Help! EML and fluid in engine bay!
"M" Specific discussion
Tcochrane92
Post by Tcochrane92 » Fri Feb 16, 2018 7:51 am
Started my car this morning and it had a really tough idle, revs fluctuated and the EML was on, pic attached
Opened the bonnet as it looks like some liquid (smells a bit oily/petrolly) has escaped out the intake onto the engine cover. Pic below.
The intake pipe is fully on and there's no oil in the air box
Subsequent start ups have been normal, car idles as normal, but the EML is still illuminated. Need a code reader...
I checked my oil level yesterday and noted how clean the engine bay was, nothing abnormal. It also drove fine yesterday.
Anyone have any ideas?
Thanks all
Current: Imola Red 400bhp 640d & Ocean Blue BMW S1000XR Sport SE
Past: Silver Grey Z4MR, Silver Grey Z4C & Titan Silver Z4 3.0i
Fishy Dave
Post by Fishy Dave » Fri Feb 16, 2018 10:15 am
Id be checking all around the fuel rail, it might be a tiny leak, but the consequences of fire are serious. :o Then again a fuel leak would be unlikely to trigger an eml? If it is fuel a lot will have evaporated by now, so the pool you see in the pic could have been larger.
Corvette C6
Mazda RX-8 race car
Now sold: Z4M Roadster, the best all round car I have owned.
Roundozo
Post by Roundozo » Fri Feb 16, 2018 10:21 am
Have you stuck your fingers on that liquid to see if fuel or oil? Do the M's have crank case breather pipes? Are they blocked?
Past - Z4 Coupe, gone but not forgotten
Present - 530d M sport touring
Tcochrane92
Post by Tcochrane92 » Fri Feb 16, 2018 10:41 am
I'll check whether its fuel or oil, I only smelled it this morning.
I turned the car back on and the EML wasn't on anymore so I drove to work, felt normal (15 min drive)
I'll put a fault code reader on it after work and check the fuel rail and surrounding pipes for any leakage
I checked the engine bay last night and it was nice and clean, this must've happened overnight
Phoenixboy
Post by Phoenixboy » Fri Feb 16, 2018 12:05 pm
Hope it all gets sorted mate, I sometimes wish I was more mechanically minded, but I’ll stick to what I’m good at😀
I can clean a car well.
E89 s drive 30i manual/gone
space grey
Carbon interior trim
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
Gone, E85 Ruby Black.
Tcochrane92
Post by Tcochrane92 » Fri Feb 16, 2018 12:14 pm
Phoenixboy wrote: Fri Feb 16, 2018 12:05 pmHope it all gets sorted mate, I sometimes wish I was more mechanically minded, but I’ll stick to what I’m good at😀
Thanks! :P
AndyBeech
Post by AndyBeech » Fri Feb 16, 2018 12:37 pm
Did you take the intake elbow off and nothing in the plenum box I presume?
Any on the underside of the bonnet?
Deffo check if it's oil or fuel first as that would eliminate the fuel rail....but yeah as said, possibly the breather pipe I would say.
Also, check the rubber connections from plenum to throttle bodies are all tight.
Weird placement for a leak!
The EML will disappear after 2-3 starts after being illuminated if the problem is no longer present (generally) but the fault will be logged so worth a code read for sure if you can find someone.
Also for OCD sake if you're that way inclined, in you're second pic, the sucking pump jet on the right of the second pic should be attached to the air box bracket next to it :wink: Though the bracket might be broken, not very robust!
Z4MR - Gruppe M, Bilstein PSS10, CSL's + 18" CSL reps with semi's, RTAB Limiters, Powerflex’d, PF Camber Arms, K-Sport BBK / RSL-29, GC Camber Plates, Strut Brace, Exhaust valves, custom brake cooling, complete underside refresh!
Tcochrane92
Post by Tcochrane92 » Fri Feb 16, 2018 1:02 pm
AndyBeech wrote: Fri Feb 16, 2018 12:37 pmDid you take the intake elbow off and nothing in the plenum box I presume?
I did indeed take the intake elbow off, inspected it and re-attached it securely. I also checked the airbox for any oil (incase its the crankcase breather) and it was fine - no problems. I'm fairly confident to write off the intake system - I'm not concentrating on the oil and fuel systems
I need to check the underside of the bonnet
I'll be reading the stored codes with Carly after work today.
Yes, I know the the sucking pump jet should be attached, but the bolt has sheared off! And half of the remaining bolt is still inside :oops: so I think that's a lost cause for now! :thumbsdown:
ph001
Post by ph001 » Fri Feb 16, 2018 1:20 pm
Very weird location. Could it have come from the washer jets on the underside of the bonnet possibly? Although that wouldn't bring on the management light of course.
AndyBeech
Post by AndyBeech » Fri Feb 16, 2018 1:56 pm
Tcochrane92 wrote: Fri Feb 16, 2018 1:02 pm
Ha yeah same happened with mine, crappy design. I zip tied it to a hole on that bracket, works!
I thought washer jets but obvs that wouldn't bring on the EML or affect the idle so can't be that.
Code reader will probably reveal all!
Beedub
Post by Beedub » Fri Feb 16, 2018 2:03 pm
You know all my years of messing with the s54.... ive never seen this one before.... and the bits i would suggest are clearly dry and not the issues, even more weird its seemingly a patch in the middle of the airbox with no sort of "start" to the trail...
Tcochrane92
Post by Tcochrane92 » Fri Feb 16, 2018 2:09 pm
I think the next step is to let Carly tell us what's wrong and go from there.
I'm going to wipe off all the fluids (and try to determine if its fuel or oil) and see if it leaks again on my drive home.
Very weird though, looks almost as though its dripped down onto the engine cover and not from the fuel rail?
Z4M-2006
Post by Z4M-2006 » Fri Feb 16, 2018 4:08 pm
It does look like oil,there does seem to be other spots as well randomly around the intake chamber.
Thats a real weird place to get a stain though,especially as you checked it last night and it was fine and presumably hadnt run again when you found the residue ?
Tcochrane92
Post by Tcochrane92 » Fri Feb 16, 2018 4:25 pm
Z4M-2006 wrote: Fri Feb 16, 2018 4:08 pmIt does look like oil,there does seem to be other spots as well randomly around the intake chamber.
I checked the engine bay last night when I checked the dipstick. Then I drove to the pub and drove home again - a total of maybe 15 miles.
That was the sight I was welcomed with this morning at roughly 6:30ish am
Weird..
Buckz
Post by Buckz » Fri Feb 16, 2018 4:41 pm
a couple of drops of oil ended up on the intake and spread around when it warmed up? maybe you didn't notice them falling of the dipstick?
