E85/E86 Steering Problems (Solved)
- wonkydonkey
Barty It's always good when people pool information like this, saving some forum members thousands of pounds on fixes like this. There is still some hope for the internet yet!
Previous:
~2006 Z4MR in Silver Grey
~2003 3.0i E85 in Sterling Grey
Click here for the Sticky Steering thread
<My name is James>
<My name is James>
I now have this problem.
Had perfect steering last week. Car has been sat for about a week went to drive it today and it feels a total mess.
- Wandering sensation above 70 kph;
- Input from the road surface translates into minute actions from the steering motor;
- A slight sensation of free play when dead straight.
-Steering motor fells like its glitching out .
Are we saying the fix is adjusting the steering ring thing as described in this excellent thread ? Seems odd that its happened to my car essentially over night. Would out of balance wheels cause the steering to spaz out also ?
cheers
cheers
- Joycey
Yes mate this thread is saying exactly that, If you're feeling a wandering sensation tighten the ring by a mm or two.marmite monster wrote: ↑Wed Nov 03, 2021 2:03 pm I now have this problem.
cheers
- wonkydonkey
marmite monster The temperature has dropped markedly between this week and last week. This could have been just enough to introduce some free play (which you can hopefully take care of with a small adjustment, as per Joyce's reply above).
Previous:
<My name is James>
<My name is James>
Amazing thanks chaps.
Yeah had the first 2 frosts of the year while it was sat last week. Nothing more exciting than a frozen bird bath on the rear hatch
Hi all, new to the forum but have owned my E86 for nearly 10 years now (and very happily). Recently however I’ve got a horrible wailing noise from the steering when going very slow, full lock to the right, picked up this thread but not too much here about the noise, just sticky steering which I don’t have! Any ideas or solutions much appreciated
- Ewazix
If it's a groan like a Viking ship's horn, there are several threads about it on here if you search. The cure is usually quite simple lubricationSmartalex wrote: ↑Sat Nov 13, 2021 5:28 pm Hi all, new to the forum but have owned my E86 for nearly 10 years now (and very happily). Recently however I’ve got a horrible wailing noise from the steering when going very slow, full lock to the right, picked up this thread but not too much here about the noise, just sticky steering which I don’t have! Any ideas or solutions much appreciated
e.g. see viewtopic.php?t=119423
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
Thanks, difficult to say if it’s a Viking ships horn! but I think you’re spot on and thanks for the link to your comprehensive post. To be honest there’s a really good specialist near me so I’ll likely take the zed there as it’s got quite “rattly” as well, local garage found nothing. I’ll take the post(s) about steering adjustment and lubrication and hope they can sort it. Thanks again.
I find after the winter lay up, the steering can sometimes have a moan for the first drive out.
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Ewazix
Let us know what the fix isSmartalex wrote: ↑Sat Nov 13, 2021 7:41 pm Thanks, difficult to say if it’s a Viking ships horn! but I think you’re spot on and thanks for the link to your comprehensive post. To be honest there’s a really good specialist near me so I’ll likely take the zed there as it’s got quite “rattly” as well, local garage found nothing. I’ll take the post(s) about steering adjustment and lubrication and hope they can sort it. Thanks again.
Fiesta Ecoboost
Fiesta Ecoboost
Thanks for the heads up, I do use the car every day. This sound has really developed over a long time. Initially every now and then on full lock right when parking, then more frequently and then full lock either side! It still doesn’t happen all the time but I’m contemplating selling (reluctantly) so want it sorting. Will post when I know the fix is done.
Quick update on the “Viking horn steering” and rattling issue I’ve had, well it’s completely disappeared! Nothings been done to the car apart from a few longer drives (but really not very long) and the incessant rattling also disappeared too. No idea if they are linked or why it’s stopped but it has. Got an mot coming up in Feb so going to go to specialist and get them to have a good look at the same time. Thanks for all the help, I’ll let them know the advice from here so they have something to go at! Cheers
- perttu
After long experimentation with different tools to loosen the adjustment ring, I finally found a working setup and just wanted to share it.
This is specifically for cars which have the adjustment ring attached with allen bolts. For torx bolt cars the procedure is apparently simpler, using a spanner seems to be the best option.
Anyway, see the attached picture for my setup. It’s like this: 1/4” ratchet -> 150 mm extension -> joint -> 50 mm extension -> 6 mm allen bolt.
Looking from footwell up, your feet pointing towards rear of the car, the tool goes in from the left side of the steering column. This gives you more direct access to the bolt, at least I had major difficulty fitting any tools in from the right side of the column (could not do it).
Cheers!
Cheers!
”Buy a BMW Z4, they zed. It’ll be fun, they zed.”
E85 3.0i 2003 Black Sapphire
Tesla Model 3 Performance
- enuff_zed
Welcome to the forum!perttu wrote: ↑Sun Apr 03, 2022 8:00 am After long experimentation with different tools to loosen the adjustment ring, I finally found a working setup and just wanted to share it.
Cheers!
Thank you for this help.
I recently changed the EPS motor and was fortunate to have the torx head bolts, which an 8mm ratchet ring spanner fits well.
Not sure it would have been so easy with allen key bolts? Especially fitting the bolts back in again. I was able to hold them in the ring spanner and push them in with a screwdriver blade.
Which leads me to wonder whether it would be worth picking up a pair of the torx versions and fitting them instead if I ever did another one and found it had the allen key version?
- perttu
Thanks for having meWelcome to the forum!
Based on my limited experience, there is so little space up there, that if you have to do anything more complex than loosening the bolts, rotating the ring and then tightening the bolts again, it's probably easier to remove the whole steering column from the car. Then again, maybe some magician with right tools and small hands could it .Not sure it would have been so easy with allen key bolts?
