Shower cubicle mastic ...
- pvr
Tough crowd
After second removal of all mastic (clear at screen end, white at wall end). No more nails means that
Plastic tool and nails to get it all out, yikes.
- IMG_4431.JPG (202.57 KiB) Viewed 930 times
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- pvr
Kitchen roll was used John to attempt to remove the worst of the previous disaster
Ok, so tool ordered, spray tip noted and appreciated. One evening next week to do the second attempt of applying it, this time
Probably too thin so it does not cover it
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- ekimj10
I have used this sealing strip from Wilko around the edge of the bath and so far (3 months or so) its been very successful.
You end up a with a 19mm x 19mm seal, its self adhesive and looks very neat, also cheap.
This is the link http://www.wilko.com/fillers+sealants/w ... vt/0288922
Def recommend, just take your time, use masking tape to mark where the horizontal bit goes, leave the adhesive cover on the vertical bit and its good. Saves the dilemma of getting a perfect mastic seal.
2.2R Toledo Blue
- pvr
With fugi kit bought the mastic is now in place. Used the 3 mm side, pretty happy with that tool and the tips of all of you guys about the soapy water worked a treat as well
- IMG_4446.JPG (231.19 KiB) Viewed 896 times
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
So you gave up and let the missus do it after all then Paul......nice job, she’s talented....
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- TonyP
Siliconing around after DIY jobs is something I hate, I always seem to get it all over my hands & clothes & then there's the stink as it's curing, usually the end result looks ok though.
I suspect as someone else said, I apply too much...
- pvr
I was prepared this time. Wearing gloves, applied very little (started to worry me in places) and the soap spray worked miracles in cleaning the tiles.
As long as the water does not disappear between the tiles and the mastic I am happy
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- Silverzedtom
All the trays etc i silicone I just use my middle finger. It’s a good idea to lick your finger first to stop the silicone sticking. As mentioned you only need to cut a tiny bit off of the tube and cut it at a 45 degree angle.
I did have a fugi kit but seem to get a neater job with my middle finger, no tape and no soap.
I think it’s just practice. I used to be shocking at it but have done loads as I’m a plumber. Worst case it can always be picked off.
E85 2.5si
F55 Cooper S
F55 Cooper S
- Silverzedtom
Oops I was a bit late there... looks like you’ve done a neat job!
E85 2.5si
F55 Cooper S
F55 Cooper S
Call that neat
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
