E85/E86 Steering Problems (Solved)
MJJamieson
Post by MJJamieson » Sat Jan 20, 2018 10:47 pm
Official BMW Procedure.
32 31 ... Optimisation of electro-steering.jpg (145.79 KiB) Viewed 6849 times
32 31 ... Optimisation of electro-steering2.jpg (154.33 KiB) Viewed 6849 times
32 31 ... Optimisation of electro-steering3.jpg (146.1 KiB) Viewed 6849 times
2004 E85 Z4 2.5i SE Sterling Grey.
Kamuela
Post by Kamuela » Mon Jan 22, 2018 4:06 am
Well, isn't that interesting. Looks like we've been doing it right. What's the date of this TIS update? Is this old information, or something BMW's just discovered?
GuidoK
Post by GuidoK » Mon Jan 22, 2018 7:32 am
Interesting find.
I checked with my official TIS version that sits in ISTA-D. That is from 22-11-2014 (ver. 3.46) so quite old already (for ISTA terms, the old tis was from 2007). That version also has this page already albeit slightly different. These is no distance listed for D (here D=5mm), but you can read the 5mm on the picture with the caliper.
I first mentioned the method here on 19th of june 2015: https://z4-forum.com/forum/viewtopic.ph ... 3#p1153983 ; by then lots of people in DLD/NL had done this mod.
On the german z forum they first started experimenting with it and reporting it around may 2014:
http://www.zroadster.com/forum/index.php?threads/aktion-problemlenkung.59821/page-75#post-1943088
It never came up in me to look it up in the new TIS because the old one obviously never mentioned it.
Maybe the new tis has more answers to other previously not displayed/solved problems.
Joycey
Post by Joycey » Mon Jan 22, 2018 11:30 am
Yeah this is a great find, glad to see we're on the right track. Might be worth sifting deeper into TIS and see what else is there. :thumbsup:
Online
bladeowner
Post by bladeowner » Mon Jan 22, 2018 3:29 pm
GuidoK wrote: Mon Jan 22, 2018 7:32 am I first mentioned the method here on 19th of june 2015: https://z4-forum.com/forum/viewtopic.ph ... 3#p1153983 ; by then lots of people in DLD/NL had done this mod.
Yes, thanks for the heads up Guidok :thumbsup: I did mine in June 2016 after reading your post. I initially moved mine 5mm but increased it to 10mm a few months later. There is no stickiness at all now but I can still 'feel' a difference between cold days and hot days (or when the heater has been on for a while).
2004 Sapphire Black 2.5 SE Z4 SMG
GuidoK
Post by GuidoK » Mon Jan 22, 2018 3:36 pm
In theory as this is a TIS entry now (or apparantly has been for a few years now), a dealer can do this repair too. Albeit TIS writes that the steering column has to be removed, which costs time (and money). Probably to not frustrate the more clumsy bmw mechanics.
loftust
Post by loftust » Mon Jan 29, 2018 12:41 pm
Is this thought to solve the steering wobble that many experience at motorway speeds? Assuming other aspects such as balancing and FCAB replacement have already been addressed.
GuidoK
Post by GuidoK » Mon Jan 29, 2018 1:52 pm
You mean the tramlining effect where the car is steered into the ridges of the tarmac caused by heavy lorries?
Thats mainly solved by ditching the runflats and maybe in limited effect adding rear trailing arm limiters (or rear trailing arm bushings that have the limiters build in).
Sticky steering is more an effect where it seems that a small magnet holds the steering in the center position and you have to break the steering wheel free from that magnet force before you can steer.
Rob_benton
Post by Rob_benton » Mon Jan 29, 2018 4:31 pm
loftust wrote: Mon Jan 29, 2018 12:41 pmIs this thought to solve the steering wobble that many experience at motorway speeds? Assuming other aspects such as balancing and FCAB replacement have already been addressed.
Solved mine after trying everything else. You have nothing to lose.
2005 Z4 3.0 Black, Zhp gear knob.
ionofchios
Post by ionofchios » Wed Feb 07, 2018 6:01 pm
Just had a go at this, but can’t get enough leverage on the bolts with my hand up inside the dash. Mine’s and e86 and it has allen bolts, not torx. I’ve got an allen bit, then universal joint, short extension, then T piece (all 1/4 inch), but I can’t get enough leverage on it. There’s not enough room to get anything longer up in there either. I suppose I’ll have to take the whole steering assembly out if I can’t find a way.
Any advice?
mac27040
Post by mac27040 » Wed Feb 07, 2018 6:47 pm
so who's setting a stall up at ZEDfest to do this for people !!! :thumbsup:
3.0i SMG Supercharged,19" CSL, AvinUSA android 10.25” screen,DSP,M6 gearknob,Coilovers,Aero F-bumper,M r-bumper,Aero skirts,Facelift front & rear lights,M sports seats,Carbon Steering wheel,Intravee,Rervese cam,Hydrographics
Joycey
Post by Joycey » Wed Feb 07, 2018 9:29 pm
mac27040 wrote: Wed Feb 07, 2018 6:47 pmso who's setting a stall up at ZEDfest to do this for people !!! :thumbsup:
Ha, long as theres a free osteopathy session after :rofl: Takes me about 20mins to make the adjustment.
Roundozo
Post by Roundozo » Thu Feb 08, 2018 9:01 am
I can vouch for this fix. Done it on my coupe a while back and it's transformed the steering. Feels so much more planted on the road now. Great fix OP! :thumbsup:
Past - Z4 Coupe, gone but not forgotten
Present - 530d M sport touring
andystone
Post by andystone » Thu Feb 08, 2018 1:36 pm
I’d book for this done at zedfest!
2005 e85 z4, 2.5
GuidoK
Post by GuidoK » Thu Feb 08, 2018 2:58 pm
Roundozo wrote: Thu Feb 08, 2018 9:01 amI can vouch for this fix. Done it on my coupe a while back and it's transformed the steering. Feels so much more planted on the road now. Great fix OP! :thumbsup:
You had sticky steering on your coupe?
Thats quite rare to have it on a FL car.
