tighten handbrake
- paddy wright
tighten handbrake
how do u tighten handbrake-mines well slack!
Re: tighten handbrake
please!!, i need to put mine as high as i can, then tug a little bit extra to make sure its on!
- RichardG
Assuming it's not just a case of taking up the slack in the handbrake cable, then what you need to is
Jack up the car
Remove a bolt from both wheels
turn the wheel slowly, looking in the hole until you can see part no.3
Using a screwdriver turn the segmented part on part no.3 until you can longer turn the wheel by hand
Turn the segmented piece the opposite way 9 times to free off the wheel.
There are further instructions on the TIS but unless you are getting into the handbrake operation and forces applied at certain points in the handbrakes operation I'll not go there at the moment.
Hope this helps
Jack up the car
Hope this helps
04 2.5 SE, Alpine iDA X-305, Eibach's, M Tri-Colour MFSW, CF Roundells, LeatherZ Armrest, De-Gingered, 19" VMR V710's, Aero Skirts, Fr & R M Bumpers, Quad Exhaust and NO Stubby
