Hello guys, first post here so be gentle :wink:
I recently got a Z4 E85 3.0i -04, love the car so far but as several others I have issues with the EPS.
I got the EPS light on the dash as soon as I turned the key, no power steering at all. A few times the power steering started to work after a while driving. Kind of the opposite of the sticky steering..
Connected INPA but got no response from control unit. All other units including steering angle sensor read out just fine without any codes. Did verify with a top-notch diagnostics reader at a BMW dealer that the EPS control unit was not responding. During the whole time outside temperature has been a few degrees C, so any heat related issue seems unlikely.
I have been replacing the battery and verified voltage on the red cable to the motor and green/white cable from fuse 22. Measured good ground on the black cable.
However when I heated up the control unit and steering column to 50 degrees C the dash light went away and the power steering worked just as it should. The EPS has remained working during a few cold starts since then but haven't been weather for a proper test drive here in Sweden, only got summer tires.
I connected INPA to the EPS control module and got one code, 6127 Error code 27: Lenkwinkel Testbedingung nicht erfullt. My german is a bit rusty but didn't seem to be a relevant code, probably from the glitchy connection. Deleted it and haven't appeared again so far.
Since ecutesting.com seem to offer a cure for my symptoms by rebuilding the motor/control unit and due to the temperature dependent broken/fully functional characteristics I noticed, I would suspect some bad soldering joint in the control unit.
I have fixed two other cars by opening control units and resoldered bad connections, and feel confident around any size through hole or surface mount components. Would be nice to save some $$, even though ecutestings lifetime warranty is tempting.
So finally my question to you experts, does anyone have experience from cracking open said or similar control unit and resolder any joints?
Does anyone know what exactly might be failing in the control unit, or do I follow a false trail?
If I go ahead with the operation I will off course keep you posted with the result
