Got to agree with this my indi said he has changed so many 2.0D engines that he can change them in under 2 hours now.
Loud tappet like noises from Engine....
E92 M3 Silverstone blue
Z4MR Black Gone
Z4MR Black Gone
- Ducklakeview
- jimmybell
So many pages on this - did the guy ever get it fixed?
V12 Vantage S - Hammerhead Silver, Manual, Lightweight Wheels, Exterior Carbon++, Carbon Buckets, AMR Performance Pack.
M135i LCI - ZF8, White, HK Audio, Adaptive
GONE Z4 M Coupe, Imola, CSLs
GONE C63 AMG, Black, Performance Pack+, LSD, HK
- ph001
You only need to go back one page to find the answer! In a word, yes.
A lot of the follower failures seem to happen not long after an inspection 2 from what I have read, does anybody know what's the causes the the follower to wear away ,poor hardening, incorrect adjustment, lack of inspection to see how badly they are worn before shimming. There must be a maximum shim that can be fitted shortly before failure. Why only a couple seem to wear badly. If it was a bad batch of material then surely all of them would wear out equally. Thoughts?
- MrPT
Maybe because the follower deteriorates so quickly once the case hardening has gone, that you’d need all follower coatings to fail at *exactly* the same time to see equal wear.
But you do hear of only one follower failing sometimes. I don’t know whether this means that just one follower started tapping or only the coating on one follower failed (or both). That would be inconsistent with bad batches, assuming that engines are fitted with followers with contiguous production dates.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- Ewazix
Generally bearings on a rotating shaft, or wear points like followers all wear at different rates due to oil flow, temperature and loads due to the shaft 'flexing' at high rotation speeds. I also think you are spot-on with the point about accelerated wear once the hardened surface is breached, once a wear point develops it will always catch. My guess is that as with crank bearings the same followers probably wear first on average engines. "The all do that sir, it's a wear-and-tear characteristic nothing we can do" ..... as the BMW warranty agent would sayMrPT wrote: ↑Tue Nov 28, 2017 12:37 amMaybe because the follower deteriorates so quickly once the case hardening has gone, that you’d need all follower coatings to fail at *exactly* the same time to see equal wear.
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
- BMWZ4MC
As above. The case hardening on the followers is very thin, once it’s gone, the follower fairly quickly trashes the cam lobe with which it’s paired.
Schrick sell coated OEM followers that should lessen the wear rate.
S2000 GT - gone
- T1berious
In other news, she's going back this weekend for some exhaust heat shield welding action, wheel refurbs and dyno run.
In totally unrelated news, our long serving E92 330i is being replaced by a 440i on Thursday. 158k and a decade later she's being replaced.
I will shed a tear.
I will shed a tear.
Current
718 Cayman GTS 4.0, Kia EV6 GT line S
F87 M2C ,F82 440i, E85 Z4MR, E92 330i All Gone!
The new bearings are supposed to have a run-in period of 1k miles or so - not sure I'd want to be putting it on a dyno that soon
Current: 06 E85 M Silbergrau
Previous: E85 3.0si Silbergrau, 03 E85 2.5i Maldives Blue.
Mods: Gaptech OTH+R, Dension Gateway 300 with USB, CDV-, clear side indicators, euro tails, stubby, MFSW retrofit, OEM Bluetooth/VR
- BMWZ4MC
My cat heat shield rattles like a pig. I had it welded a few years ago but grounding on an aggressive change in camber at a drive entrance put pay to that. The good news is that welding it cures the problem, the bad news is you’ll dislodge it again at some point!
S2000 GT - gone
- TomK
According to BMW's workshop manual that's not true (and also what I've been told by my shop), no run in period is required for these on replacement. I think most just take it relatively easy for a few hundred miles to be on the safe side, 1k is unnecessary.
By BMW's workshop manual you're referring to TIS/ISTA? I couldn't find any reference to it and unless it specifically says that a run-in period isn't required I wouldn't take it to mean that it isn't.
I know the arguments which say that the break-in is unnecessary, but it is recommended by BMW: under SIB 11 04 04 (rod bearing updates for early E46 M3s) it specifically states that a 1200 mile break-in period is required following the correction work. I have two friends who are experienced BMW techs, both E46 M3 owners and they agree that a break-in should be performed.
That said, I do agree that 1200 miles of break-in is certainly overkill but dyno runs are not a casual engine operation so I definitely wouldn't be doing one too soon after the bearing change!
- Beedub
Definitely run these parts in for a period, its will hurt nothing to do so and give you piece of mind.
- Smartbear
^^As above ^^ if it was my car I wouldn’t let it go near a Dyno at this early stage.
I certainly wouldn’t want to be changing the bearing shells twice
e85 3.0si sold
