Connecting CTEK Battery Charger?
Nick177
Post by Nick177 » Thu Dec 07, 2017 5:44 pm
It’s that time of year when I normally plug in my CTEK Battery Charger into my E89. I found it simple with my old E85, just plug it in to the cigarette lighter. With the E89 the two power connectors, one the cigarette lighter,the other under the arm rest appear not to be live. I’ve been on line and it appears that there might be a power socket in the boot. It’s possible that my model 2011 SDrive 23i M Sport Highline doesn’t have a power socket in the boot, which would mean that I would have to connect direct to the battery, or via the terminals in the engine bay. Does anybody know any different?
ph001
Post by ph001 » Thu Dec 07, 2017 6:02 pm
Terminals in the engine bay is usually the preferred place. Defo not across the battery as you have an IBS module.
2004 E46 M3 coupe manual.
Online
ronk
Post by ronk » Thu Dec 07, 2017 6:20 pm
The "Book" is quite specific although quit a few members have connected directly over the battery.
Scan 1.jpeg (180.61 KiB) Viewed 397 times
You don't stop playing when you get old - You get old when you stop playing !
Nick177
Post by Nick177 » Thu Dec 07, 2017 6:27 pm
Thanks ph001, seems a bit of a backward step going from E85 to E89. Not much of a comfort package there. Car will have to sit in the garage with the bonnet open.
Kingfisher
Post by Kingfisher » Thu Dec 07, 2017 6:35 pm
You can shut the bonnet OK, under the front rather than the side - no harm done.
Dec 2014 ... E89 35is sDrive M DCT ... Red ... :driving:
john-e89
Post by john-e89 » Thu Dec 07, 2017 6:55 pm
Plenty of room to connect a c-tek under the bonnet, then run the cable out between the headlight and bumper, shut the bonnet, no problem at all.
2015 E89 35is. Sapphire black on 296's, coral red, nav, cruise, pro wireless, comfort pack and toasty steering wheel.
Previous:
Z4M roady
E85 3.0 si,
E85 3.0SE
No 5 has landed...2nd ///Mental angry roller skate...
Busterboo
Post by Busterboo » Thu Dec 07, 2017 7:09 pm
So, my idea of leaving the CTEK 'convenience'(?) connectors permanently attached to the battery and run up through the boot floor, for connection to the CTEK when needed, is a bad one.
Kuh.
Gaffa22
Post by Gaffa22 » Thu Dec 07, 2017 7:22 pm
Well I didn't know that and have been connecting direct to the battery.
Doesn't appear to done any harm, fortunately.
I'll connect under the bonnet in future.
2010 E89 35i DCT
2017 Honda CBR1000RR fireblade
2016 Honda VFR1200F
ph001
Post by ph001 » Thu Dec 07, 2017 9:18 pm
I don’t think it would do much harm in reality but the IBS is supposed to look at the recharge current so it knows the battery is fully charged. Take it all with a pinch if salt...I’m of the opinion that if the IBS is looking at live data anyway it will soon sort itself out once you start driving normally.
Gaffa22
Post by Gaffa22 » Thu Dec 07, 2017 9:56 pm
Well like I said it doesn't seem to have done any harm, I left it connected because the battery is on its way out as it's the original, I have got a new battery the dealer paid for but haven't fitted it yet as I haven't been using the car.
I assume I can permanently attach the Ctek convenience connector to the terminals under the bonnet ?
2010 E89 35i DCT
2016 Honda VFR1200F
Baza
Post by Baza » Thu Dec 07, 2017 10:55 pm
For the last 3 winters mine has been connected direct to the battery using the convenience connections which I leave in place all year . There has been no ill effect or problems . Its easier than under the hood due to the lengths of the CTEC cables.
Panther Kallista 2.8
S Drive 3.0i E89 2009 Space Grey Coral red Int 18" 295 wheels
Ewazix
Post by Ewazix » Fri Dec 08, 2017 12:06 am
I've always understood that the connection post is recommended in owners manuals because high amp fast chargers and jump starting can overload the system and there is charge protection on the post. For comparison the ctek is strictly speaking a smart controlled 'conditioner' which delivers a max of 5 amps (hence the skinny leads). An average boost or jump starter will push over 400 amps which would knock down a horse! so requires the big fat leads and quite sensibly needs protection.
The CTEK is safe to connect directly to the battery via the supplied plug, in fact CTEK make the chargers for BMW and are identical, including the battery plugs and lead supplied even for the E89.
2003 2.5SE, low miles, Sterling Grey, black leather, Colour coded 108's & Eagle F1A2, no stubby here! French fries intact, unmolested.
Gaffa22
Post by Gaffa22 » Fri Dec 08, 2017 9:10 am
Handy to know, Thanks Ewazix
I must admit I thought it unlikely a Ctek battery charger would push enough amperage to cause any harm.
Jump starting as you say, is a different mater
2010 E89 35i DCT
2016 Honda VFR1200F
mcbutler
Post by mcbutler » Fri Dec 08, 2017 2:07 pm
Surely, once the battery is fully charged, it is fully charged, you cannot charge it higher than its max physical capacity.
Why do we need a module to monitor something that is fixed?
Is it to warn of excess discharge? or maybe something to do with the system that disconnects the alternator at full charge?
Either way would it be required or active (connected) if the car is parked up?
ph001
Post by ph001 » Fri Dec 08, 2017 3:46 pm
Read this... viewtopic.php?f=23&t=100385&start=15
The IBS module is active all the time btw.
Who is online
Users browsing this forum: Callum_W, Joee, keving1, SteveSmith, willgill and 10 guests
