 pm Ok so I had it tweaked today
0deg02' front toe
-1.2 front camber
0deg11' rear toe
cheers!
Caster can't be adjusted
My car is back on msport springs though as I do so many miles on it, too many scrapes from speedbumps/rural driveways!
- Steve84N
Castor can be 'adjusted' by fitting the Z4M lower front control arm bush, it's offset compared to standard. Otherwise, yes you can't formally adjust it. A worthwhile mod if you have a non-M.
C63 AMG Estate 6208cc
Does this increase or decrease castor? What is ge impact on the steering? Increased castor increases the self centering and slows the steering a little doesn’t it?
Z4 Coupe 3.0si - Stratus Grey - M sport seats, headlining, New England, Carver, Cruise, Xenons, sT XTAs, Eisenmann race, 18” 405m
G21 M340i - Tanzanite - Tech Pack, Comfort + Pack, Visibility pack, pan roof.
- Steve84N
Increases castor which gives a bit more negative camber when cornering. I didn't notice much difference in steering weight but the increase in mid-corner grip was obvious.
