Found the boot was wet this morning in the sunken part near the lights. Anyone had this?
Wondering if it’s coming through from the join here (highlighted) as that’s roughly where I can feel something on the inside.
Thoughts?
Wet boot near the lights...common leak?
- 8F76B67F-637B-473B-B5EE-3210CEE1EFB4.jpeg (361.15 KiB) Viewed 828 times
2nd Z4, Auction find, 2007 3.0si Sport, 45k, Silver Grey, 224 Alloys. Retro Cruise
Previous: 2003, 2.5i Sport, Sterling Grey (2006-2010)
- JINGLE
I had something similar, I removed rear light for a look and didn’t see anything obvious. So I reseated the foam etc and then put a small bead of clear silicone along the join in the boot recess but where the panels join. It can't be seen as it’s clear and appears to have fixed the issue... no idea what actually caused it so reseating the light could have potentially fixed it.
Interested to see if anybody else has any comments
- 1000rr
There's a vent behind the carpet,. Peel the carpet crack to see if the vent is wet, if so, the seal has gone.
Ok, sounds like a good place to start! Is the seal a separate part you can buy to replace?
- 1000rr
I think you need a new vent... but silicone may sort it?
- Beatman
Is your car parked on a slope? My drive is fairly steep, and I had the same as you, water in the corner pockets of the boot.
It only seemed to do it during heavy rain. When I looked in to it, the rain water was running back along the tray, that runs into the roof motor pocket.
All the Drain holes are clear, but the angle of the car and water getting on to the tray drained back in to the boot..
My Car- 2004 3.0se sterling grey, mv3s , satnav, heated seats, ZHP.
Had the exact same problem when my car was parked pointing uphill. When I park pointing downhill, there is no issue.Beatman wrote: ↑Fri Feb 23, 2018 1:04 amIs your car parked on a slope? My drive is fairly steep, and I had the same as you, water in the corner pockets of the boot.
Harry
1970 VW Sunroof Bus - "The Magic Bus"
1973.5 911T Targa - "Smokey"
2003 BMW Z4
2009 MB C300
2003 BMW Z4
2009 MB C300
- MACK
+1HarryD wrote: ↑Sat Feb 24, 2018 6:04 amHad the exact same problem when my car was parked pointing uphill. When I park pointing downhill, there is no issue.Beatman wrote: ↑Fri Feb 23, 2018 1:04 amIs your car parked on a slope? My drive is fairly steep, and I had the same as you, water in the corner pockets of the boot.
Silver 05 3.0i SE
White E89 20i M Sport
- ben g
I have this on mine currently. Recent heavy rain has gathered in the right side of my boot, in that little area where nothing seems to fit.
It done it years ago when i left my car parked on my sloped driveway and went on holiday. Replaced the vents behind the bumper and also the rear light gaskets.
I'm pretty sure it only does it when the hardtop is fitted, so the water must be running down from the hardtop into a gap somewhere. God knows where the gap is though. I even raised the boot seal a little to see if that made any difference.
