That place would be my heaven!! Can't wait till I find a place with a garage large enough for a 2 post lift!!!
E85/E86 Steering Problems (Solved)
- TheDan
Hello!
Im not sure i have sticky steering but gonna ask anyway.
My problem is that when driving around 110km/h electric steering assist is always micro correcting steering wheel and i have to counter that correction from electric assist, it is hard to drive in straight line because of this. There are no faults stored.
Could adjusting ring solve that?
Hi guys,
Noticed when mine was parked in the sun during the baking hot summer the steering would get a bit sticky (nothing too bad just noticeable). The temperatures have dropped so only really occurs on a long drive but looked through this thread and thought I'd attempt this to see if it helps at all
I've managed to loosen the 2 bolts but cannot get the ring to budge. How are people doing this? And how 'loose' should the 2 bolts be? I have them to the point where using a ratchet spanner takes the lightest touch to loosen them further, but don't want to over loosen them (if that's even possible).
But the ring that you have to move clockwise will not budge, and I can't see holes or bits I can stick a screwdriver to use as leverage.
Ideas most welcome
Ideas most welcome
- wonkydonkey
FunkyGBrown If you've definitely loosened the right bolts ( ) then it should turn by hand. By all means loosen them another half a turn or so from where you are now, to take the clamping load off the assembly. Perhaps it just needs a bit of persuasion to break free if it's never been moved since initial assembly
Previous:
~2006 Z4MR in Silver Grey
~2003 3.0i E85 in Sterling Grey
Click here for the Sticky Steering thread
<My name is James>
<My name is James>
Definitely the right bolts! Should it turn quite freely? Any tips on getting it loose? It definitely feels stuck inplace!wonkydonkey wrote: ↑Sun Oct 16, 2022 5:11 pm FunkyGBrown If you've definitely loosened the right bolts ( ) then it should turn by hand. By all means loosen them another half a turn or so from where you are now, to take the clamping load off the assembly. Perhaps it just needs a bit of persuasion to break free if it's never been moved since initial assembly
- wonkydonkey
FunkyGBrown I haven't messed with one for a few years now, but I don't think I remember having to free any of them off. Aren't there some flats that could be given a gentle persuasive tap with a small hammer and a suitable tool?
Previous:
<My name is James>
<My name is James>
Used a hammer and a flathead for some gentle persuasion and that seems to have done to trick. Moved it about 10mm clockwise and the steering feels 10x better, excellent!wonkydonkey wrote: ↑Sun Oct 16, 2022 8:03 pm FunkyGBrown I haven't messed with one for a few years now, but I don't think I remember having to free any of them off. Aren't there some flats that could be given a gentle persuasive tap with a small hammer and a suitable tool?
Leaving the trim off for a few days just so I can check the 2 bolts are tight enough. So far so good!
- wonkydonkey
FunkyGBrown It sounds like you got the measure of it Happy driving!
Previous:
<My name is James>
<My name is James>
- enuff_zed
Always win with a bit of percussive adjustment.FunkyGBrown wrote: ↑Mon Oct 17, 2022 12:45 pmUsed a hammer and a flathead for some gentle persuasion and that seems to have done to trick. Moved it about 10mm clockwise and the steering feels 10x better, excellent!wonkydonkey wrote: ↑Sun Oct 16, 2022 8:03 pm FunkyGBrown I haven't messed with one for a few years now, but I don't think I remember having to free any of them off. Aren't there some flats that could be given a gentle persuasive tap with a small hammer and a suitable tool?
- DMike
2005 Z4 3.0i Sterling grey
- thecremeegg
Does anyone know if a facelift steering column fits in a pre-facelift? I assume it will but good to check!
Z4M - Interlagos Blue with Black Leather
Z4 3.0i - Sapphire Black with Red Leather - FOR SALE!
- enuff_zed
Realoem suggests it's the same part number yes.thecremeegg wrote: ↑Thu Nov 10, 2022 5:57 pm Does anyone know if a facelift steering column fits in a pre-facelift? I assume it will but good to check!
If you discover differently let me know as I have a pre-facelift assembly here.
- thecremeegg
Thanks! I did hear the facelift ones were meant to have been changed internally but that could well be hearsay!
- enuff_zed
If you can find out let me know, as I'm away from Sunday pm and not back until next Friday.thecremeegg wrote: ↑Thu Nov 10, 2022 6:10 pm Thanks! I did hear the facelift ones were meant to have been changed internally but that could well be hearsay!
Does this mean you're not going hydraulic now then?
- thecremeegg
Yea, I accumulated some of the parts, but getting anyone round my way to do it is impossible, plus I think that I may well sell the car on this year so didn't really see the point of the investment in the end. Anyone need a purple tag steering rack?
