Amateur detailing with a DA polisher....with pics!
Claying, polishing, waxing... share your secrets in here.
ph001
Post by ph001 » Fri Sep 29, 2017 12:27 pm
OK, so been doing lots of cosmetic work on the Zed over the last few weeks so thought I'd share a few pics. Like many people have said previously I'd absolutely recommend to purchase a DA polisher. I'd say it's virtually impossible to do any damage with them unless you go completely mental with a ridiculously aggressive pad / compound. I think more importantly, it's really satisfying to do. Very enjoyable actually (although I'm not sure I could do it as a job day in day out).
Here is a link to all the products I am using... viewtopic.php?f=15&t=99630
So the order of work was:
  • Brush soft top down with rubber bristled brush and spray with 303 cleaner to lift dirt with nail brush
  • Thoroughly wash and dry car with wax free shampoo.
  • Hose rinse and dry with quality microfibre...
  • Soft top - When fully dry, mask any risky runoff areas and apply dye to restore colour.
  • Wait until thoroughly dry and apply soft-top proofer for protection
  • Remove masking and clay down paint using quick detailer spray as lube...
  • Remove any remaining clay residues with quick detailer and microfibre towel
  • Mask rubber seals and trims with tape and start test polish on a small area with least aggressive pad / compound, moving up to more aggressive pad if necessary.
  • Wipe area with panel wipe and inspect with bright diffused light source.
  • When satisfied, wipe down entire car with panel wipe and treat with quality sealant (main purposes to give hardness to paint and increase resilience to further swirl marks). Do the wheels as well (make sure they are fully cleaned and panel wiped first)
  • It's important that car is protected from elements after the sealant (ideally garaged and left overnight )
  • Apply quality LSP (last stage protection) by hand with foam applicator. Buff off with clean microfibre.
  • Treat all rubber seals with gummi pflege.
Roof dyed with Renovo..
Looking nice and black
Some pretty bad paint defects to sort!
Not perfect but looking better.
Mirrors were awful!
Mirrors were awful!
Much better colour now.
ph001
Post by ph001 » Fri Sep 29, 2017 12:28 pm
After the Sonus nano protect but before wax...
jamie_z4
Post by jamie_z4 » Fri Sep 29, 2017 1:40 pm
Wish I had a 'coloured' zed so I could see results like this. Looks good
18 Z4s owned to date.
Current: 2.5i Titan silver
ph001
Post by ph001 » Fri Sep 29, 2017 2:25 pm
I actually added quite a lot of artefacts with the clay bar (brand new). Not sure if that's because I ran out of quick detailer as a lube so just used washing up liquid diluted about 100:1 in a spray bottle. No obvious contamination in the clay and car was perfectly clean. Was pretty horrified when I saw what it had done but the DA got them out no problem without too much work.
This colour looks amazing when glowing but seems ridiculously sensitive to even the smallest of swirls. I'd take grey any day!
jamie_z4
Post by jamie_z4 » Fri Sep 29, 2017 4:25 pm
Is it Monaco blue? My old coupe was Monaco n I know how sensitive that was to scratching.
ph001
Post by ph001 » Fri Sep 29, 2017 4:37 pm
jamie_z4 wrote: Fri Sep 29, 2017 4:25 pm Is it Monaco blue? My old coupe was Monaco n I know how sensitive that was to scratching.
That's the one! It's even worse than black for that, does look lovely though.
jamie_z4
Post by jamie_z4 » Fri Sep 29, 2017 4:44 pm
I did use the rotary on mine a couple of times but just give it a couple of coats of poorboys black hole to cover up the holograms I caused and all the swirls :rofl:
john-e89
Post by john-e89 » Mon Oct 02, 2017 7:08 pm
jamie_z4 wrote: Fri Sep 29, 2017 4:44 pm I did use the rotary on mine a couple of times but just give it a couple of coats of poorboys black hole to cover up the holograms I caused and all the swirls :rofl:
:rofl:
Yep, precisely why mine has stayed in the box un-used so far J...I'm too chicken to try the damn thing... :lol:
Car looks superb OP...great job... :thumbsup:
MR2 MK 2
E89 35is
G29
deka1
Post by deka1 » Mon Oct 02, 2017 8:23 pm
Nice work is the midnight blue metallic
ph001
Post by ph001 » Mon Oct 09, 2017 7:59 pm
And finally...some outdoor pics
ph001
Post by ph001 » Mon Oct 09, 2017 8:02 pm
bz4kev
Post by bz4kev » Mon Oct 09, 2017 8:22 pm
Looks mint l know what your saying regarding scratches mine attracts them like a magnet
2004 z4 30i auto Toledo blue stubby Areo front back sideskirts and rear spoiler M/// MFSW DLV exhaust mod mma tips vanos overhaul 108s refurbed ram air scoop E46 M3 heated seats clear rear lights M/// sport black grills
ph001
Post by ph001 » Mon Oct 09, 2017 8:22 pm
ph001
Post by ph001 » Mon Oct 09, 2017 8:23 pm
Lovely pic Kev!
jamie_z4
Post by jamie_z4 » Mon Oct 09, 2017 8:27 pm
That interior wow
